Soyuz-2.1b / Fregat Baikonur Launch 2022-08-09 05:52 UTC
Hello everyone! Here are some new satellites in amateur band coming, that you could possibly listen to. All of the following satellites use GMSK modulation, USP FEC protocol, 2400 bitrate. Corresponding preliminary TLEs are in links below.
SXC3-212 (MGU)
Callsign: RS32S
UHF frequency: 437.550 MHz
tle_SXC3-212.txt (152 Bytes)
SXC3-213 (HSE-AIS)
Callsign RS21S
UHF frequency: 435.570 MHz
X frequency: 10455.0 MHz
tle_SXC3-213.txt (152 Bytes)
SXC3-214 (MIET-AIS)
Callsign RS28S
UHF frequency: 437.900 MHz
X frequency: 10475.0 MHz
tle_SXC3-214.txt (152 Bytes)
SXC3-215 (Vizard)
Callsign RS33S
UHF frequency: 437.800 MHz
tle_SXC3-215.txt (152 Bytes)
SXC3-216 (UTMN)
Callsign RS23S
UHF frequency: 435.670 MHz
X frequency: 10485.0 MHz
tle_SXC3-216.txt (152 Bytes)
SXC3-217 (Siren)
Callsign RS30S
UHF frequency: 437.750 MHz
tle_SXC3-217.txt (152 Bytes)
SXC3-218 (KuzSTU)
Callsign RS34S
UHF frequency: 437.700 MHz
X frequency: 10495.0 MHz
tle_SXC3-218.txt (152 Bytes)
SXC3-219 (Medex)
Callsign RS19S
UHF frequency: 437.650 MHz
tle_SXC3-219.txt (152 Bytes)
SXC3-2110 (Voenmeh)
Callsign RS29S
UHF frequency: 436.050 MHz
tle_SXC3-2110.txt (153 Bytes)
SXC3-2111 (SibSU)
Callsign RS8S
UHF frequency: 435.380 MHz
tle_SXC3-2111.txt (153 Bytes)
For decoding signals under Windows a soundmodem tool can be used and a quick guide here. Also you could try a flowgraph and USP FEC info with Ubuntu 20.04+ with gnuradio 3.8. It wasn`t changed since last launch.
You can look for more information and tools here in updated topic.
You are welcome to ask any questions :slight_smile:
Can you point to IARU frequency coordination information for these launches?
How does the amateur radio community benefit from these launches? It’s sounding more like the Sputnix “Private Space Company” benefits more than the community does here.
Satellites have been added in DB. From a quick look, it doesn’t seem they have IARU coordination, so their transmitter will be added as violators in DB.
If anyone would like a single TLE file for these objects reflecting the SatNogs names & object #'s, you are welcome to this one:
sputnix.txt (1.5 KB)
Thanks Scott, I should have shared this earlier http://tle.pe0sat.nl/kepler/preliminary.txt
What content will be broadcast in X-band?
Will it be DVB-S2? With what parameters? Will it be video? Or maybe files ?
Will it be possible to decode the data ?
Thanks a lot for advices! We`ll try to point information about spacecrafts to IARU soon.
All of these satellites are created as the universities initiative, so they actually are not owned by Sputnix company. After succesfull reception of satellite signal, you could request a QSL card from corresponding university as usual. Talking about amateur radio benefits, we probably could try to increase amount of opened telemetry messages and satellite data, for your interest. In previous launch there was a talk about dashboards and kaitai structs. If you are still interested in gathering satellite data, we could give you generated kaitai, which describes satellite beacon.
About X-band. Yes, protocol is DVB-S2 file transfer (photos for now) over GSE, QPSK modulation, FEC 9/10, 1Msps. But the truth is, there is only one X station, which could be used to receive data and it is located near Moscow, so we are not going to turn on the transmitter on other coordinates yet. If there will be further transmissions on other locations, we could give more information about receiving data
For those to happen the satellites will need to be coordinated. Can you please provide more information about the coordination status of those satellites?
Unfortunately, as I could know, no one has sent information to IARU directly. But satellite frequencies and callsigns were registered at the local frequency registration center.
