TLE for INNOSAT3
INNOSAT3
1 98553U 25207.49956303 .00000000 00000-0 50000-4 0 07
2 98553 97.4100 171.9996 0008420 52.2001 355.5076 15.21424471 01
TLE for INNOSAT3
INNOSAT3
tinyGS.com has added the 4 new objects from my work trying to locate & decode the new CSTP-4.x sats.
All 4 immediately started logging decodes from stations in the footprint!
@geoscan How stable is the GEOSCAN-x LO, new observed value 435.972200 ?
My SDR isn’t GPS locked but the frequency difference I see at the moment is to much to be caused by the sdr LO.
GEOSCAN-1
1 98559U 25207.63245003 .00000000 00000-0 16318-2 0 09
2 98559 97.4100 173.0234 0016147 141.4184 269.7200 15.21985603 07
Frequency 436.163100
GEOSCAN-2
1 98558U 25207.56703300 .00000000 00000-0 24756-1 0 03
2 98558 97.4100 172.9467 0011560 49.4078 5.0868 15.22043063 02
GEOSCAN-x LO should be not more than couple of kHz. I guess frequency values you provided might be actual and caused by medium
Thanks for the update, I guess that is the reason why concatenating the data is problematic.
I will try to get better results but to be honest it is difficult.
Contacted the strf creator @cgbsat
At 436MHz, a 1000Hz offset corresponds to 0.7 km/s in velocity. Since that’s about 10% of orbital velocity I would think that will make TLE fitting infeasible.
But you can fit each curve separately and apply an offset to each.
Lets see if we can find an offset.
Ref. the CSTP-4.x satellites, after the tinyGS.com administrator added those objects to his database and decodes started coming in, he determined that the telemetry appeared to match up w/ the format seen in the CSTP-1.x & CSTP-2.x sats.
I thought it was cool to see the transition where he started applying the decoder to received frames:
GNSS corrected TLE’s
INNOSAT16
1 98552U 25209.47340000 .00000000 00000-0 50000-4 0 07
2 98552 97.2801 175.9015 0009866 108.2683 295.3575 15.21172526 01
These will not be perfect, the LO drift makes fitting difficult.
239ALFEROV
1 98560U 25210.14500129 .00000000 00000-0 22649+0 0 05
2 98560 97.2801 174.3136 0009866 108.2683 19.3901 15.24288825 07
GEOSCAN-1
1 98559U 25210.14518985 .00000000 00000-0 24746-2 0 05
2 98559 97.4100 175.0854 0011560 49.4078 78.2838 15.21244438 04
GEOSCAN-2
1 98558U 25210.14421699 .00000000 00000-0 11151-1 0 04
2 98558 97.4200 176.1508 0021954 111.1616 16.8002 15.23828294 06
GEOSCAN-3
1 98557U 25210.20804363 .00000000 00000-0 50000-4 0 02
2 98557 97.4100 177.8394 0011560 49.4078 71.7190 15.15409510 07
GEOSCAN-4
1 98556U 25210.20885421 .00000000 00000-0 12132+1 0 05
2 98556 97.4100 177.5378 0011560 49.4078 73.4358 15.16363346 07
GEOSCAN-5
1 98555U 25210.20885421 .00000000 00000-0 -13507+1 0 02
2 98555 97.4100 176.0247 0011560 49.4078 73.3481 15.14704834 00
GEOSCAN-6
1 98554U 25210.14525865 .00000000 00000-0 -28825-2 0 08
2 98554 97.4100 175.3038 0008420 52.2001 75.5472 15.21470362 06
INNOSAT3
1 98553U 25210.20834735 .00000000 00000-0 12477-1 0 07
2 98553 97.4100 175.2603 0008420 52.2001 70.1408 15.23624243 03
INNOSAT16
1 98552U 25210.21147922 .00000000 00000-0 -10476-1 0 00
2 98552 97.2801 176.7763 0009866 108.2683 14.1027 15.20057854 04
Sorry, but it seems these are already pretty off
INNOSAT16 new TLE
INNOSAT16
1 98552U 25211.73718750 .00000000 00000-0 50000-4 0 00
2 98552 97.4100 177.3817 0015621 342.3901 209.9746 15.19739116 03
Confirming.
Gpredict also crashes for GEOSCAN-4 and -5 (with +1).
The other GEOSCAN TLEs (with -1) are working.
A TLE for Geoscan-4, it may be not so accurate as it was produced using old observations:
GEOSCAN-4
1 98556U 25211.39511701 .00000000 00000-0 82229-4 0 01
2 98556 97.4100 177.0420 0014369 56.1820 83.7452 15.22104405 05
And one TLE for Geoscan-5, again it is not very accurate but it seems better that the one we have now:
GEOSCAN-5
1 98555U 25209.47968711 .00000000 00000-0 50000-4 0 05
2 98555 97.4200 173.1826 0016821 52.9234 38.4392 15.23975807 03
Better TLE’s for 239ALFEROV
239ALFEROV
1 98560U 25209.47548935 .00000000 00000-0 50000-4 0 03
2 98560 97.4200 179.1219 0022354 94.9108 329.0355 15.20786303 01
Updated TLE
INNOSAT16
1 98552U 25213.55310750 .00000000 00000-0 50000-4 0 00
2 98552 97.4100 179.1269 0015621 170.1161 240.5242 15.05926634 09
INNOSAT3
1 98553U 25213.48350990 .00000000 00000-0 50000-4 0 03
2 98553 97.4100 183.2665 0009200 93.8092 329.1810 15.20742872 08
GEOSCAN-6
1 98554U 25213.48291530 .00000000 00000-0 50000-4 0 08
2 98554 97.4200 175.1819 0021909 71.4167 332.8198 15.06426376 08
Were there successful observations after this TLE update for GEOSCAN-5?
