SpaceX F9 Transporter-8 - 2023-06-12 21:35 UTC
Info from spaceflightforum:
EDIT:
COMMERCIAL UHF
99258 GHOST-3 400.5 MHz Directly
99098 Otter Pup 400.5 MHz Orbiter SN3
99081 Tomorrow R2 400.5 MHz Former unknown satellite with the name “Transporter 8 Satellite B” Directly
99082 Transporter 8 Satellite C 400.503 MHz Merged with GHOST-3 Directly
99079 AII-DELTA 401.05 MHz Former unknown satellite with the name “Transporter 8 Satellite E” Unknown
99078 Transporter 8 Satellite F 401.05 MHz Unknown Satellite, possible match is AYRIS-2 according to the pre-launch TLE from Celestrak Unknown
99192 Istanbul 401.075 MHz ION SCV-011 - Alba Orbital Cluster 7
99083 GEISAT PRECURSOR 401.4 MHz Former unknown satellite with the name “Transporter 8 Satellite E” Directly
99103 ION SCV-011 401.415 MHz Directly
99101 Outpost Mission 0 401.500 MHz ION SCV-011
99115 FOSSASAT-FEROX 14 - PlatziSat-1 401.7 MHz Directly
99114 FOSSASAT-FEROX 15 401.7 MHz Directly
99113 FOSSASAT-FEROX 16 401.7 MHz Directly
99112 FOSSASAT-FEROX 17 401.7 MHz Directly
AMATEUR UHF
99187 ROM-2 436.235 MHz IARU Coordinated ION SCV-011 - Alba Orbital Cluster 7
99080 AFR-1 436.630 MHz Not IARU Coordinated Unknown Satellite, Former unknown satellite with the name “Transporter 8 Satellite D” Directly
99182 MRC-100 436.72 MHz IARU Coordinated ION SCV-011 - Alba Orbital Cluster 7
99352 URESAT-1 436.888 MHz IARU Coordinated ION SCV-011 - Alba Orbital Cluster 7
99097 MDQSAT-1C 436.9 MHz Not IARU Coordinated Orbiter SN3
99096 MDQSAT-1D 436.9 MHz Not IARU Coordinated Orbiter SN3
99095 Pleiades-Squared 437.4 MHz IARU Coordinated Orbiter SN3
99100 SpeiSat 437.5 MHz Not IARU Coordinated ION SCV-011
99097 MDQSAT-1C 437.8 MHz Not IARU Coordinated Orbiter SN3
99096 MDQSAT-1D 437.8 MHz Not IARU Coordinated Orbiter SN3
OTHER FREQUENCIES (UHF, S-Band, X-Band)
99104 QPS-SAR-6 924.3 MHz Directly
99106 GREGOIRE 2223 MHz Directly
99109 XVI 2230.3 MHz Directly
99110 Droid.001 2245 MHz Directly
99107 AFR-1 2245 MHz Directly
99105 Orbiter SN3 2245 MHz Directly
99104 QPS-SAR-6 2254 MHz Directly
99111 EIVE 2263.9 MHz Directly
99102 Winnebago-1 2272.5 MHz Directly
99104 QPS-SAR-6 8174.5 MHz Directly
99107 AFR-1 8210 MHz Directly
99110 Droid.001 8212.5 MHz Directly
99106 GREGOIRE 8320 MHz Directly
99108 MuSat-1 8387.5 MHz Directly
NO FREQUENCIES
- Ayris-1 Directly
- Ayris-2 Directly
- LEMUR 2 EMBRIONOVIS Directly
- MISR-A Directly
- LEMUR 2 NAZIYAH Directly
- LEMUR 2 AADAM-ALIYAH Directly
- Swarm Spacebees Directly
- MISR-B Directly
- Tiger-4 Directly
- NewSat 40 Directly
- NewSat 41 Directly
- NewSat 43 Directly
- NewSat 42 Directly
- 1st ICEYE satellite Directly
- 2nd ICEYE satellite Directly
- 3rd ICEYE satellite Directly
- HotSat-1 Directly
- 4th ICEYE satellite Directly
- Skykraft-3 Directly
99260 Blackjack Aces-2 Directly
- Runner-1 Directly
99262 Blackjack Aces-4 Directly
99259 Blackjack Aces-1 Directly
99261 Blackjack Aces-3 Directly
- EpicHyper2/Dragonette 2 ION SCV-011
99099 SATLLA-2I ION SCV-011 - Alba Orbital Cluster 7
Latest Update: 2023-08-06 22:15 UTC
Launch Schedule from SpaceX:
Temporary NORAD ID Satellite Frequency Notes Deployer
Amatuer UHF
xxxxx Pleades -Squared 437.400 MHz IARU Coordinated Launcher Orbiter SN3
xxxxx ROM-2 436.235 MHz IARU Coordinated Directly?
