SpaceX F9 Transporter-8 - 2023-06-12 21:35 UTC
TLE set by @PE0SAT for MRC-100:
MRC-100
1 99182U          23173.79400897  .00000000  00000-0  46840-3 0    07
2 99182  97.5127 290.8733 0014159 177.0273 180.4427 15.13242215    03
According to what was declared in the ITU, the DL frequency of Istanbul should be 402.075 Mhz
https://www.itu.int/online/snl/satbandold_snl.sh?ntc_id=123545093&fr1=400&fr2=450&ie=y&sat_type=&sat_name=ISTANBUL&sel_satname=ISTANBUL&plan_id=
At the request of Rony (SATLLA Team), I have added a transmitter suggestion for SATLLA-2I
https://db.satnogs.org/satellite/XDTB-0414-1246-0782-0962#transmitters
… for the GFSK capability that’s included with their satellite’s radio.
These modules are most often used for LoRa, but absolutely support other modes. However, while we normally associate GFSK with FM modulation, previous testing (as well as the code shown below from SATLLA-2I’s programming) indicate that these signals decode when SSB demod is used:
SATLLA-2I_GFSK-parameters
… so, if this suggestion is added to the list of potential transmitters for SATLLA-2I, would it be possible to schedule some SatNogs observations to increase the odds of finding this new satellite?
Good catch, I’ve changed Istanbul transmitter, the future observations will be updated accordingly.
Thanks for adding it, I’m not sure if the coordination is valid for this satellite, as each satellite needs separate coordination with IARU.
I’ll try to schedule some observations and see if we can get anything.
May I ask how many satellites on the rocket have been successfully received so far?
Can list the confirmed satellites for future observations will appreciate…
Thanks
:pray:
Currently the biggest challenge is identifying, we have multi signals and no idea to what satellite they belong.
Even on Ham radio UHF where this is mandatory, a signal on 436.630 no idea what satellite.
Check also this table SpaceX F9 Transporter-8 - 2023-06-12 21:35 UTC - #59 by fredy
New TLE set by @PE0SAT for MRC-100:
MRC-100
1 99182U          23175.10000000  .00000000  00000-0  00000-0 0    01
2 99182  97.5127 292.2526 0007844 177.2573  84.7931 15.13266641    02
EDIT: same TLE with updated epoch
Latest Status Update:
Temporary NORAD ID Satellite NORAD ID to follow Other NORAD IDs Identified Deployed Last Update
RECEIVED AND DEMODULATED
ION SCV-011 56957 - YES YES Identified, here are the ikhnos results
99187 ROM-2 56957 - NO YES Deployed, uses TLE set of its deployer when it was deployed
99182 MRC-100 - - NO YES Deployed, uses TLE set generated by SatNOGS Community
99115 FOSSASAT-FEROX 14 - PlatziSat-1 - all NO YES Received according to tinygs
99100 SpeiSat 56957 - NO YES Deployed, uses TLE set of its deployer when it was deployed
99114 FOSSASAT-FEROX 15 - all NO YES Received according to tinygs
99112 FOSSASAT-FEROX 17 - all NO YES Received according to tinygs
99097 MDQSAT-1C - all NO YES Received according to tinygs
99096 MDQSAT-1D - all NO YES Received according to tinygs
RECEIVED
99258 Tomorrow-R2 56959 56958, 56960(unlikely) NO YES No update
Otter Pup 56933 - YES YES Identified, here are the ikhnos results
99079 Transporter 8 Satellite E 56987 56986(unlikely) NO YES No update
OBJECT 23084AJ (Transporter 8 Satellite D) 56964 - YES YES Identified, here are the ikhnos results
99081 Transporter 8 Satellite B 56962 56961(unlikely) NO YES Unknown satellite that seems to follow 56962, received, changed to follow 56962, other possible 56961
RECEPTION STOPPED
99078 Transporter 8 Satellite F 56939 56932-56938, 56940-56944 NO YES No reception since 2023-06-15 11:31, changed to follow 56939, other possible 56932-56938, 56940-56944
