hrkim
June 28, 2022, 3:55pm
#1
Dear, All.
I hope to get your help regarding our satellite STEP CubeLab-II. STEP CubeLab-II is in PVSAT and will be separated from PVSAT tomorrow afternoon about 3:00 PM (KST).
The TLE of PVSAT is as follow:
2022-065A
1 52894U 22065A 22179.22536086 .00000054 00000+0 21446-4 0 9995
2 52894 98.0197 330.2826 0008615 213.1705 271.3716 14.57557373 1002
The transmitter for STEP CubeLab-II is developed by us. The specification for STEP CubeLab-II is as follow:
GMSK
437.485 MHz
9600 bps
AX.25
I hope to find our satellite based on your help.
Would you help to find the satellite tomorrow?
fredy
June 28, 2022, 5:27pm
#2
@hrkim I see that you use radio amateur frequency, could you link to your IARU coordination?
EDIT: The satellite has been added in DB with the temporary NORAD ID 99390. It will be available for scheduling in Network a couple of hours before the deployment.
fredy
June 28, 2022, 5:45pm
#3
@hrkim do you know if the other 3 satellites in the same launch will be deployed at the same time?
fredy
June 28, 2022, 6:53pm
#4
The other three satellites have been also added. So, we have:
fredy
June 28, 2022, 7:10pm
#5
Answering my own question
from Nuri : Test Flight #2 : Naro, South Korea : June 21, 2022 (07:00 UTC)
One deployment will be performed every two days, so:
Satellite
Temporary NORAD ID
Deployment Date
RANDEV
99387
2022-07-01
MIMAN
99388
2022-07-05
SNUGLITE 2
99389
2022-07-03
STEP CUBELAB-II
99390
2022-06-29
K4KDR
June 28, 2022, 8:10pm
#6
So the UTC deployment time for STEP CUBELAB-II is 0600 utc on 29-June-2022, did I do that correctly?
hrkim
June 28, 2022, 11:39pm
#7
No, 3 satellite will be deployed with 2 days
29th Jun 22 - STEP CubeLab-ii
1st Jul 22 - RANDEV
3rd Jul 22 - SNUGLITE
5th Jul 22 - STEP CubeLab-II
hrkim
June 28, 2022, 11:42pm
#8
Dear, Fredy
Thank you for supporting us.
Command to PVSAT for the deployment of STEP CubeLab-II ‘22. 6. 29, 16:50 (KST)
SOLETOP is operating SATNOGS.
I will add STEP2 in the observation.
Would you let me know how to add the observations?
fredy
June 29, 2022, 5:39am
#10
Thanks for the update, I’ve scheduled observation for the first 24h. Please also you or @soletop answer to my previous question:
You should be able to schedule observations now if you have the permissions to do so.
Dear, Fredy.
TLE is updated by KARI as follow.
I will check the IARU link with Chosun univ.
Best regards,
K4KDR
June 29, 2022, 9:23am
#12
Very nice downlink packets consistent with 9k6 seen on 2-minute interval 0900utc over the U.S. Doppler track matched PVSAT very well; unfortunately too weak for me to decode - not enough elevation. Good luck!
-Scott, K4KDR
https://twitter.com/scott23192/status/1542075361839792128
fredy
June 29, 2022, 9:46am
#13
Here is the first successful observation of STEP2 in Network SatNOGS Network - Observation 6147666 and here is the first one with decoded data SatNOGS Network - Observation 6147651 .
Hello, Fredy.
Thank you for your support.
Battery works well. We will check the others via TMTC operation.
Best regards,
fredy
June 29, 2022, 2:06pm
#15
There is a new TLE set from spacetrack for this launch:
0 TBA - TO BE ASSIGNED
1 52897U 22065D 22180.51470043 -.01103556 00000-0 -25807+0 0 9997
2 52897 98.0162 331.5282 0007165 227.2094 179.2094 14.58106744 22
We are going to follow it for STEP CUBELAB-II in DB and Network.
fredy
June 29, 2022, 2:07pm
#16
@soletop is the satellite transmitting all the time or only above certain areas or only after commanding it?
STEP Cubelab-ii transmit the beacon every 60 seconds,
After 2 hours, we will command to the satellite for checking all the status over Korean penisula.
fredy:
52897
Thank you for the update.
@fredy
I updated new satelllite deployed from PVSAT as follow.
RANDEV / KAIST
RANDEV will be launched tomorrow afternoon similar time with STEP CubeLab-II
Frequency : 436.0285MHz
Modulation : BPSK w/ G3RUH
Datarate : 1200 bps and 9600 bps (Default)
Tranceiver : ISIS VHF/UHF Full Duplex Transceiver
Apart from this,
Would you help us command via other site?
Is it possible to use Satnogs for commanding?
fredy
June 30, 2022, 7:05pm
#20
Currently commanding isn’t supported from the Network, however is in our plans.