Other
xxxxx EIVE 71-76 GHz info Exolaunch
xxxxx Outpost MIssion 0 400-401 MHz notes D-Orbit ION
xxxxx DROID.001 X & S-band notes Exolaunch
xxxxx SpeiSat (“Guardian of Hope”) 437.5MHz notes D-Orbit ION
xxxxx Otter Pup 400.50 MHz info Launcher Orbiter SN3
xxxxx MuSat-1 X-Band info
Here is a nice picture of satellite stack:
https://twitter.com/GewoonLukas_/status/1667244268371492865
The new generation of FOSSA ‘FEROX’ satellites will downlink on 401.700 using LoRa, just like the current FOSSA sats. Here is a pre-launch test decode that shows the parameters:
https://tinygs.com/packet/f0dbe06e-7cc3-47a7-9853-741ca241a9bd
MRC-100 is already in SatNogs & will use a variety of baud rates that do not match what we typically see. So, this should be interesting:
https://db.satnogs.org/satellite/PDTE-7914-8172-6131-7029#transmitters
… regarding the software decode options, a very extensive install is suggested on the Project Team’s website that would really only be suitable for a blank, dedicated system. Last night I posted a tweet showing that other options are already in-place and are very easy to use:
https://twitter.com/scott23192/status/1668058355166740481
As celestrak hasn’t posted yet any preliminary TLE as it does usually for spacex missions, @cgbsat generated a preliminary TLE set that will be used if we don’t find something better:
1 99999U          23163.88819444  .00000000  00000-0  50000-4 0    08
2 99999  97.4000 276.0000 0001454   0.0000 125.0000 15.21937999    09
This is based on 500 km @ 97.4 deg for 21:19UTC launch time
I’m still gathering info and I’ll add satellites in DB in the next hours and I’ll update the first post accordingly.
TinyGS has now posted info on all of the known LoRa sats in this launch. So, whether setup to decode them or not, watch for very quick, wide-band downlinks for the following when monitoring 70cm:
(2) MDQSAT-1C/1D 436.900 125kHz
(4) FOSSASat FEROX 14/15/16/17 401.700 125 kHz
(1) Pleiades-Squared 437.400 125 kHz
(1) SATLLA-2I (freq & BW unknown)
There are pre launch TLE available on Celestrak.
FOSSASAT FEROX
1 70301C 23084A   23163.92985035 -.00020562  00000+0 -12243-2 0    07
2 70301  97.5025 276.5311 0007492 260.2794  99.1878 15.11286844    11
AII-DELTA
1 70302C 23084B   23163.93022303 -.00019691  00000+0 -11024-2 0    06
2 70302  97.5005 276.5314 0012957 213.2926 148.2065 15.13452566    12
GEISAT
1 70303C 23084C   23163.93037118 -.00024307  00000+0 -14392-2 0    08
2 70303  97.5063 276.5317 0008142 254.7716 107.5217 15.11485273    14
AYRIS-1
1 70304C 23084D   23163.93049039 -.00020839  00000+0 -11650-2 0    04
2 70304  97.5034 276.5317 0013492 215.2510 147.6966 15.13497688    12
EIVE
1 70305C 23084E   23163.93062234 -.00021893  00000+0 -12973-2 0    07
2 70305  97.5039 276.5318 0007591 254.3003 109.3646 15.11459822    19
AYRIS-2
1 70306C 23084F   23163.93067211 -.00021036  00000+0 -11764-2 0    04
2 70306  97.5072 276.5321 0013822 217.9473 145.9817 15.13480909    19
LEMUR-2-EMBRIONOVIS
1 70307C 23084G   23163.93079132 -.00022651  00000+0 -12801-2 0    07
2 70307  97.5109 276.5325 0012941 224.4275 140.1429 15.13116712    13
MISR-A-1
1 70308C 23084H   23163.93088854 -.00021722  00000+0 -12296-2 0    05
2 70308  97.4992 276.5316 0011586 217.2220 147.9009 15.13073796    10
LEMUR-2-NAZIYAH
1 70309C 23084J   23163.93172998 -.00022222  00000+0 -12531-2 0    07
2 70309  97.5015 276.5324 0012458 218.3927 151.3039 15.13201721    15
LEMUR-2-AADAM-ALIYAH
1 70310C 23084K   23163.93185729 -.00022305  00000+0 -12546-2 0    03
2 70310  97.5035 276.5329 0012979 219.1389 151.2465 15.13286088    14
SPACEBEE-168 TO -179
1 70311C 23084L   23163.93209803 -.00025446  00000+0 -14328-2 0    03
2 70311  97.5073 276.5338 0013198 222.3570 149.3307 15.13246938    12
DROID.001
1 70312C 23084M   23163.93221262 -.00023934  00000+0 -13635-2 0    07
2 70312  97.5030 276.5330 0011314 223.6504 148.6694 15.12848614    16
AFRL-XVI
1 70313C 23084N   23163.93239317 -.00026237  00000+0 -15334-2 0    05
2 70313  97.5079 276.5343 0008822 241.9568 131.3356 15.11953300    19
MISR-B-2
1 70314C 23084P   23163.93254016 -.00024067  00000+0 -14087-2 0    02
