I have read here in the forum telemetry frames that are successfully decoded are now also uploaded into the database. Is this right? I can’t find the forum thread any longer.
This url points to the API endpoint of the satnogs-db which is probably not what you want.
If you want to see the decoded telemetry data, have a look at https://dashboard.satnogs.org
If you want to download frames from db: log-in to the db, then there will be a download option available on the satellite page (if there are frames available for this satellite).
Hi @kerel, thanks. Right that was the announcement I was thinking of.
So it is not possible to get .json data of telemetry frames in the database?
I am working on a little python project and was looking for something like an api request to get the latest frame within my application. It already works for observations (db.satnogs.org/api/observations) I know that there is the possibility to download the frames as a .CSV file but that is not really helping me in this case.
Unfortunately for now the only way to download frames from db is the csv file, telemetry API in db is used only for pushing data frames in db.
However there are plans for creating and improving the api of db after moving forward with some more important issues and changes like artifacts and decoders/dashboards.
the API will in fact produce frames, yes, but only for satellites we have few frames for at the moment (hence the issue that @MasterJ ran into with the page load)
Hm. So is it possible to get specific frames using the API?
When I look at the stats page I see that my station has already delivered n frames.
I doubt that someone downloads the .csv table every day and counts the frames to update the stats
Ok, for fetching frames automatically this API endpoint would be the right choice (in principle). Unfortunately it doesn’t provide advanced filters yet and it’s broken for satellites with too much frames (known issue as @cshields mentioned. nevertheless I created issue satnogs-db#266 to track this).
