K4KDR
November 10, 2024, 2:01pm
122
GNU Radio w/ gr-satellites support for ASRTU-1 doing a fine job via my 2.5-turn helical omni antenna for these telemetry downlinks. Appeared to be a camera image downlink streaming on-command from uplink via N6RFM’s station this morning!
So great that you can receive, decode, & contribute frames from a satellite like this without even needing a rotator or expensive antennas.
kddk
November 10, 2024, 6:46pm
123
Updated TLE for SamSat-Ionosphere:
SamSat-Ionosphere
1 98786U 24315.71205867 .00000000 00000-0 00000-0 0 00002
2 98786 097.5300 180.5889 0023657 264.6068 237.8696 15.23150148000009
Ionosfera-M satellites should transmit beacons at 150 and 400 MHz, then also a data downlink in the 137 MHz band, and possibly in the 1.7 GHz band
fredy
November 12, 2024, 3:44pm
125
New TLE set for Kosar based on the latest observations, not fully accurate as we need more good observations for fitting it:
KOSAR
1 98772U 24317.50000000 .00000000 00000-0 21060-3 0 00
2 98772 97.3828 181.5588 0007069 156.9679 117.2526 15.25048002 04
EDIT:
I’ve also updated the transmitter to 38k4 as this is how they show up in observations (which by the way is similar to another Iranian satellite CHAMRAN-1 (61072) ).
fredy
November 12, 2024, 4:04pm
126
98766 S2.1b Unknown 1 satellite has been merged with 98795 Altair .
Altair transmitters 435.615 MHz and 435.715 MHz currently are inactive. The merged transmitter at 435.215 MHz is active.
sputnix
November 12, 2024, 4:10pm
127
Hello!
There is some information about callsigns/frequencies of SITRO-AIS flock from satellites operators:
Name Callsign Frequency
SITRO-AIS-13 SC3231 401,010
SITRO-AIS-14 SC3232 401,035
SITRO-AIS-15 SC3233 401,055
SITRO-AIS-16 SC3234 401,075
SITRO-AIS-17 SC3235 401,095
SITRO-AIS-18 SC3236 401,115
SITRO-AIS-19 SC3237 401,135
SITRO-AIS-20 SC3238 401,155
SITRO-AIS-21 SC3239 401,175
SITRO-AIS-22 SC2310 401,195
SITRO-AIS-23 SC2311 401,215
SITRO-AIS-24 SC2312 401,235
SITRO-AIS-37 SC2325 401,0025
SITRO-AIS-38 SC2326 401,045
SITRO-AIS-39 SC2327 401,065
SITRO-AIS-40 SC2328 401,085
SITRO-AIS-41 SC2329 401,105
SITRO-AIS-42 SC2330 401,125
SITRO-AIS-43 SC2331 401,145
SITRO-AIS-44 SC2332 401,165
SITRO-AIS-45 SC2333 401,185
SITRO-AIS-46 SC2334 401,205
SITRO-AIS-47 SC2360 401,225
SITRO-AIS-48 SC2370 401,245
All of them use USP 2400.
kddk
November 12, 2024, 6:48pm
128
SamSat-Ionosphere
1 98786U 24317.74832178 .00000000 00000-0 00000-0 0 00008
2 98786 097.3271 182.1693 0016400 238.0336 261.7479 15.23051667000007
geoscan
November 12, 2024, 8:41pm
129
Updated
Colibri-S
1 98794U 24317.58701730 .00000000 00000-0 50000-4 0 07
2 98794 97.4000 182.2064 0002174 211.5622 157.2734 15.24966766 06
TUSUR GO
1 98788U 24317.54000000 .00000000 00000-0 50000-4 0 08
2 98788 97.4000 185.8104 0012126 184.7730 250.3400 15.23901209 07
fredy
November 12, 2024, 9:02pm
130
Thanks for the info!
I’m going to add them in DB in the next hours with some temporary NORAD IDs, If you can also share any TLE set we can use, we can start scheduling observations in Network.
geoscan
November 12, 2024, 9:17pm
131
VIZARD-ion
1 98789U 24317.80190000 .00000000 00000-0 50000-4 0 08
2 98789 97.4000 174.9015 0002766 275.0012 194.8762 15.24799255 04
fredy
November 13, 2024, 12:00am
132
SITRO-AIS satellites are now in DB with their temporary NORAD IDs. First post also updated.