2 70314  97.5061 276.5341 0008388 241.5543 132.5415 15.11899435    12
LAYAN-23
1 70315C 23084Q   23163.93267558 -.00021937  00000+0 -12827-2 0    01
2 70315  97.5045 276.5338 0008280 239.2722 135.5636 15.11937053    12
NUSAT-40
1 70316C 23084R   23163.93284109 -.00022713  00000+0 -13239-2 0    04
2 70316  97.5035 276.5337 0008505 235.9068 139.8316 15.12049795    17
NUSAT-41
1 70317C 23084S   23163.93299965 -.00022801  00000+0 -13256-2 0    08
2 70317  97.5022 276.5334 0008670 232.8789 143.7249 15.12141711    10
NUSAT-43
1 70318C 23084T   23163.93398113 -.00023336  00000+0 -13252-2 0    04
2 70318  97.5061 276.5357 0012146 226.4247 155.5117 15.12953751    10
NUSAT-42
1 70319C 23084U   23163.93410845 -.00023477  00000+0 -13356-2 0    03
2 70319  97.5071 276.5362 0011973 227.8895 154.7375 15.12889684    19
MUSAT1
1 70320C 23084V   23163.93443368 -.00018280  00000+0 -10391-2 0    03
2 70320  97.5040 276.5353 0011888 225.4034 158.9997 15.12919628    19
AFR-1
1 70321C 23084W   23163.93538738 -.00028203  00000+0 -16068-2 0    03
2 70321  97.5058 276.5371 0011750 228.3103 161.2782 15.12844069    11
TOMORROW-R2
1 70322C 23084X   23163.93602280 -.00021663  00000+0 -12363-2 0    05
2 70322  97.5047 276.5372 0011450 228.1293 164.9191 15.12783255    19
GREGOIRE
1 70323C 23084Y   23163.93660498 -.00027806  00000+0 -16131-2 0    03
2 70323  97.5060 276.5387 0009123 233.5687 162.6443 15.12216275    10
X26
1 70324C 23084Z   23163.93729248 -.00028890  00000+0 -16493-2 0    08
2 70324  97.5035 276.5374 0011400 227.7383 172.2214 15.12772624    16
ORBITER SN3
1 70325C 23084AA  23163.93805868 -.00030390  00000+0 -17659-2 0    05
2 70325  97.5049 276.5394 0008783 231.7495 172.3755 15.12160136    13
X25
1 70326C 23084AB  23163.93881447 -.00030461  00000+0 -17369-2 0    00
2 70326  97.5051 276.5404 0011642 230.6197 177.6173 15.12813709    17
X23
1 70327C 23084AC  23163.94008646 -.00032513  00000+0 -18851-2 0    01
2 70327  97.5053 276.5421 0009088 231.2164 183.9406 15.12239118    16
MWIR PATHFINDER
1 70328C 23084AD  23163.94082604 -.00033529  00000+0 -19281-2 0    04
2 70328  97.5054 276.5432 0010318 232.1127 187.0678 15.12524374    14
X30
1 70329C 23084AE  23163.94160845 -.00033889  00000+0 -19668-2 0    07
2 70329  97.5040 276.5416 0009028 227.4751 195.9679 15.12205039    11
SKYKRAFT-3
1 70330C 23084AF  23163.94186076 -.00034771  00000+0 -20070-2 0    03
2 70330  97.5049 276.5437 0009751 230.8805 193.9314 15.12395314    16
GHOST-3
1 70331C 23084AG  23163.94234803 -.00033268  00000+0 -19041-2 0    02
2 70331  97.5046 276.5437 0011008 232.1221 195.3424 15.12687128    14
BLACKJACK ACES-2
1 70332C 23084AH  23163.94309919 -.00037486  00000+0 -21527-2 0    02
2 70332  97.5038 276.5420 0010654 229.3316 202.2247 15.12571126    18
QPS-SAR-6 AMATERU-III
1 70333C 23084AJ  23163.94340243 -.00035410  00000+0 -20462-2 0    00
2 70333  97.5046 276.5449 0009599 229.7225 203.4788 15.12356298    12
RUNNER-1
1 70334C 23084AK  23163.94363623 -.00036900  00000+0 -21235-2 0    02
2 70334  97.5037 276.5418 0010416 228.1346 206.3452 15.12497819    11
ION SCV-011
1 70335C 23084AL  23163.94393137 -.00037659  00000+0 -21577-2 0    07
2 70335  97.5039 276.5429 0010966 230.4993 205.5848 15.12651467    11
BLACKJACK ACES-4
1 70336C 23084AM  23163.94420451 -.00038794  00000+0 -22363-2 0    03
2 70336  97.5040 276.5432 0010137 228.2983 209.2720 15.12440128    12
BLACKJACK ACES-1
1 70337C 23084AN  23163.94482257 -.00039543  00000+0 -22689-2 0    00
2 70337  97.5046 276.5471 0010491 233.1505 207.7764 15.12605126    12
WINNEBAGO-1
1 70338C 23084AP  23163.94557373 -.00038722  00000+0 -22150-2 0    04
2 70338  97.5042 276.5453 0011057 232.6798 212.3389 15.12708705    18
BLACKJACK ACES-3
1 70339C 23084AQ  23163.94708299 -.00042320  00000+0 -24512-2 0    03
2 70339  97.5043 276.5478 0009466 226.8281 226.4008 15.12276849    13
Live T8 launch coverage via SpaceX
I guess that this will be a pocketqube so it will be inside the alba orbital deployer.
The frequency probably is at 437.25 MHz as the previous ones, if this is it then it is uncoordinated.
