Stvid Setup, and optical observations for NOOBS
clear sky - 2026-07-14 (time in UTC)
my ip cam: TAPO C325WB (original firmware, default 20fps)
this my stvid configuration:
configuration.ini.share2satno.txt (4.3 KB)
configuration.ini
[Observer]
cospar = 9999             # COSPAR number of observer's site
name = BALI           # Name of observer
latitude = -8.736        # Latitude of location (decimal degrees)
longitude = 115.195       # Longitude of location (decimal degrees)
height = 10              # Height of location (meters)
[Setup]
camera_type = CV2                 # CV2 or ASI or PI
tracking_mount = False
alt_sunset = -6.0                 # Solar altitude at sunset
alt_sunrise = -6.0                # Solar altitude at sunrise
observations_path = /home/linux/obs
[Credentials]
st-username = x       # Space-track.org username
st-password = x       # Space-track.org password
[ASI]
device_id = 0           # Device ID
nx = 968                # Camera horizontal pixel count
ny = 608                # Camera vertical pixel count
nframes = 100           # Number of frames for each image
gain = 300              # Camera gain
maxgain = 300           # Maximum gain (for autogain; starts at gain)
autogain = True         # Use autogain
exposure = 100000       # Exposure time in microseconds
brightness = 10         # Target brightness of pixels
bandwidth = 90          # Bandwidth usage (percent)
high_speed = 0          # High speed mode (0 for False, 1 for True)
hardware_bin = 0        # Hardware binning (0 for False, 1 for True)
bin = 1                 # ASI software binning factor (1: 1x2, 2: 2x2 etc)
software_bin = 2        # STVID software binning factor (1: 1x1, 2: 2x2 etc)
sdk = /path/to/libASICamera2.so # path to the SDK library
[PI]
nx =  800               # Camera horizontal pixel count
ny =  600               # Camera vertical pixel count
framerate = 5		# Take 5 frames per second
exposure = 200000	# Exposure time in us
awb_gain_red = 2	# Gain for red.
awb_gain_blue = 2.3	# Gain for blue
analog_gain = 16	# Analog gain
digital_gain = 64	# Digital gain
# my ip cam: tapo c325wb
[CV2]
device_string = rtsp://x:x@x.x.x.x:554/stream1
# stream1 resolution 2560 x 1440. after software_bin = 2, this become half = 1280 x 720
# then crop 1280 - 480 = 800 and 720 - 120 = 600
software_crop_width = 480
software_crop_height = 120
#result after cropped
nx = 800
ny = 600
nframes = 400
software_bin = 2        # STVID software binning factor (1: 1x1, 2: 2x2 etc) (bikin file output jadi lebih kecil)