Temporary NORAD ID
Satellite
Frequency
Notes
Deployed
98763
SITRO-AIS-13
401.010 MHz
Directly
98762
SITRO-AIS-14
401.035 MHz
Directly
98761
SITRO-AIS-15
401.055 MHz
Directly
98760
SITRO-AIS-16
401.075 MHz
Directly
98759
SITRO-AIS-17
401.095 MHz
Directly
98758
SITRO-AIS-18
401.115 MHz
Directly
98757
SITRO-AIS-19
401.135 MHz
Directly
98756
SITRO-AIS-20
401.155 MHz
Directly
98755
SITRO-AIS-21
401.175 MHz
Directly
98754
SITRO-AIS-22
401.195 MHz
Directly
98753
SITRO-AIS-23
401.215 MHz
Directly
98752
SITRO-AIS-24
401.235 MHz
Directly
98751
SITRO-AIS-37
401.025 MHz
Directly
98750
SITRO-AIS-38
401.045 MHz
Directly
98749
SITRO-AIS-39
401.065 MHz
Directly
98748
SITRO-AIS-40
401.085 MHz
Directly
98747
SITRO-AIS-41
401.105 MHz
Directly
98746
SITRO-AIS-42
401.125 MHz
Directly
98745
SITRO-AIS-43
401.145 MHz
Directly
98744
SITRO-AIS-44
401.165 MHz
Directly
98743
SITRO-AIS-45
401.185 MHz
Directly
98742
SITRO-AIS-46
401.205 MHz
Directly
98741
SITRO-AIS-47
401.225 MHz
Directly
98740
SITRO-AIS-48
401.245 MHz
Directly
fredy
November 13, 2024, 12:14am
133
I’ve also added the same TLE produced for one of them by @PE0SAT , the TLE may not be accurate for the most of them as they have different orbits:
SITRO-AIS-13
1 98763U 24317.32401620 .00000000 00000-0 50000-4 0 00
2 98763 97.4000 181.9008 0018170 108.8799 265.3057 15.24815270 04
SITRO-AIS-14
1 98762U 24317.32401620 .00000000 00000-0 50000-4 0 09
2 98762 97.4000 181.9008 0018170 108.8799 265.3057 15.24815270 03
SITRO-AIS-15
1 98761U 24317.32401620 .00000000 00000-0 50000-4 0 08
2 98761 97.4000 181.9008 0018170 108.8799 265.3057 15.24815270 02
SITRO-AIS-16
1 98760U 24317.32401620 .00000000 00000-0 50000-4 0 07
2 98760 97.4000 181.9008 0018170 108.8799 265.3057 15.24815270 01
SITRO-AIS-17
1 98759U 24317.32401620 .00000000 00000-0 50000-4 0 05
2 98759 97.4000 181.9008 0018170 108.8799 265.3057 15.24815270 09
SITRO-AIS-18
1 98758U 24317.32401620 .00000000 00000-0 50000-4 0 04
2 98758 97.4000 181.9008 0018170 108.8799 265.3057 15.24815270 08
SITRO-AIS-19
1 98757U 24317.32401620 .00000000 00000-0 50000-4 0 03
2 98757 97.4000 181.9008 0018170 108.8799 265.3057 15.24815270 07
SITRO-AIS-20
1 98756U 24317.32401620 .00000000 00000-0 50000-4 0 02
2 98756 97.4000 181.9008 0018170 108.8799 265.3057 15.24815270 06
SITRO-AIS-21
1 98755U 24317.32401620 .00000000 00000-0 50000-4 0 01
2 98755 97.4000 181.9008 0018170 108.8799 265.3057 15.24815270 05
SITRO-AIS-22
1 98754U 24317.32401620 .00000000 00000-0 50000-4 0 00
2 98754 97.4000 181.9008 0018170 108.8799 265.3057 15.24815270 04
SITRO-AIS-23
1 98753U 24317.32401620 .00000000 00000-0 50000-4 0 09
2 98753 97.4000 181.9008 0018170 108.8799 265.3057 15.24815270 03
SITRO-AIS-24
1 98752U 24317.32401620 .00000000 00000-0 50000-4 0 08
2 98752 97.4000 181.9008 0018170 108.8799 265.3057 15.24815270 02
SITRO-AIS-37
1 98751U 24317.32401620 .00000000 00000-0 50000-4 0 07
2 98751 97.4000 181.9008 0018170 108.8799 265.3057 15.24815270 01
SITRO-AIS-38
1 98750U 24317.32401620 .00000000 00000-0 50000-4 0 06