For now I’ve added in DB those satellites that will be directly deployed and I’ve updated the first post with a satellite tables grouped by frequency.
I’m going to add later today the rest, that are inside the deployers, in DB and in the first post.
New launch time at 2023-06-12 21:35 UTC
https://twitter.com/SpaceX/status/1668361253033766914
Preliminary TLE from celestrak, move to fit the new launch time:
FOSSASAT FEROX
1 70301U 14900A   23163.94096146  .00000000  00000-0 -12243-2 0    07
2 70301  97.5025 280.5421 0007492 260.2794  99.1878 15.11286844    07
AII-DELTA
1 70302U 14900A   23163.94133414  .00000000  00000-0 -11024-2 0    04
2 70302  97.5005 280.5424 0012957 213.2926 148.2065 15.13452566    08
GEISAT
1 70303U 14900A   23163.94148229  .00000000  00000-0 -14392-2 0    06
2 70303  97.5063 280.5427 0008142 254.7716 107.5217 15.11485273    00
AYRIS-1
1 70304U 14900A   23163.94160150  .00000000  00000-0 -11650-2 0    08
2 70304  97.5034 280.5427 0013492 215.2510 147.6966 15.13497688    08
EIVE
1 70305U 14900A   23163.94173345  .00000000  00000-0 -12973-2 0    08
2 70305  97.5039 280.5428 0007591 254.3003 109.3646 15.11459822    05
AYRIS-2
1 70306U 14900A   23163.94178322  .00000000  00000-0 -11764-2 0    06
2 70306  97.5072 280.5431 0013822 217.9473 145.9817 15.13480909    05
LEMUR-2-EMBRIONOVIS
1 70307U 14900A   23163.94190243  .00000000  00000-0 -12801-2 0    06
2 70307  97.5109 280.5435 0012941 224.4275 140.1429 15.13116712    09
MISR-A-1
1 70308U 14900A   23163.94199965  .00000000  00000-0 -12296-2 0    05
2 70308  97.4992 280.5426 0011586 217.2220 147.9009 15.13073796    06
LEMUR-2-NAZIYAH
1 70309U 14900A   23163.94284109  .00000000  00000-0 -12531-2 0    03
2 70309  97.5015 280.5434 0012458 218.3927 151.3039 15.13201721    01
1 70310U 14900A   23163.94296840  .00000000  00000-0 -12546-2 0    06
2 70310  97.5035 280.5439 0012979 219.1389 151.2465 15.13286088    00
1 70311U 14900A   23163.94320914  .00000000  00000-0 -14328-2 0    07
2 70311  97.5073 280.5448 0013198 222.3570 149.3307 15.13246938    08
DROID.001
1 70312U 14900A   23163.94332373  .00000000  00000-0 -13635-2 0    00
2 70312  97.5030 280.5440 0011314 223.6504 148.6694 15.12848614    02
AFRL-XVI
1 70313U 14900A   23163.94350428  .00000000  00000-0 -15334-2 0    00
2 70313  97.5079 280.5453 0008822 241.9568 131.3356 15.11953300    05
MISR-B-2
1 70314U 14900A   23163.94365127  .00000000  00000-0 -14087-2 0    07
2 70314  97.5061 280.5451 0008388 241.5543 132.5415 15.11899435    08
LAYAN-23
1 70315U 14900A   23163.94378669  .00000000  00000-0 -12827-2 0    03
2 70315  97.5045 280.5448 0008280 239.2722 135.5636 15.11937053    08
NUSAT-40
1 70316U 14900A   23163.94395220  .00000000  00000-0 -13239-2 0    04
2 70316  97.5035 280.5447 0008505 235.9068 139.8316 15.12049795    03
NUSAT-41
1 70317U 14900A   23163.94411076  .00000000  00000-0 -13256-2 0    02
2 70317  97.5022 280.5444 0008670 232.8789 143.7249 15.12141711    06
NUSAT-43
1 70318U 14900A   23163.94509224  .00000000  00000-0 -13252-2 0    02
2 70318  97.5061 280.5467 0012146 226.4247 155.5117 15.12953751    06
NUSAT-42
1 70319U 14900A   23163.94521956  .00000000  00000-0 -13356-2 0    04
2 70319  97.5071 280.5472 0011973 227.8895 154.7375 15.12889684    05
MUSAT1
1 70320U 14900A   23163.94554479  .00000000  00000-0 -10391-2 0    08
2 70320  97.5040 280.5463 0011888 225.4034 158.9997 15.12919628    05
AFR-1
1 70321U 14900A   23163.94649849  .00000000  00000-0 -16068-2 0    02
2 70321  97.5058 280.5481 0011750 228.3103 161.2782 15.12844069    07
TOMORROW-R2
1 70322U 14900A   23163.94713391  .00000000  00000-0 -12363-2 0    01
2 70322  97.5047 280.5482 0011450 228.1293 164.9191 15.12783255    05
GREGOIRE
1 70323U 14900A   23163.94771609  .00000000  00000-0 -16131-2 0    05
2 70323  97.5060 280.5497 0009123 233.5687 162.6443 15.12216275    06
X26
1 70324U 14900A   23163.94840359  .00000000  00000-0 -16493-2 0    06
2 70324  97.5035 280.5484 0011400 227.7383 172.2214 15.12772624    02
ORBITER SN3
1 70325U 14900A   23163.94916979  .00000000  00000-0 -17659-2 0    04