# C0 blue
# C1 orange
# C2 green
# C3 red
# C4 violet
# C5 brown
# C6 pink
# C7 gray
# C8 yellow
# C9 blue light
# C10 blue
# C11 orange, repeat ...
[Elements]
tlepath = /home/linux/tle
tlefile4 = satno.tle
name4 = Satnogs
abbrev4 = satnogs
color4 = C6
tlefile5 = starlink.tle
name5 = Starlink
abbrev5 = starlink
color5 = C4
tlefile1 = catalog.tle  # TLE File
name1 = Catalog	            	 # Catalog name
abbrev1 = catalog		 # Catalog abbreviation
color1 = C0			 # Color code
tlefile2 = classfd.tle
name2 = Classified
abbrev2 = classfd
color2 = C1
tlefile3 = inttles.tle
name3 = Integrated
abbrev3 = inttles
color3 = C2
[DiagnosticPlot]
colormap = gray_r
[LineDetection]
min_sigma = 3.2               # Minimum track selection significance, kalau banyak noise dinaikkan angkanya. default 5
min_track_points = 25         # 10 Minimum number of points making up a track
min_track_width = 10           # 7 Minimum track selection width (pixels)
color = C3                    # Detected track color code
cpu_count = 2                 # CPU threads to use
[Identification]
max_off_track_offset_deg = 0.1            # Maximum off-track offset [angle; deg]
max_along_track_offset_s = 2.0            # Maximum off-track offset [time; sec]
max_direction_difference_deg = 2.0        # Maximum difference between direction of motion [angle; deg]
max_velocity_difference_percent = 5.0     # Maximum velocity difference [percent]
[Astrometry]
min_stars = 25            #ok : 20 Minimum number of stars to attempt plate solve
max_magnitude = 13 # between 12 - 13 still there bending. 13-15 same result. maybe because the star detected is same
solve-field_args = -O -l 10 -z 2 -t 1 --crpix-center # Solve-field arguments
#[Shutter]
#pin = 19                  # GPIO pin controlling shutter
#[Aimpoint]                # Stop/start when aimpoint is in/out of shadow
#az_deg = 180              # Aimpoint azimuth (deg)
#alt_deg = 60              # Aimpoint altitude (deg)
#height_km = 2000          # Aimpoint orbital height (km)
.fits example from obs and tle used:
tle.zip (2.3 MB)
2026-07-14T20-55-59.725.fits.zip (3.5 MB)
i modified original @cgbsat acquire.py, so now support cropping. get here:
acquire-modif-crop.py.txt (29.5 KB)
acquire.py
#!/usr/bin/env python3
import sys
import os
import numpy as np
import cv2
import time
import ctypes
import multiprocessing
from astropy.coordinates import EarthLocation
from astropy.time import Time
from astropy.io import fits
import astropy.units as u
from stvid.utils import observe_logic
import logging
import configparser
import argparse
def setup_logging(path):
    logFormatter = logging.Formatter(
        "%(asctime)s [%(processName)-12.12s] [%(levelname)-5.5s] %(message)s"
    logger = logging.getLogger()
    logger.handlers.clear()
    logger.setLevel(logging.DEBUG)
    fileHandler = logging.FileHandler(os.path.join(path, "acquire.log"))
    fileHandler.setFormatter(logFormatter)
    logger.addHandler(fileHandler)
    consoleHandler = logging.StreamHandler(sys.stdout)
    consoleHandler.setFormatter(logFormatter)
    logger.addHandler(consoleHandler)
    return logger
# Capture images from pi
def capture_pi(image_queue, z1base, t1base, z2base, t2base, nx, ny, nz, tend, device_id, live, conf_file):
    global logger
    logger = setup_logging(os.getcwd())
    cfg = configparser.ConfigParser(inline_comment_prefixes=("#", ";"))
    cfg.read(conf_file)
    from picamerax.array import PiRGBArray
    from picamerax import PiCamera
    z1 = np.ctypeslib.as_array(z1base.get_obj()).reshape(ny, nx, nz)
    t1 = np.ctypeslib.as_array(t1base.get_obj())
    z2 = np.ctypeslib.as_array(z2base.get_obj()).reshape(ny, nx, nz)
    t2 = np.ctypeslib.as_array(t2base.get_obj())
    # Intialization
    first = True
    slow_CPU = False
    # Initialize cv2 device
    camera = PiCamera(sensor_mode=2)
    camera.resolution = (nx, ny)
    # Turn off any thing automatic.
    camera.exposure_mode = "off"
    camera.awb_mode = "off"
    # ISO needs to be 0 otherwise analog and digital gain won't work.
    camera.iso = 0
    # set the camea settings
    camera.framerate = cfg.getfloat(camera_type, "framerate")
    camera.awb_gains = (cfg.getfloat(camera_type, "awb_gain_red"), cfg.getfloat(camera_type, "awb_gain_blue"))
    camera.analog_gain = cfg.getfloat(camera_type, "analog_gain")
    camera.digital_gain = cfg.getfloat(camera_type, "digital_gain")
    camera.shutter_speed = cfg.getint(camera_type, "exposure")
    rawCapture = PiRGBArray(camera, size=(nx, ny))
    # allow the camera to warmup
    time.sleep(0.1)
    try:
        # Loop until reaching end time
        while float(time.time()) < tend:
            # Wait for available capture buffer to become available
            if (image_queue.qsize() > 1):
                logger.warning("Acquiring data faster than your CPU can process")
                slow_CPU = True
            while (image_queue.qsize() > 1):
                time.sleep(0.1)
            if slow_CPU:
                lost_video = time.time() - t
                logger.info("Waited %.3fs for available capture buffer" % lost_video)
                slow_CPU = False
            # Get frames
            i = 0
            for frameA in camera.capture_continuous(rawCapture, format="bgr", use_video_port=True):
                # Store start time
                t0 = float(time.time())
                # grab the raw NumPy array representing the image, then initialize the timestamp
                frame = frameA.array
                # Compute mid time
                t = (float(time.time()) + t0) / 2
                # Skip lost frames
                if frame is not None:
                    # Convert image to grayscale
                    z = np.asarray(cv2.cvtColor(
                        frame, cv2.COLOR_BGR2GRAY)).astype(np.uint8)