2 98750 97.4000 181.9008 0018170 108.8799 265.3057 15.24815270 00
SITRO-AIS-39
1 98749U 24317.32401620 .00000000 00000-0 50000-4 0 04
2 98749 97.4000 181.9008 0018170 108.8799 265.3057 15.24815270 08
SITRO-AIS-40
1 98748U 24317.32401620 .00000000 00000-0 50000-4 0 03
2 98748 97.4000 181.9008 0018170 108.8799 265.3057 15.24815270 07
SITRO-AIS-41
1 98747U 24317.32401620 .00000000 00000-0 50000-4 0 02
2 98747 97.4000 181.9008 0018170 108.8799 265.3057 15.24815270 06
SITRO-AIS-42
1 98746U 24317.32401620 .00000000 00000-0 50000-4 0 01
2 98746 97.4000 181.9008 0018170 108.8799 265.3057 15.24815270 05
SITRO-AIS-43
1 98745U 24317.32401620 .00000000 00000-0 50000-4 0 00
2 98745 97.4000 181.9008 0018170 108.8799 265.3057 15.24815270 04
SITRO-AIS-44
1 98744U 24317.32401620 .00000000 00000-0 50000-4 0 09
2 98744 97.4000 181.9008 0018170 108.8799 265.3057 15.24815270 03
SITRO-AIS-45
1 98743U 24317.32401620 .00000000 00000-0 50000-4 0 08
2 98743 97.4000 181.9008 0018170 108.8799 265.3057 15.24815270 02
SITRO-AIS-46
1 98742U 24317.32401620 .00000000 00000-0 50000-4 0 07
2 98742 97.4000 181.9008 0018170 108.8799 265.3057 15.24815270 01
SITRO-AIS-47
1 98741U 24317.32401620 .00000000 00000-0 50000-4 0 06
2 98741 97.4000 181.9008 0018170 108.8799 265.3057 15.24815270 00
SITRO-AIS-48
1 98740U 24317.32401620 .00000000 00000-0 50000-4 0 05
2 98740 97.4000 181.9008 0018170 108.8799 265.3057 15.24815270 09
PE0SAT
November 13, 2024, 9:50am
134
Thank you @fredy
With this information the gr-satellites yaml files that are new for this launch are now also updated.
sputnix
November 13, 2024, 1:32pm
135
There are TLEs we use. Orbital elements for satellites with numbers 13…24 are acceptable (corrected by STRF), all others obviously require more work on.
SITRO-AIS 17
1 99998U 24310.07546296 .00000000 00000-0 10000-4 0 01
2 99998 97.3920 174.6886 0005462 257.8600 330.3967 14.92693049 09
SITRO-AIS 21
1 99997U 24310.07552083 .00000000 00000-0 10000-4 0 01
2 99997 97.3921 174.6887 0012795 238.9458 349.6176 14.90976416 03
SITRO-AIS 18
1 99996U 24310.07662037 .00000000 00000-0 10000-4 0 01
2 99996 97.3931 174.6910 0005397 255.3309 339.1403 14.92682085 03
SITRO-AIS 22
1 99995U 24310.07667824 .00000000 00000-0 10000-4 0 09
2 99995 97.3932 174.6911 0012780 239.7125 355.0605 14.90981438 03
SITRO-AIS 19
1 99994U 24310.07777778 .00000000 00000-0 10000-4 0 08
2 99994 97.3941 174.6937 0005370 252.6692 348.0164 14.92693430 06
SITRO-AIS 23
1 99993U 24310.07783565 .00000000 00000-0 10000-4 0 08
2 99993 97.3941 174.6938 0012720 240.4528 0.5298 14.91036668 07
SITRO-AIS 20
1 99992U 24310.07893519 .00000000 00000-0 10000-4 0 08
2 99992 97.3950 174.6965 0005399 250.0220 356.8779 14.92702265 01
SITRO-AIS 24
1 99991U 24310.07899306 .00000000 00000-0 10000-4 0 07
2 99991 97.3950 174.6967 0012619 241.1198 6.0727 14.91024770 04
SITRO-AIS 13
1 99990U 24310.08009259 .00000000 00000-0 10000-4 0 07
2 99990 97.3957 174.6996 0005478 247.5366 5.5776 14.92559153 01
SITRO-AIS 14
