TLE sets from space-track.org are now assigned and we have the first identifications as we don’t expect more objects to be catalogued, here is the latest status update:
Temporary NORAD ID | Satellite | NORAD ID to follow | Other NORAD IDs | Identified | Deployed | Last Update | Notes |
RECEIVED | |||||||
- | METEOR M2-4 | 59051 | - | YES | YES | Reiceived, Identified | Identified from space-track.org, verified also by Network observations |
- | PARS 1 | 59065 | - | YES | YES | Identified, here are the ikhnos results | |
98952 | ZORKIY-2M 2 | 59064 | - | NO | YES | Changed to follow 59064 | Received on both 401.0275 MHz and 401.0725, needs a couple more observations for identification |
98951 | SITRO-AIS-25 | 59067 | 59066 | NO | YES | Received, changed to follow 59067, other possible: 59066 | |
98950 | SITRO-AIS-26 | 59066 | 59067(unlikely) | NO | YES | Received, changed to follow 59066, other possible: 59067(unlikely) | |
98949 | SITRO-AIS-27 | 59068 | 59071(unlikely) | NO | YES | Received, changed to follow 59068, other possible: 59071(unlikely) | |
98948 | SITRO-AIS-28 | 59071 | 59068(unlikely) | NO | YES | Received, changed to follow 59071, other possible: 59068(unlikely) | |
98947 | SITRO-AIS-29 | 59052 | 59053 | NO | YES | Received, changed to follow 59052, other possible: 59053 | |
98946 | SITRO-AIS-30 | 59053 | 59052 | NO | YES | Received, changed to follow 59053, other possible: 59052 | |
- | SITRO-AIS-31 | 59054 | - | YES | YES | Identified, here are the ikhnos results | |
98944 | SITRO-AIS-32 | 59056 | 59055(unlikely), 59057 | NO | YES | Received, changed to follow 59056, other possible: 59055(unlikely), 59057 | |
98943 | SITRO-AIS-33 | 59057 | 59055(unlikely), 59056 | NO | YES | Received, changed to follow 59057, other possible: 59055(unlikely), 59056 | |
98942 | SITRO-AIS-34 | 59055 | 59056, 59057 | NO | YES | Received, changed to follow 59055, other possible: 59056, 59057 | |
98941 | SITRO-AIS-35 | 59058 | 59057(unlikely) | NO | YES | Received, changed to follow 59058, other possible: 59057(unlikely) | |
98940 | SITRO-AIS-36 | 59059 | 59060 | NO | YES | Received, changed to follow 59059, other possible: 59060, removed 59061 | |
98939 | SITRO-AIS-49 | 59060 | 59059(unlikely), 59061 | NO | YES | Received, changed to follow 59060, other possible: 59059(unlikely), 59061 | |
98938 | SITRO-AIS-50 | 59061 | 59059(unlikely), 59060, 59062(unlikely) | NO | YES | Received, changed to follow 59061, other possible: 59059(unlikely), 59060, 59062(unlikely) | |
98937 | SITRO-AIS-51 | 59062 | 59061(unlikely) | NO | YES | Received, changed to follow 59062, other possible: 59061(unlikely) | |
- | SITRO-AIS-52 | 59063 | - | YES | YES | Identified, here are the ikhnos results |
