By running ikhnos, for now I’ve changed the NORAD IDs we follow in the following way, note that it is still early for identification and for some of the satellites more than one TLE sets fits for now but we chose only one to follow:
Hello, Geoscan here. We have been able to get our telemetry with AX.25 format packet from our satellite transmitter an hour ago. So our cubesat is operational. I hope you’ll be able to receive signal from it! It looks like that our satellite should have 53375 NORAD rather than 53383, but it’s tbd still.
Here is our protocol. We are open to any questions and eager to communicate with satnogs community. GRTP.pdf (339.9 KB)
We have contacted IARU beforehand as soon as we got a place on this launch, a callsign from our national administration and figured out what we have to do. We really wanted this mission to be as open as possible. We want to follow all conventions and communicate with radio amateurs around the world. To be able to follow our educational mission. But sadly IARU don’t want to see us as such, somehow. But we try to do anything we can. This is our first ever mission:)
What software should we use to decode frames from your satellite? Standard UZ7HO HS-SoundModem FSK 9K6 modem? What mode? USB or W-FM? I was able to receive signals from your satellite but I couldn´t decode them with my usual Windows tools.
@fredy Certainly may be the case, I’ve got a STRF observation from SatNOGS Network - Observation 6314779 that shows a couple signals in the last several seconds that are lining up with 53378 @ 437.550.
With the space-track.org TLE assigned we are a step closer to identifications. Here are the results after analyzing with ikhnos the latest observations:
Name
Temporary NORAD ID
Followed NORAD ID
Other Possible NORAD IDs
Status
Update
GEOSCAN-EDELVEIS
99395
53385
53383(unlikely), 53384, 53386(unlikely)
Received
Rejected 53372, 53373 and 53374
MONITOR-1
99368
53374
53375
Received
Rejected 53373 and 53376
CUBESX-HSE-2
99356
53383
53384
Received
Rejected 53381, 53382, 53385
MIET-AIS
99360
53376
53374, 53375, 53377, 53378
Received
Added 53374 as possible
VIZARD
99364
53386
53385(unlikely)
Received
Rejected 53381, 53382, 53383, 53384
UTMN
99363
53377
53374, 53375, 53376, 53378
Received
Rejected 53373
SIREN
99362
53384
53383
Received
Rejected 53381, 53382. Changed to follow 53384 instead of 53382
I have not seen the names “Polytech Universe 1 & 2” mentioned here, but following up on a tweet:
… I recorded a low pass of Objects 53371/53372 and after replay & analysis, find that their downlinks are 62.5k LoRa.
The LoRa parameters shown in the following tweet are probably not all exactly correct, but they were close enough for me to get a decode from one of the dirty packets from this low pass. So, I’ll be interested to see confirmation eventually of what these 2 objects are and hopefully even some info about the telemetry payload