2 70325  97.5049 280.5504 0008783 231.7495 172.3755 15.12160136    00
X25
1 70326U 14900A   23163.94992558  .00000000  00000-0 -17369-2 0    00
2 70326  97.5051 280.5514 0011642 230.6197 177.6173 15.12813709    03
X23
1 70327U 14900A   23163.95119757  .00000000  00000-0 -18851-2 0    01
2 70327  97.5053 280.5531 0009088 231.2164 183.9406 15.12239118    02
MWIR PATHFINDER
1 70328U 14900A   23163.95193715  .00000000  00000-0 -19281-2 0    06
2 70328  97.5054 280.5542 0010318 232.1127 187.0678 15.12524374    00
X30
1 70329U 14900A   23163.95271956  .00000000  00000-0 -19668-2 0    00
2 70329  97.5040 280.5526 0009028 227.4751 195.9679 15.12205039    07
SKYKRAFT-3
1 70330U 14900A   23163.95297187  .00000000  00000-0 -20070-2 0    05
2 70330  97.5049 280.5547 0009751 230.8805 193.9314 15.12395314    02
GHOST-3
1 70331U 14900A   23163.95345914  .00000000  00000-0 -19041-2 0    04
2 70331  97.5046 280.5547 0011008 232.1221 195.3424 15.12687128    00
BLACKJACK ACES-2
1 70332U 14900A   23163.95421030  .00000000  00000-0 -21527-2 0    01
2 70332  97.5038 280.5530 0010654 229.3316 202.2247 15.12571126    04
1 70333U 14900A   23163.95451354  .00000000  00000-0 -20462-2 0    01
2 70333  97.5046 280.5559 0009599 229.7225 203.4788 15.12356298    08
RUNNER-1
1 70334U 14900A   23163.95474734  .00000000  00000-0 -21235-2 0    08
2 70334  97.5037 280.5528 0010416 228.1346 206.3452 15.12497819    07
ION SCV-011
1 70335U 14900A   23163.95504248  .00000000  00000-0 -21577-2 0    02
2 70335  97.5039 280.5539 0010966 230.4993 205.5848 15.12651467    07
BLACKJACK ACES-4
1 70336U 14900A   23163.95531562  .00000000  00000-0 -22363-2 0    06
2 70336  97.5040 280.5542 0010137 228.2983 209.2720 15.12440128    08
BLACKJACK ACES-1
1 70337U 14900A   23163.95593368  .00000000  00000-0 -22689-2 0    00
2 70337  97.5046 280.5581 0010491 233.1505 207.7764 15.12605126    08
WINNEBAGO-1
1 70338U 14900A   23163.95668484  .00000000  00000-0 -22150-2 0    06
2 70338  97.5042 280.5563 0011057 232.6798 212.3389 15.12708705    04
BLACKJACK ACES-3
1 70339U 14900A   23163.95819410  .00000000  00000-0 -24512-2 0    08
2 70339  97.5043 280.5588 0009466 226.8281 226.4008 15.12276849    09
New pre-launch TLE from celestrak:
FOSSASAT FEROX
1 70301C 23084A   23163.94096146 -.00020529  00000+0 -12224-2 0    07
2 70301  97.5025 280.5421 0007492 260.2801  99.1871 15.11286848    14
AII-DELTA
1 70302C 23084B   23163.94133414 -.00019652  00000+0 -11003-2 0    07
2 70302  97.5004 280.5423 0012957 213.2926 148.2065 15.13452571    13
GEISAT
1 70303C 23084C   23163.94148229 -.00024289  00000+0 -14382-2 0    03
2 70303  97.5063 280.5426 0008142 254.7719 107.5214 15.11485278    15
AYRIS-1
1 70304C 23084D   23163.94160151 -.00020805  00000+0 -11631-2 0    06
2 70304  97.5034 280.5426 0013491 215.2510 147.6965 15.13497693    12
EIVE
1 70305C 23084E   23163.94173345 -.00021864  00000+0 -12956-2 0    03
2 70305  97.5038 280.5427 0007591 254.3008 109.3641 15.11459827    19
AYRIS-2
1 70306C 23084F   23163.94178322 -.00021001  00000+0 -11745-2 0    02
2 70306  97.5072 280.5430 0013822 217.9473 145.9816 15.13480914    10
LEMUR-2-EMBRIONOVIS
1 70307C 23084G   23163.94190243 -.00022624  00000+0 -12786-2 0    07
2 70307  97.5109 280.5435 0012941 224.4275 140.1428 15.13116717    14
MISR-A-1
1 70308C 23084H   23163.94199965 -.00021692  00000+0 -12279-2 0    09
2 70308  97.4992 280.5426 0011585 217.2221 147.9008 15.13073801    13
LEMUR-2-NAZIYAH
1 70309C 23084J   23163.94284109 -.00022190  00000+0 -12513-2 0    00
2 70309  97.5015 280.5433 0012458 218.3928 151.3038 15.13201728    18
1 70310C 23084K   23163.94296840 -.00022273  00000+0 -12528-2 0    05
2 70310  97.5035 280.5438 0012979 219.1390 151.2464 15.13286094    18
1 70311C 23084L   23163.94320914 -.00025427  00000+0 -14318-2 0    09
2 70311  97.5073 280.5448 0013198 222.3571 149.3307 15.13246944    17
DROID.001
1 70312C 23084M   23163.94332373 -.00023909  00000+0 -13620-2 0    00
2 70312  97.5030 280.5440 0011314 223.6505 148.6693 15.12848620    10
AFRL-XVI
1 70313C 23084N   23163.94350428 -.00026222  00000+0 -15324-2 0    06