                    # optionally rotate the frame by 2 * 90 degrees.
                    # z = np.rot90(z, 2)
                    # Display Frame
                    if live is True:
                        cv2.imshow("Capture", z)
                        cv2.waitKey(1)
                    # Store results
                    if first:
                        z1[:, :, i] = z
                        t1[i] = t
                    else:
                        z2[:, :, i] = z
                        t2[i] = t
                # clear the stream in preparation for the next frame
                rawCapture.truncate(0)
                # count up to nz frames, then break out of the for loop.
                i += 1
                if i >= nz:
                    break
            if first:
                buf = 1
            else:
                buf = 2
            image_queue.put(buf)
            logger.debug("Captured buffer %d" % buf)
            # Swap flag
            first = not first
        reason = "Session complete"
    except KeyboardInterrupt:
        print()
        reason = "Keyboard interrupt"
    except ValueError as e:
        logger.error("%s" % e)
        reason = "Wrong image dimensions? Fix nx, ny in config."
    finally:
        # End capture
        logger.info("Capture: %s - Exiting" % reason)
        camera.close()
# Capture images from cv2
def capture_cv2(image_queue, z1base, t1base, z2base, t2base, nx, ny, nz, tend, device_id, live, conf_file):
    global logger
    cfg.read(conf_file)
    # Intialization
    camera_type  = "CV2"
    first = True
    slow_CPU = False
    if cfg.has_option(camera_type, "device_string"):
        device = cv2.VideoCapture(cfg.get(camera_type, "device_string"))
    else:
        device = cv2.VideoCapture(device_id)
    # Test for software binning
    try:
        software_bin = cfg.getint(camera_type, "software_bin")
    except configparser.Error:
        software_bin = 1
    # Test for software cropping
    try:
        software_crop_width = cfg.getint(camera_type, "software_crop_width")
        software_crop_width = 0
    try:
        software_crop_height = cfg.getint(camera_type, "software_crop_height")
        software_crop_height = 0
    # Set properties
    device.set(3, nx * software_bin)
    device.set(4, ny * software_bin)
    try:
                slow_CPU = True
                time.sleep(0.1)
            if slow_CPU:
                slow_CPU = False
            # Get frames
            for i in range(nz):
                # Store start time
                # Get frame
                res, frame = device.read()
                # Compute mid time
                # Skip lost frames
                if res is True:
                    # Apply software binning
                    if software_bin > 1:
                        my, mx = z.shape
                        z = cv2.resize(z, (mx // software_bin, my // software_bin))
                    # Apply software cropping
                    if software_crop_width > 1:
                        my, mx = z.shape
                        # Crop n pixels
                        crop_w = mx - software_crop_width
                        crop_h = my - software_crop_height
                        y_start = (my - crop_h) // 2
                        x_start = (mx - crop_w) // 2
                        y_end = y_start + crop_h
                        x_end = x_start + crop_w
                        z = z[y_start:y_end, x_start:x_end]
                    # Display Frame
                    if live is True:
                        cv2.waitKey(1)
                    # Store results
                    if first:
                        z1[:, :, i] = z
                        t1[i] = t
                    else:
                        z2[:, :, i] = z
                        t2[i] = t
            if first:
                buf = 1
            else:
                buf = 2
            logger.debug("Captured z%d" % buf)
            # Swap flag
            first = not first
        print()
    finally:
        # End capture
        device.release()
# Capture images
def capture_asi(image_queue, z1base, t1base, z2base, t2base, nx, ny, nz, tend, device_id, live, conf_file):
    global logger
    cfg.read(conf_file)
    import zwoasi as asi
    first    = True  # Array flag
