Updated station to Buster, then reinstalled satnogs station x 3
it works but no waterfall or date is recorded anyone help?
rtl-sdr dongle works on laptop with sdr# ,
see report below and rtl_test
anyone help ?
“versions”: {
“satnogs-client”: “1.3.1”,
“satnogs-client-ansible”: “202004012056”,
“gr-satnogs”: “2.1-1”,
“gr-soapy”: “2.1.2-1”,
“gnuradio”: “3.8.0.0-6”,
“satnogs-config”: “0.10”
“state”: {
“is-applied”: true,
“pending-tags”: null
“system”: {
“distribution”: {
“RELEASE”: “10”,
“CODENAME”: “buster”,
“ID”: “Raspbian”
“pending-updates”: false,
“platform”: {
“system”: “Linux”,
“node”: “satnogs”,
“release”: “4.19.97-v7+”,
“machine”: “armv7l”,
“processor”: “”
“memory”: {
“total”: 971059200,
“available”: 790810624,
“percent”: 18.6,
“used”: 109879296,
“free”: 401272832,
“active”: 310071296,
“inactive”: 174682112,
“buffers”: 33742848,
“cached”: 426164224,
“shared”: 6479872,
“slab”: 63881216
“disk”: {
“total”: 14978719744,
“used”: 3343458304,
“free”: 10979291136,
“percent”: 23.3
“configuration”: {
“satnogs_antenna”: “rx”,
“satnogs_rf_gain”: “11”,
“satnogs_station_elev”: “125”,
“satnogs_station_id”: “657”,
“satnogs_station_lat”: “-40.938”,
“satnogs_station_lon”: “175.679”
Press Enter to continue…
rtl_ test shows
pi@satnogs:~ $ rtl_test
Found 1 device(s):
0: Realtek, RTL2838UHIDIR, SN: 00000001
[R82XX] PLL not locked!
Sampling at 2048000 S/s.
Info: This tool will continuously read from the device, and report if
samples get lost. If you observe no further output, everything is fine.
Reading samples in async mode…
Allocating 15 zero-copy buffers
lost at least 120 bytes