Probably, we have a TLE miscalculation, updated TLE is coming soon.
Beaconing time in UTC Satellite
7:06:06 SXC3-215
7:06:48 SXC3-2110
7:06:48 SXC3-2110
7:07:38 SXC3-212
7:07:43 SXC3-217
7:08:28 SXC3-218
7:08:33 SXC3-213
7:09:18 SXC3-218
7:09:23 SXC3-2111
7:10:08 SXC3-214
7:10:13 SXC3-219
In that case and since there is no information on ITU either, all those satellites will be considered as violators in our DB and flagged appropriately. We take frequency coordination very seriously and will not be able to support those missions.
I know little about this, so I did some digging. On the Russian Amateur radio site it says (via machine translation):
In addition to regulations, for non-compliance with which violators are subject to appropriate sanctions by the relevant state bodies, radio amateurs have ethical standards , non-compliance with which is not punished by the state, but is condemned by the amateur radio community, which is a self-regulatory organization. The Union of Radio Amateurs of Russia strongly recommends that you study these nomes and adhere to them.
Well put!
After some changes and merges this is the list of the satellites for this launch:
Satellite Identifier Name Temporary NORAD ID Alt. Names
KILB-3720-6406-0699-8042 CUBESX-HSE-2 99356 SXC3-213, RS21S, HSE-AIS
XXDG-8589-5393-3222-5405 KUZBASS-300 99357 SXC3-218, RS34S, KUZSTU
BFTX-5845-5159-6971-7200 ISOI 99358 SXC3-219, RS19SL, MEDEX
OTLB-3496-1811-8002-0742 MIET-AIS 99360 SXC3-214 RS28S
EUTM-6475-4739-7036-7152 RESHUCUBE 99361 SXC3-2111, RS8S, SIBSU, SIBGU
TSYE-5592-5507-8880-3661 SIREN 99362 SXC3-217 RS30S
YOQT-9019-0118-9280-5437 UTMN 99363 SXC3-216 RS23S
UPJA-6543-4153-4055-9244 VIZARD 99364 SXC3-215 RS33S
YYOS-0902-7582-8175-2841 VOENMEH 99365 SXC3-2110 RS29S
RMLQ-3219-7901-9651-4925 KHAYYAM 99366
LCSC-5849-7353-1157-6022 KAI 1 99367 RS26S, KNITU-KAI, KNRTU-KAI
HKXU-1877-4030-6508-9166 MONITOR-1 99368 SXC3-212, RS32S, MGU
QNCD-8954-6090-5430-2718 GEOSCAN-EDELVEIS 99395 RS20S
Indeed the TLE sets seem to be too off. Let us know if you have any update on them.
Ok, now have updated TLEs, in one file for all satellites with SXC prefix, you could try.
all-2022-tle.txt (1.5 KB)
We will tell satellite owners to coorinate IARU.
I hope that their frequencies can be changed in orbit. If not, there is no point in coordinating.
Of course, it can be changed. But as I just found out, we spoke to satellite owners about coordination repeatedly, but all of them did not do it. And it is extremly sad, so I hope they will change their mind.