    slow_CPU = False # Performance issue flag
    camera_type  = "ASI"
    gain         = cfg.getint(camera_type, "gain")
    maxgain      = cfg.getint(camera_type, "maxgain")
    autogain     = cfg.getboolean(camera_type, "autogain")
    exposure     = cfg.getint(camera_type, "exposure")
    binning      = cfg.getint(camera_type, "bin")
    brightness   = cfg.getint(camera_type, "brightness")
    bandwidth    = cfg.getint(camera_type, "bandwidth")
    high_speed   = cfg.getint(camera_type, "high_speed")
    hardware_bin = cfg.getint(camera_type, "hardware_bin")
    sdk          = cfg.get(camera_type, "sdk")
    try:
        software_bin = 0
    # Initialize device
    asi.init(sdk)
    num_cameras = asi.get_num_cameras()
    if num_cameras == 0:
        logger.error("No ZWOASI cameras found")
        raise ValueError
        sys.exit()
    cameras_found = asi.list_cameras()  # Models names of the connected cameras
    if num_cameras == 1:
        device_id = 0
        logger.info("Found one camera: %s" % cameras_found[0])
    else:
        logger.info("Found %d ZWOASI cameras" % num_cameras)
        for n in range(num_cameras):
            logger.info("    %d: %s" % (n, cameras_found[n]))
        logger.info("Using #%d: %s" % (device_id, cameras_found[device_id]))
    camera = asi.Camera(device_id)
    camera_info = camera.get_camera_property()
    logger.debug("ASI Camera info:")
    for (key, value) in camera_info.items():
        logger.debug("  %s : %s" % (key,value))
    camera.set_control_value(asi.ASI_BANDWIDTHOVERLOAD, bandwidth)
    camera.disable_dark_subtract()
    camera.set_control_value(asi.ASI_GAIN, gain, auto=autogain)
    camera.set_control_value(asi.ASI_EXPOSURE, exposure, auto=False)
    camera.set_control_value(asi.ASI_AUTO_MAX_GAIN, maxgain)
    camera.set_control_value(asi.ASI_AUTO_MAX_BRIGHTNESS, 20)
    camera.set_control_value(asi.ASI_WB_B, 99)
    camera.set_control_value(asi.ASI_WB_R, 75)
    camera.set_control_value(asi.ASI_GAMMA, 50)
    camera.set_control_value(asi.ASI_BRIGHTNESS, brightness)
    camera.set_control_value(asi.ASI_FLIP, 0)
    try:
        camera.set_control_value(asi.ASI_HIGH_SPEED_MODE, high_speed)
    except:
        pass
    try:
        camera.set_control_value(asi.ASI_HARDWARE_BIN, hardware_bin)
    except:
        pass
    camera.set_roi(bins=binning)
    camera.start_video_capture()
    camera.set_image_type(asi.ASI_IMG_RAW8)
    try:
        # Fix autogain
        if autogain:
            while True:
                # Get frame
                z = camera.capture_video_frame()
                # Break on no change in gain
                settings = camera.get_control_values()
                if gain == settings["Gain"]:
                    break
                gain = settings["Gain"]
                slow_CPU = True
                time.sleep(0.1)
            if slow_CPU:
                slow_CPU = False
            # Get settings
            try:
                temp = settings["Temperature"] / 10
            except:
                gain, temp = 0, 0
            logger.info("Capturing frame with gain %d, temperature %.1f" % (gain, temp))
            # Set gain
            if autogain:
            # Get frames
            for i in range(nz):
                # Store start time
                # Get frame
                    my, mx = z.shape
                # Compute mid time
                # Display Frame
                if live is True:
                    cv2.waitKey(1)
                # Store results
                if first:
                    z1[:, :, i] = z
                    t1[i] = t
                else:
                    z2[:, :, i] = z
                    t2[i] = t
            if first:
                buf = 1
            else:
                buf = 2
            logger.debug("Captured buffer %d (%dx%dx%d)" % (buf, nx, ny, nz))
            # Swap flag
            first = not first
        print()
    except MemoryError as e:
        logger.error("Capture: Memory error %s" % e)
    finally:
        # End capture
        camera.stop_video_capture()
        camera.close()
def compress(image_queue, z1base, t1base, z2base, t2base, nx, ny, nz, tend, path, device_id, conf_file):
    """ compress: Aggregate nframes of observations into a single FITS file, with statistics.