2 70313  97.5079 280.5453 0008822 241.9570 131.3354 15.11953307    14
MISR-B-2
1 70314C 23084P   23163.94365127 -.00024041  00000+0 -14072-2 0    05
2 70314  97.5061 280.5450 0008388 241.5547 132.5412 15.11899442    17
LAYAN-23
1 70315C 23084Q   23163.94378669 -.00021901  00000+0 -12806-2 0    06
2 70315  97.5045 280.5448 0008280 239.2726 135.5632 15.11937060    17
NUSAT-40
1 70316C 23084R   23163.94395220 -.00022680  00000+0 -13219-2 0    03
2 70316  97.5035 280.5446 0008504 235.9072 139.8313 15.12049802    13
NUSAT-41
1 70317C 23084S   23163.94411076 -.00022768  00000+0 -13237-2 0    09
2 70317  97.5022 280.5444 0008670 232.8792 143.7246 15.12141719    16
NUSAT-43
1 70318C 23084T   23163.94509225 -.00023301  00000+0 -13232-2 0    03
2 70318  97.5061 280.5466 0012146 226.4249 155.5115 15.12953760    16
NUSAT-42
1 70319C 23084U   23163.94521956 -.00023441  00000+0 -13336-2 0    09
2 70319  97.5071 280.5472 0011973 227.8898 154.7373 15.12889694    18
MUSAT1
1 70320C 23084V   23163.94554479 -.00018219  00000+0 -10356-2 0    03
2 70320  97.5040 280.5462 0011888 225.4038 158.9993 15.12919639    17
AFR-1
1 70321C 23084W   23163.94649850 -.00028185  00000+0 -16057-2 0    09
2 70321  97.5058 280.5481 0011750 228.3104 161.2781 15.12844080    11
TOMORROW-R2
1 70322C 23084X   23163.94713391 -.00021611  00000+0 -12333-2 0    02
2 70322  97.5047 280.5481 0011450 228.1297 164.9187 15.12783269    19
GREGOIRE
1 70323C 23084Y   23163.94771609 -.00027781  00000+0 -16117-2 0    07
2 70323  97.5060 280.5496 0009123 233.5690 162.6441 15.12216289    13
X26
1 70324C 23084Z   23163.94840359 -.00028866  00000+0 -16480-2 0    05
2 70324  97.5035 280.5483 0011400 227.7385 172.2212 15.12772639    18
ORBITER SN3
1 70325C 23084AA  23163.94916979 -.00030369  00000+0 -17647-2 0    05
2 70325  97.5049 280.5504 0008783 231.7498 172.3752 15.12160152    19
X25
1 70326C 23084AB  23163.94992558 -.00030436  00000+0 -17355-2 0    04
2 70326  97.5051 280.5513 0011642 230.6199 177.6170 15.12813727    12
X23
1 70327C 23084AC  23163.95119757 -.00032492  00000+0 -18839-2 0    00
2 70327  97.5053 280.5531 0009088 231.2166 183.9403 15.12239138    14
MWIR PATHFINDER
1 70328C 23084AD  23163.95193715 -.00033508  00000+0 -19269-2 0    04
2 70328  97.5054 280.5542 0010318 232.1130 187.0675 15.12524394    14
X30
1 70329C 23084AE  23163.95271956 -.00033866  00000+0 -19654-2 0    04
2 70329  97.5040 280.5525 0009028 227.4754 195.9675 15.12205061    11
SKYKRAFT-3
1 70330C 23084AF  23163.95297188 -.00034751  00000+0 -20058-2 0    05
2 70330  97.5049 280.5547 0009751 230.8808 193.9311 15.12395336    17
GHOST-3
1 70331C 23084AG  23163.95345914 -.00033237  00000+0 -19023-2 0    05
2 70331  97.5046 280.5546 0011008 232.1224 195.3420 15.12687151    15
BLACKJACK ACES-2
1 70332C 23084AH  23163.95421030 -.00037471  00000+0 -21519-2 0    07
2 70332  97.5038 280.5530 0010654 229.3319 202.2245 15.12571149    11
1 70333C 23084AJ  23163.95451354 -.00035383  00000+0 -20447-2 0    09
2 70333  97.5046 280.5558 0009599 229.7228 203.4784 15.12356322    15
RUNNER-1
1 70334C 23084AK  23163.95474734 -.00036879  00000+0 -21223-2 0    01
2 70334  97.5036 280.5527 0010416 228.1348 206.3449 15.12497843    11
ION SCV-011
1 70335C 23084AL  23163.95504248 -.00037640  00000+0 -21566-2 0    03
2 70335  97.5039 280.5538 0010966 230.4996 205.5845 15.12651490    13
BLACKJACK ACES-4
1 70336C 23084AM  23163.95531563 -.00038779  00000+0 -22354-2 0    04
2 70336  97.5039 280.5541 0010137 228.2985 209.2717 15.12440151    10
BLACKJACK ACES-1
1 70337C 23084AN  23163.95593368 -.00039527  00000+0 -22680-2 0    00
2 70337  97.5046 280.5580 0010492 233.1508 207.7762 15.12605149    15
WINNEBAGO-1
1 70338C 23084AP  23163.95668484 -.00038698  00000+0 -22137-2 0    08
2 70338  97.5042 280.5562 0011057 232.6801 212.3386 15.12708729    12
BLACKJACK ACES-3
1 70339C 23084AQ  23163.95819410 -.00042305  00000+0 -24503-2 0    05
2 70339  97.5043 280.5587 0009466 226.8284 226.4005 15.12276872    15
The first post is updated now with the satellites that are going to be deployed from ION SCV-011 and Orbiter SN3 deployers.