99083 Transporter 8 Satellite A 56934 56932, 56933, 56935 NO YES No reception since 2023-06-16 20:57, changed to follow 56934, other possible 56932, 56933, 56935
NOT RECEIVED
99082 Transporter 8 Satellite C - - NO YES Not currently observing, trying to figure out if they are known or unknown satellites
99192 Istanbul 56957 - NO YES Deployed, uses TLE set of its deployer when it was deployed
99101 Outpost Mission 0 56957 - NO YES Deployed, uses TLE set of its deployer when it was deployed
99113 FOSSASAT-FEROX 16 - - NO YES
99352 URESAT-1 56957 - NO YES Deployed, uses TLE set of its deployer when it was deployed
99095 Pleiades-Squared - - NO YES
99104 QPS-SAR-6 - - NO YES
99106 GREGOIRE - - NO YES
99109 XVI - - NO YES
99110 Droid.001 - - NO YES
99107 AFR-1 - - NO YES
99105 Orbiter SN3 - - NO YES
99111 EIVE - - NO YES
99102 Winnebago-1 - - NO YES
99108 MuSat-1 - - NO YES
99260 Blackjack Aces-2 - - NO YES
99262 Blackjack Aces-4 - - NO YES
99259 Blackjack Aces-1 - - NO YES
99261 Blackjack Aces-3 - - NO YES
99099 SATLLA-2I 56957 - NO YES Deployed, uses TLE set of its deployer when it was deployed
NOT IN DB
- AII-DELTA - - NO YES
- GEISAT - - NO YES
- Ayris-1 - - NO YES
- Ayris-2 - - NO YES
- LEMUR 2 EMBRIONOVIS - - NO YES
- MISR-A - - NO YES
- LEMUR 2 NAZIYAH - - NO YES
- LEMUR 2 AADAM-ALIYAH - - NO YES
- Swarm Spacebees - - NO YES
- MISR-B - - NO YES
- Tiger-4 - - NO YES
- NewSat 40 - - NO YES
- NewSat 41 - - NO YES
- NewSat 43 - - NO YES
- NewSat 42 - - NO YES
- 1st ICEYE satellite - - NO YES
- 2nd ICEYE satellite - - NO YES
- 3rd ICEYE satellite - - NO YES
- HotSat-1 - - NO YES
- 4th ICEYE satellite - - NO YES
- Skykraft-3 - - NO YES
- GHOSt-3 - - NO YES
- Runner-1 - - NO YES
- EpicHyper2/Dragonette 2 - - NO YES Waiting deployment from ION SCV-011
Can you update it in the scheduler as well? I just re-schedule a few for our station (2380, see e.g. SatNOGS Network - Observation 7759809), but still uses the previous one with a different mean motion (15.13242215 c/d instead of 15.13266641 c/d).
I did and also fix my copy paste error, so now you can see the updated TLE set in the post.
I see, thanks! So does it mean that the mean motion is not changed since yesterday?
Unfortunately the fit wasn’t done for mean motion, this usually needs more than one observations to have better accuracy and in this case the fit was done on one observation. Let’s see if the next hours space-track.org will publish TLE/objects from the ION deployment, if not we can try to fit more than one observations and get mean motion also updated.
EDIT: feel free to join the #satnogs matrix channel where we discuss all these matters
would it help if we make an i/q recording from this? SatNOGS Network - Observation 7760476. The previous high pass (SatNOGS Network - Observation 7752590) was rather good, but there is no i/q saved :confused:
It may help but not sure if it will need some extra process, we perform the fit by using strf tools for observations and fit.
Based on latest @PE0SAT TLE set and some network observations I’ve managed to generate a little better TLE set with mean motion also fitted:
MRC-100
1 99182U          23175.20000000  .00000000  00000-0  00000-0 0    02
2 99182  97.5127 291.3583 0014340 171.7329 273.5804 15.11776647    09
sites.txt (2.6 KB)
mrc_175.dat (2.9 KB)
it is interesting that the mean motion decreased quite prominently
I think it is normal given that for the initial TLE set we used the one of the ION deployer which has different size and mass.
Looks good: SatNOGS Network - Observation 7761089, SatNOGS Network - Observation 7761090