        ImageHDU[0]: mean pixel value nframes         (zmax)
        ImageHDU[1]: standard deviation of nframes    (zstd)
        ImageHDU[2]: maximum pixel value of nframes   (zmax)
        ImageHDU[3]: maximum pixel value frame number (znum)
    Also updates a [observations_path]/control/state.txt for interfacing with satttools/runsched and sattools/slewto
    global logger
    cfg.read(conf_file)
    # Force a restart
    controlpath = os.path.join(path, "control")
    if not os.path.exists(controlpath):
        try:
            os.makedirs(controlpath)
        except PermissionError:
            logger.error("Can not create control path directory: %s" % controlpath)
            raise
    if not os.path.exists(os.path.join(controlpath, "position.txt")):
        with open(os.path.join(controlpath, "position.txt"), "w") as fp:
            fp.write("\n")
    with open(os.path.join(controlpath, "state.txt"), "w") as fp:
        fp.write("restart\n")
    try:
        # Start processing
        while True:
            # Check mount state
            restart = False
            with open(os.path.join(controlpath, "state.txt"), "r") as fp:
                line = fp.readline().rstrip()
                if line == "restart":
                    restart = True
            # Restart
            if restart:
                # Log state
                    fp.write("observing\n")
                # Get obsid
                trestart = time.gmtime()
                obsid = "%s_%d/%s" % (time.strftime("%Y%m%d", trestart), device_id, time.strftime("%H%M%S", trestart))
                filepath = os.path.join(path, obsid)
                logger.info("Storing files in %s" % filepath)
                # Create output directory
                if not os.path.exists(filepath):
                    try:
                        os.makedirs(filepath)
                        logger.error("Can not create output directory: %s" % filepath)
                        raise
                # Get mount position
                with open(os.path.join(controlpath, "position.txt"), "r") as fp:
                with open(os.path.join(filepath, "position.txt"), "w") as fp:
                    fp.write(line)
            # Wait for completed capture buffer to become available
            while image_queue.empty():
                time.sleep(0.1)
            # Get next buffer # from the work queue
            try:
                proc_buffer = image_queue.get(timeout=60)
            except:
                logger.debug("Queue timed out")
                break
            logger.debug("Processing buffer %d" % proc_buffer)
            # Log start time
            tstart = time.time()
            # Process first buffer
            if proc_buffer == 1:
                t = t1
                z = z1
            elif proc_buffer == 2:
                t = t2
                z = z2
            # Format time
            nfd = "%s.%03d" % (time.strftime("%Y-%m-%dT%T",
                                             time.gmtime(t[0])), int((t[0] - np.floor(t[0])) * 1000))
            t0 = Time(nfd, format="isot")
            dt = t - t[0]
            # Cast to 32 bit float
            z = z.astype("float32")
            # Compute statistics
            zmax = np.max(z, axis=2)
            znum = np.argmax(z, axis=2)
            zs1 = np.sum(z, axis=2) - zmax
            zs2 = np.sum(z * z, axis=2) - zmax * zmax
            zavg = zs1 / float(nz - 1)
            zstd = np.sqrt((zs2 - zs1 * zavg) / float(nz - 2))
            # Convert to float and flip
            zmax = np.flipud(zmax.astype("float32"))
            znum = np.flipud(znum.astype("float32"))
            zavg = np.flipud(zavg.astype("float32"))
            zstd = np.flipud(zstd.astype("float32"))
            # Generate fits
            ftemp = "%s.temp" % nfd.replace(":", "-")
            fname = "%s.fits" % nfd.replace(":", "-")
            # Format header
            hdr = fits.Header()
            hdr["DATE-OBS"] = "%s" % nfd
            hdr["MJD-OBS"]  = t0.mjd
            hdr["EXPTIME"]  = dt[-1] - dt[0]