New update on TLE from Celestrak:
FOSSASAT FEROX
1 70301C 23084A   23163.94096086 -.00020209  00000+0 -11858-2 0    07
2 70301  97.5092 280.5429 0008180 227.4050 132.0661 15.11811318    12
AII-DELTA
1 70302C 23084B   23163.94133354 -.00019299  00000+0 -10635-2 0    07
2 70302  97.5070 280.5432 0016146 200.7387 160.7654 15.13976359    10
GEISAT
1 70303C 23084C   23163.94148169 -.00024099  00000+0 -14059-2 0    06
2 70303  97.5129 280.5435 0009136 225.3603 136.9378 15.12012053    13
AYRIS-1
1 70304C 23084D   23163.94160090 -.00020490  00000+0 -11274-2 0    01
2 70304  97.5100 280.5435 0016580 202.6669 160.2862 15.14024239    13
EIVE
1 70305C 23084E   23163.94173285 -.00021558  00000+0 -12586-2 0    05
2 70305  97.5103 280.5436 0008657 222.8503 140.8206 15.11988779    16
AYRIS-2
1 70306C 23084F   23163.94178262 -.00020694  00000+0 -11394-2 0    02
2 70306  97.5138 280.5439 0016734 205.2381 158.6964 15.13998005    15
LEMUR-2-EMBRIONOVIS
1 70307C 23084G   23163.94190183 -.00022368  00000+0 -12444-2 0    06
2 70307  97.5174 280.5443 0015550 209.5360 155.0404 15.13644757    12
MISR-A-1
1 70308C 23084H   23163.94199905 -.00021389  00000+0 -11917-2 0    04
2 70308  97.5058 280.5434 0014650 202.5928 162.5362 15.13604964    19
LEMUR-2-NAZIYAH
1 70309C 23084J   23163.94284049 -.00021885  00000+0 -12148-2 0    07
2 70309  97.5080 280.5442 0015417 204.3685 165.3358 15.13728669    11
1 70310C 23084K   23163.94296780 -.00021969  00000+0 -12165-2 0    06
2 70310  97.5099 280.5446 0015868 205.3936 164.9997 15.13810205    19
1 70311C 23084L   23163.94320854 -.00025245  00000+0 -13994-2 0    09
2 70311  97.5138 280.5456 0015905 208.1873 163.5088 15.13770651    14
DROID.001
1 70312C 23084M   23163.94332313 -.00023647  00000+0 -13263-2 0    06
2 70312  97.5095 280.5448 0014023 207.2116 165.1170 15.13375543    19
AFRL-XVI
1 70313C 23084N   23163.94350368 -.00026029  00000+0 -14984-2 0    05
2 70313  97.5143 280.5461 0010581 217.1113 156.1902 15.12481830    10
MISR-B-2
1 70314C 23084P   23163.94365067 -.00023750  00000+0 -13693-2 0    02
2 70314  97.5126 280.5459 0010224 215.8603 158.2449 15.12428723    13
LAYAN-23
1 70315C 23084Q   23163.94378609 -.00021517  00000+0 -12393-2 0    04
2 70315  97.5111 280.5456 0010267 213.9579 160.8874 15.12465233    11
NUSAT-40
1 70316C 23084R   23163.94395160 -.00022321  00000+0 -12814-2 0    08
2 70316  97.5100 280.5455 0010677 211.9533 163.7951 15.12578375    12
NUSAT-41
1 70317C 23084S   23163.94411016 -.00022410  00000+0 -12834-2 0    09
2 70317  97.5088 280.5452 0010982 210.1356 166.4785 15.12664193    17
NUSAT-43
1 70318C 23084T   23163.94509164 -.00022954  00000+0 -12835-2 0    06
2 70318  97.5125 280.5475 0014646 210.3458 171.6027 15.13476988    12
NUSAT-42
1 70319C 23084U   23163.94521896 -.00023095  00000+0 -12939-2 0    05
2 70319  97.5136 280.5480 0014392 211.3542 171.2851 15.13412202    14
MUSAT1
1 70320C 23084V   23163.94554419 -.00017641  00000+0 -98728-3 0    05
2 70320  97.5105 280.5471 0014480 209.2411 175.1750 15.13447928    15
AFR-1
1 70321C 23084W   23163.94649789 -.00027975  00000+0 -15690-2 0    08
2 70321  97.5123 280.5489 0014195 211.3644 178.2390 15.13376398    16
TOMORROW-R2
1 70322C 23084X   23163.94713331 -.00021097  00000+0 -11851-2 0    08
2 70322  97.5112 280.5490 0013950 210.9113 182.1530 15.13322978    16
GREGOIRE
1 70323C 23084Y   23163.94771549 -.00027479  00000+0 -15694-2 0    03
2 70323  97.5125 280.5505 0011438 211.4991 184.7311 15.12756918    16
X26
1 70324C 23084Z   23163.94840299 -.00028598  00000+0 -16072-2 0    07
