it is in GMSK 2400 downlink with an AX25 protocol. It will emit every 30 s if you ever manage to decode. Don’t hesitate to send me this raw data. THANKS
DJIBOUTI-1A packets clearly there, but just not enough SNR for me to decode… just need more elevation. I even isolated the strongest packet & looped it in GNU Radio while fine-tuning the exact center freq & filter bandwidth, but I’ll just need more signal to get a decode. Will keep trying!
Can you tell me where I can download the soundmodem program?
There are many different versions, the main page is at
DJIBOUTI-1 2K4 AX.25 telemetry. RX FN41iq 45E from IQ replay 12Nov23 0220Z Congratulations to the Team. Great achievement. Data to @Satnogs.
That relieves me a little. Can you send me the AX25 raw frame please?
Thanks.
Thanks for decoding.
I downloaded it from UZ7HO Personal page - Packet-Radio - English version and checked, but I could not find a soundmodem that could handle AX.25 G3RUH 1200bd.
Can you send me the soundmodem program by email?
That one was created special and can be downloaded from:
Here is the link to an FM demodulated WAV file from which you may decode the raw data.
Congrats!
Bob
N6RFM
Thank you
Thanks.
Thanks, Bob! And great job getting those decodes. I wasn’t able to decode that last packet, but the first two look good. Hopefully I’ll get a higher elevation pass tomorrow & can find that extra SNR that wasn’t there for me tonight! Just needed a bit more elevation.
U frame UI: p/f=0, No layer 3 protocol implemented., length = 158
dest F4KJX 0 c/r=1 res=3 last=0
source DJIB1A 0 c/r=1 res=3 last=1
000: 8c 68 96 94 b0 40 e0 88 94 92 84 62 82 e1 03 f0 .h...@.....b....
010: 8c 10 c2 ae 4a 5c ab ae 4a 5c 00 00 01 22 98 52 ....J\..J\...".R
020: 00 00 01 00 01 00 33 c1 05 bd c1 c1 00 60 f3 0f ......3......`..
030: 08 3a 17 4e 00 00 f8 f6 f6 f8 f6 cd 64 09 d1 83 .:.N........d...
040: c6 65 00 08 09 cc 11 36 00 11 00 00 ad 02 89 7b .e.....6.......{
050: 66 78 1f 00 00 1e 02 01 b8 01 b8 7f 04 bf 07 fa fx..............
060: 01 66 00 02 02 02 07 01 28 fe d4 40 e8 06 c1 ff .f......(..@....
070: d2 00 19 00 09 00 00 00 00 00 00 00 00 00 00 00 ................
080: 00 00 00 00 00 00 44 4a 49 42 4f 55 54 49 2d 31 ......DJIBOUTI-1
090: 41 20 76 6f 75 73 20 73 61 6c 75 65 20 21 A vous salue !
010: 8c 10 e1 ae 4a 5c c9 ae 4a 5c 00 00 01 22 98 52 ....J\..J\...".R
020: 00 00 01 00 01 00 33 c1 05 bc c1 c0 00 60 f2 0f ......3......`..
030: 08 3b 17 4e 00 00 f7 f6 f5 f7 f6 cd 64 09 ce 82 .;.N........d...
040: c6 63 00 08 08 cc 11 36 00 11 00 00 ae 02 8a 7b .c.....6.......{
could you tell me which tool you can decode this signal ?
. I tried an sdrpp with a sound modem but I can’t decode
For this modulation type, I use GNU Radio (+ gr-satellites) with 2k4 FSK demod and AX.25 (G3RUH=False) deframer. I like the AX.25 display in Direwolf, so the ‘KISS File Sink’ block sends the output to ‘/tmp/kisstnc’ that is available when you run Direwolf with the -p option
One more addition in DB and Network (and in the first post of this thread), is Impulse-1 (LEO Express-1) at 402.680 MHz.
Thanks for sharing the IQ file, this gave me the opportunity to create a gr-satellites yml file
norad: 99028
&tlm0 AX25 telemetry:
telemetry: ax25
1k2 G3RUH FSK downlink:
frequency: 435.835e6
modulation: FSK
baudrate: 1200
framing: AX.25 G3RUH
- *tlm0
2k4 G3RUH FSK downlink:
modulation: FSK
baudrate: 2400
- *tlm0
4k8 G3RUH FSK downlink:
modulation: FSK
baudrate: 4800
- *tlm0
9k6 G3RUH FSK downlink:
modulation: FSK
baudrate: 9600
- *tlm0
And this is the output:
-> Packet from 1k2 G3RUH FSK downlink
Container:
header = Container:
addresses = ListContainer:
Container:
callsign = u'KAFSAT' (total 6)
ssid = Container:
ch = True
ssid = 1
extension = False
Container:
ssid = Container:
ch = False
ssid = 1
extension = True
control = 0x03
pid = 0xF0
info = b'\x08\x02\xc0\xff\x00\xbe\x10\x03\x19\x02\x03\xcd:\x15\xff\xfe\xff\xe4\x00\xd9\x00\xda\x00\x00s\xd4\x01\x00\x07\x01\x06\x01\xf8\x00\x07\x01\x15\x01\x15\x01\x06\x00\x0b\x00\x08\x00\r\x00\x0c\x00\r\x00\x00\x00\x00\x00\x00\x00H\x1fJ\x1f\x00\x00\x00\x00\x97\x131\r\x03\x00\x06\x00\x06\x00\x12\x00\x1a\x00\x04\x00\x04\x00\x04\x00\xb5\x00\xf0\x01\x00\x01\x00A\t\x00\x00A\t\x00\x00e\xf1\x07\x000&\x0c\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00y\xf4\xdb\x04\xaf\xf6\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x11\x00\x01\xff\xe0\xff\x00\x00\x00\x00\x00\x00\r\x99\x99ds\x01\x01\x00' (total 199)
((transmitter . 1k2 G3RUH FSK downlink))
pdu length = 215 bytes
pdu vector contents =
0000: 96 82 8c a6 82 a8 e2 96 82 8c a6 82 a8 63 03 f0
0010: 08 02 c0 ff 00 be 10 03 19 02 03 cd 3a 15 ff fe
0020: ff e4 00 d9 00 da 00 00 73 d4 01 00 07 01 06 01
0030: f8 00 07 01 15 01 15 01 06 00 0b 00 08 00 0d 00
0040: 0c 00 0d 00 00 00 00 00 00 00 48 1f 4a 1f 00 00
0050: 00 00 97 13 31 0d 03 00 06 00 06 00 12 00 1a 00
0060: 04 00 04 00 04 00 b5 00 f0 01 00 01 00 41 09 00
0070: 00 41 09 00 00 65 f1 07 00 30 26 0c 00 00 00 00
0080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00a0: 00 00 00 00 00 00 00 00 00 00 00 79 f4 db 04 af
00b0: f6 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00c0: 00 00 00 11 00 01 ff e0 ff 00 00 00 00 00 00 0d
00d0: 99 99 64 73 01 01 00
name: KAFASAT (not KAFKASAT)
Thank you
Korea Air Force Academy Satellite