            hdr["NFRAMES"]  = nz
            hdr["CRPIX1"]   = float(nx) / 2
            hdr["CRPIX2"]   = float(ny) / 2
            hdr["CRVAL1"]   = 0.0
            hdr["CRVAL2"]   = 0.0
            hdr["CD1_1"]    = 1 / 3600
            hdr["CD1_2"]    = 0.0
            hdr["CD2_1"]    = 0.0
            hdr["CD2_2"]    = 1 / 3600
            hdr["CTYPE1"]   = "RA---TAN"
            hdr["CTYPE2"]   = "DEC--TAN"
            hdr["CUNIT1"]   = "deg"
            hdr["CUNIT2"]   = "deg"
            hdr["CRRES1"]   = 0.0
            hdr["CRRES2"]   = 0.0
            hdr["EQUINOX"]  = 2000.0
            hdr["RADECSYS"] = "ICRS"
            hdr["COSPAR"]   = cfg.getint("Observer", "cospar")
            hdr["OBSERVER"] = cfg.get("Observer", "name")
            hdr["SITELONG"] = cfg.getfloat("Observer", "longitude")
            hdr["SITELAT"] = cfg.getfloat("Observer", "latitude")
            hdr["ELEVATIO"] = cfg.getfloat("Observer", "height")
            if cfg.getboolean("Setup", "tracking_mount"):
                hdr["TRACKED"] = 1
            else:
                hdr["TRACKED"] = 0
            for i in range(nz):
                hdr["DT%04d" % i] = dt[i]
            for i in range(10):
                hdr["DUMY%03d" % i] = 0.0
            # Write fits file
            hdu = fits.PrimaryHDU(data=np.array([zavg, zstd, zmax, znum]),
                                  header=hdr)
            hdu.writeto(os.path.join(filepath, ftemp))
            os.rename(os.path.join(filepath, ftemp), os.path.join(filepath, fname))
            logger.info("Compressed %s in %.2f sec" % (fname, time.time() - tstart))
            # Exit on end of capture
            if t[-1] > tend:
                break
            logger.debug("Processed buffer %d" % proc_buffer)
        pass
        logger.error("Compress: Memory error %s" % e)
    finally:
        # Exiting
        logger.info("Exiting compress")
# Main function
if __name__ == '__main__':
    multiprocessing.set_start_method("spawn", force=True)
    # Read commandline options
    conf_parser = argparse.ArgumentParser(description="Capture and compress" +
                                                      " live video frames.")
    conf_parser.add_argument("-c", "--conf_file",
                             help="Specify configuration file(s). If no file" +
                             " is specified 'configuration.ini' is used.",
                             action="append",
                             nargs="?",
                             metavar="FILE")
    conf_parser.add_argument("-t", "--test",
                             nargs="?",
                             action="store",
                             default=False,
                             help="Testing mode - Start capturing immediately for (optional) seconds",
                             metavar="s")
    conf_parser.add_argument("-l", "--live", action="store_true",
                             help="Display live image while capturing")
    args = conf_parser.parse_args()
    # Process commandline options and parse configuration
    conf_file = args.conf_file if args.conf_file else "configuration.ini"
    result = cfg.read(conf_file)
    if not result:
        print("Could not read config file: %s\nExiting..." % conf_file)
        sys.exit()
    # Setup logging
    logFormatter = logging.Formatter("%(asctime)s [%(threadName)-12.12s] " +
                                     "[%(levelname)-5.5s]  %(message)s")
    # Generate directory
    path = os.path.abspath(cfg.get("Setup", "observations_path"))
    if not os.path.exists(path):
        try:
            os.makedirs(path)
            logger.error("Can not create observations_path: %s" % path)
            sys.exit()
    logger.info("Using config: %s" % conf_file)
    # Testing mode
    if args.test is None:
        test_duration = 31
        testing = True
    elif args.test is not False:
        test_duration = int(args.test)
        testing = True
    else:
        testing = False
    logger.info("Test mode: %s" % testing)
    if (testing):