2 70324  97.5101 280.5492 0013909 210.5118 189.4664 15.13307863    17
ORBITER SN3
1 70325C 23084AA  23163.94916919 -.00030105  00000+0 -17221-2 0    05
2 70325  97.5115 280.5512 0011242 209.4974 194.6476 15.12703844    18
X25
1 70326C 23084AB  23163.94992498 -.00030165  00000+0 -16935-2 0    09
2 70326  97.5116 280.5522 0013949 213.0624 195.1959 15.13345580    12
X23
1 70327C 23084AC  23163.95119697 -.00032226  00000+0 -18397-2 0    07
2 70327  97.5118 280.5539 0011524 209.6506 205.5303 15.12774648    19
MWIR PATHFINDER
1 70328C 23084AD  23163.95193655 -.00033258  00000+0 -18831-2 0    03
2 70328  97.5119 280.5551 0012607 212.3935 206.8123 15.13058003    10
X30
1 70329C 23084AE  23163.95271896 -.00033587  00000+0 -19193-2 0    05
2 70329  97.5106 280.5535 0011660 206.8522 216.6175 15.12737087    18
SKYKRAFT-3
1 70330C 23084AF  23163.95297127 -.00034499  00000+0 -19609-2 0    07
2 70330  97.5115 280.5556 0012130 210.5156 214.3235 15.12924472    19
GHOST-3
1 70331C 23084AG  23163.95345854 -.00032909  00000+0 -18552-2 0    09
2 70331  97.5112 280.5556 0013202 213.3597 214.1328 15.13208045    11
BLACKJACK ACES-2
1 70332C 23084AH  23163.95420970 -.00037277  00000+0 -21079-2 0    04
2 70332  97.5104 280.5539 0013061 210.7586 220.8271 15.13099549    14
1 70333C 23084AJ  23163.95451294 -.00035081  00000+0 -19963-2 0    08
2 70333  97.5111 280.5567 0012065 209.3676 223.8639 15.12885454    19
RUNNER-1
1 70334C 23084AK  23163.95474674 -.00036633  00000+0 -20761-2 0    08
2 70334  97.5102 280.5537 0012903 209.3971 225.1133 15.13021649    19
ION SCV-011
1 70335C 23084AL  23163.95504188 -.00037413  00000+0 -21110-2 0    09
2 70335  97.5105 280.5547 0013292 211.9667 224.1487 15.13176142    17
BLACKJACK ACES-4
1 70336C 23084AM  23163.95531502 -.00038581  00000+0 -21898-2 0    00
2 70336  97.5105 280.5549 0012672 209.1174 228.4849 15.12971460    17
BLACKJACK ACES-1
1 70337C 23084AN  23163.95593308 -.00039329  00000+0 -22221-2 0    05
2 70337  97.5111 280.5587 0012721 213.2882 227.6721 15.13135334    17
WINNEBAGO-1
1 70338C 23084AP  23163.95668424 -.00038430  00000+0 -21644-2 0    08
2 70338  97.5108 280.5571 0013287 213.8534 231.2000 15.13242586    14
BLACKJACK ACES-3
1 70339C 23084AQ  23163.95819350 -.00042109  00000+0 -24003-2 0    05
2 70339  97.5108 280.5594 0012181 207.2348 246.0320 15.12825533    19
ION SCV-011 deployer is alive and received:
https://network.satnogs.org/observations/?future=0&good=1&bad=0&unknown=0&failed=0&norad=99103
Hello! This is the Bronco Space team from Cal Poly Pomona with our Pleiades - Squared CubeSat. This sat is a refight of our dead Pleiades - Yearling architecture as we continue to try and create a reliable platform for educational CubeSats.
We are believed to have deployed from the Orbiter SN3 and would like assistance searching for signal from our satellite on 437.4 MHz. Currently we are tracking the prelim TLE from Celestrak for Orbiter SN3:
ORBITER SN3
TLE of ORBITER SN3 are now added to all the satellites it carried. I’ve scheduled observations for these satellites (including Pleiades - Squared).
Pleiades - Squared (RX by N6RFM in Rhode Island) and 3 of the 4 new FOSSA sats have been received w/ good LoRa decodes. (not by me, but tinyGS stations in Japan & Australia.
I was looking for MRC-100 from the U.S. East Coast tonight but my pass elevations were just too low. So, nothing seen (yet).
MRC-100 is in the ION deployer, usually ION deployer deploys its payload after some days.