TLE have been updated in DB and Network. For GEOSCAN-EDELVEIS and KAI 1, I have used TLE set of SXC3-219 and of SXC3-216 respectively. Here are the TLE sets using the temporary NORAD IDs:
SXC3-212
1 99368U 21022AE  22220.30208333  .00000940  00000-0  68406-4 0  9993
2 99368  97.44    76.9000 0023680 118.     183.6  0 15.27149321    05
SXC3-213
1 99356U 21022AE  22220.30271991  .00000940  00000-0  68406-4 0  9990
2 99356  97.44    76.9000 0024990 112.92   192.17 0 15.27392296    05
SXC3-214
1 99360U 21022AE  22220.30381944  .00000940  00000-0  68406-4 0  9995
2 99360  97.44    76.9000 0019500 121.82   189.29 0 15.27392296    09
SXC3-215
1 99364U 21022AE  22220.30101852  .00000940  00000-0  68406-4 0  9997
2 99364  97.44    76.8900 0029960 108.19   187.59 0 15.27392296    08
SXC3-216
1 99363U 21022AE  22220.30324074  .00000940  00000-0  68406-4 0  9999
2 99363  97.44    76.9000 0020940 121.     186.94 0 15.27392296    01
SXC3-217
1 99362U 21022AE  22220.30214120  .00000940  00000-0  68406-4 0  9998
2 99362  97.44    76.9000 0026660 111.65   190.27 0 15.27392296    06
SXC3-218
1 99357U 21022AE  22220.30266204  .00000940  00000-0  68406-4 0  9992
2 99357  97.44    76.9000 0022350 119.61   185.16 0 15.27392296    08
SXC3-219
1 99358U 21022AE  22220.30387731  .00000940  00000-0  68406-4 0  9992
2 99358  97.44    76.9000 0021630 114.18   197.24 0 15.27392296    08
SXC3-2110
1 99365U 21022AE  22220.30150463  .00000940  00000-0  68406-4 0  9990
2 99365  97.44    76.8900 0024910 116.2    182.23 0 15.27392296    06
SXC3-2111
1 99361U 21022AE  22220.30329861  .00000940  00000-0  68406-4 0  9996
2 99361  97.44    76.9000 0023330 113.78   194.48 0 15.27392296    09
KAI 1
1 99367U 21022AE  22220.30324074  .00000940  00000-0  68406-4 0  9993
2 99367  97.44    76.9000 0020940 121.     186.94 0 15.27392296    05
GEOSCAN-EDELVEIS
1 99395U 21022AE  22220.30387731  .00000940  00000-0  68406-4 0  9993
2 99395  97.44    76.9000 0021630 114.18   197.24 0 15.27392296    09
A quick note, the TLE sets above seems to be off too. @sputnix how do you calculate them? We can may help on this process if we have more data.
Sorry for disturbing, but could you, please, make another update. In previous file was old data.
SXC3-212
1 99368U 21022AE  22220.29349537  .00000940  00000-0  68406-4 0  9993
2 99368  97.44   121.9000 0023680 118.      86.4646 15.27149321    02
SXC3-213
1 99356U 21022AE  22220.29413194  .00000940  00000-0  68406-4 0  9991
2 99356  97.44   121.9000 0024990 112.92    95.0274 15.27392296    03
SXC3-214
1 99360U 21022AE  22220.29523148  .00000940  00000-0  68406-4 0  9997
2 99360  97.44   121.9000 0019500 121.82    92.1784 15.26313000    07
SXC3-215
1 99364U 21022AE  22220.29243056  .00000940  00000-0  68406-4 0  9998
2 99364  97.44   121.8900 0029960 108.19    90.4184 15.28473119    00
SXC3-216
1 99363U 21022AE  22220.29465278  .00000940  00000-0  68406-4 0  9999
2 99363  97.44   121.9000 0020940 121.      89.82 0 15.26609654    09
SXC3-217
1 99362U 21022AE  22220.29355324  .00000940  00000-0  68406-4 0  9998
2 99362  97.44   121.9000 0026660 111.65    93.1175 15.27743396    05
SXC3-218
1 99357U 21022AE  22220.29407407  .00000940  00000-0  68406-4 0  9992
2 99357  97.44   121.9000 0022350 119.61    88.0320 15.26879440    09
SXC3-219
1 99358U 21022AE  22220.29528935  .00000940  00000-0  68406-4 0  9993
2 99358  97.44   121.9000 0021630 114.18   100.1181 15.26636629    08
SXC3-2110
1 99365U 21022AE  22220.29291667  .00000940  00000-0  68406-4 0  9990
2 99365  97.44   121.8900 0024910 116.2     85.0878 15.27392296    07
SXC3-2111
1 99361U 21022AE  22220.29471065  .00000940  00000-0  68406-4 0  9998
2 99361  97.44   121.9000 0023330 113.78    97.3475 15.27014369    01
I have updated NORAD IDs and recalculated checksums in previous post.