        logger.info("Test duration: %ds" % test_duration)
    # Live mode
    live = True if args.live else False
    logger.info("Live mode: %s" % live)
    # Get camera type
    camera_type = cfg.get("Setup", "camera_type")
    # Get device id
    device_id = cfg.getint(camera_type, "device_id")
    # Current time
    tnow = Time.now()
    # Set location
    loc = EarthLocation(lat=cfg.getfloat("Observer", "latitude") * u.deg,
                        lon=cfg.getfloat("Observer", "longitude") * u.deg,
                        height=cfg.getfloat("Observer", "height") * u.m)
    if not testing:
        # Reference altitudes
        refalt_set  = cfg.getfloat("Setup", "alt_sunset") * u.deg
        refalt_rise = cfg.getfloat("Setup", "alt_sunrise") * u.deg
        # Aimpoint configuration
        if cfg.has_section("Aimpoint"):
            aimpoint_az = cfg.getfloat("Aimpoint", "az_deg") * u.deg
            aimpoint_alt = cfg.getfloat("Aimpoint", "alt_deg") * u.deg
            aimpoint_height = cfg.getfloat("Aimpoint", "height_km") * u.km
        else:
            aimpoint_az, aimpoint_alt, aimpoint_height = None, None, None
        # Get logic
        action, wait_time, tend, state = observe_logic(tnow, loc, refalt_set, refalt_rise,
                                                       aimpoint_az, aimpoint_alt, aimpoint_height)
        # Wait for observation start
        logger.info(state)
        if action == "wait":
            logger.info(f"Waiting for {wait_time:.0f} seconds.")
            try:
                time.sleep(wait_time)
                sys.exit()
    else:
        tend = tnow + test_duration * u.s
    # Read shutter config
    if cfg.has_section("Shutter"):
        from stvid.shutter import Shutter
        shutter = Shutter(cfg.getint("Shutter", "pin"))
    else:
        shutter = None
    logger.info("Starting data acquisition")
    logger.info("Acquisition will end after "+tend.isot)
    # Get settings
    nx = cfg.getint(camera_type, "nx")
    ny = cfg.getint(camera_type, "ny")
    nz = cfg.getint(camera_type, "nframes")
    # Initialize arrays
    z1base = multiprocessing.Array(ctypes.c_uint8, nx * ny * nz)
    t1base = multiprocessing.Array(ctypes.c_double, nz)
    z2base = multiprocessing.Array(ctypes.c_uint8, nx * ny * nz)
    t2base = multiprocessing.Array(ctypes.c_double, nz)
    image_queue = multiprocessing.Queue()
    # Set processes
    pcompress = multiprocessing.Process(target=compress,
                                        name="compress",
                                        args=(image_queue,
                                              nx, ny, nz, tend.unix,
                                              path, device_id, conf_file))
    if camera_type == "PI":
        pcapture = multiprocessing.Process(target=capture_pi,
                                           name="capture_pi",
                                           args=(image_queue,
                                                 device_id, live, conf_file))
    elif camera_type == "CV2":
        pcapture = multiprocessing.Process(target=capture_cv2,
                                           name="capture_cv2",
                                           args=(image_queue,
    elif camera_type == "ASI":
        pcapture = multiprocessing.Process(target=capture_asi,
                                           name="capture_asi",
                                           args=(image_queue,
    try:
        # Open shutter
        if shutter:
            shutter.open()
        # Start
        pcapture.start()
        pcompress.start()
        # End
        try:
            pcapture.join()
            pcompress.join()
        except (KeyboardInterrupt, ValueError):
            time.sleep(0.1) # Allow a little time for a graceful exit
            logger.error("Memory error %s" % e)
        finally:
            pcapture.terminate()
            pcompress.terminate()
        # Release device
        if live is True:
            cv2.destroyAllWindows()
    finally:
        if shutter:
            shutter.close()