1 99989U 24310.08125000 .00000000 00000-0 10000-4 0 08
2 99989 97.3962 174.7027 0005609 245.3387 13.9896 14.92520619 07
SITRO-AIS 15
1 99988U 24310.08240741 .00000000 00000-0 10000-4 0 07
2 99988 97.3964 174.7060 0005784 243.5410 22.0011 14.92465444 00
SITRO-AIS 16
1 99987U 24310.08356481 .00000000 00000-0 10000-4 0 05
2 99987 97.3965 174.7093 0005997 242.2425 29.5134 14.92388655 00
SITRO-AIS 41
1 99986U 24310.15011574 .00000000 00000-0 10000-4 0 03
2 99986 97.3942 174.8372 0011413 231.8631 39.9488 15.24210265 02
SITRO-AIS 42
1 99985U 24310.15069444 .00000000 00000-0 10000-4 0 01
2 99985 97.3941 174.8389 0011546 231.6883 43.2959 15.24176531 00
SITRO-AIS 43
1 99984U 24310.15127315 .00000000 00000-0 10000-4 0 02
2 99984 97.3940 174.8406 0011680 231.5849 46.5716 15.24180588 02
SITRO-AIS 44
1 99983U 24310.15185185 .00000000 00000-0 10000-4 0 00
2 99983 97.3938 174.8422 0011812 231.5561 49.7726 15.24143520 05
SITRO-AIS 37
1 99982U 24310.15821759 .00000000 00000-0 10000-4 0 03
2 99982 97.3871 174.8595 0016406 247.0011 69.1888 15.22870007 07
SITRO-AIS 38
1 99981U 24310.15937500 .00000000 00000-0 10000-4 0 04
2 99981 97.3858 174.8613 0016240 246.7985 75.7318 15.22825337 01
SITRO-AIS 39
1 99980U 24310.16053241 .00000000 00000-0 10000-4 0 05
2 99980 97.3847 174.8628 0016092 246.4354 82.4354 15.22919237 04
SITRO-AIS 40
1 99979U 24310.16168981 .00000000 00000-0 10000-4 0 01
2 99979 97.3836 174.8641 0015974 245.9020 89.3094 15.22977831 08
SITRO-AIS 45
1 99978U 24310.16226852 .00000000 00000-0 10000-4 0 02
2 99978 97.3832 174.8647 0015931 245.5914 92.7903 15.22976832 07
SITRO-AIS 46
1 99977U 24310.16284722 .00000000 00000-0 10000-4 0 01
2 99977 97.3828 174.8653 0015902 245.2488 96.3032 15.23020661 03
SITRO-AIS 47
1 99976U 24310.16342593 .00000000 00000-0 10000-4 0 01
2 99976 97.3825 174.8658 0015884 244.8894 99.8329 15.23042376 03
SITRO-AIS 48
1 99975U 24310.16400463 .00000000 00000-0 10000-4 0 01
2 99975 97.3822 174.8662 0015880 244.5342 103.3585 15.23070509 09
SIT-2086
1 99974U 24310.14664352 .00000000 00000-0 10000-4 0 07
2 99974 97.3934 174.8274 0010774 234.5086 8.7979 15.24780386 09
SIT-HSE
1 99973U 24310.14895833 .00000000 00000-0 10000-4 0 06
2 99973 97.3942 174.8339 0011167 232.4715 15.7527 15.24967326 00
HS318
November 14, 2024, 12:17pm
136
Just received my ArcticSat-1 QSL card
dl7ndr
November 14, 2024, 1:34pm
137
Hi Kim,
Thanks for this reminder.
I’ve checked my mailbox which is not affected by yandex blocking.
And, I also got my QSL card for RS74S (ArcticSat-1).
Did they also write on your card “GMSK 9600 ”?
I received the beacon at 2k4.
I’m wondering how the guys from ASRTU-1 (BJ2CR / RS64S) will distribute their special QSL card planned for first day telemetry .
Daniel
Foxiks
November 14, 2024, 2:46pm
138
Hello! Please tell me the symbol speed of signals and the period of binary data!
HS318
November 14, 2024, 3:44pm
139
Hi Daniel
I’ve just looked again and yes it’s “GMSK 9600” I also received at 2k4
deckbsd
November 14, 2024, 6:01pm
141
Got mine too and same here
