Soyuz-2.1a / Fregat Baikonur launch 2021-03-22T06:07 UTC
It seems that objects like 2021-022AD have disappeared from
https://www.celestrak.com/NORAD/elements/tle-new.txt
… but are also not in
https://www.celestrak.com/NORAD/elements/active.txt
… and since I don’t see any other object identified as GRBAlpha (and perhaps this affects object #'s we were using for other uncertain objects also), what can be done for a TLE for objects that were not yet firmly identified?
-Scott, K4KDR
Not sure why it disappeared, it is back now, at least on the active satellites list. In general case if we don’t have a TLE set from any of the sources we use and we receive the satellite then we can generate our own, currently using strf tools and observations that are performed independently from community members.
Ah, yes – they even have it by name now. Thanks!!
GRBALPHA
1 47959U 21022AD  21113.76376416  .00001014  00000-0  74201-4 0  9993
2 47959  97.5626  17.0081 0022556 134.7180 313.3257 15.05609915  3640
Update on the fits for the 38 TLE sets by using ikhnos. GRBALPHA and KSU-Cubesat are identified and indirectly SIMBA:
Satellite Norad Follow Other Candidates Notes
UNISAT-7 OBJECT P(47945) Identified as OBJECT P(47945), here are the results of ikhnos on observation 3958280.
BCCSAT-1 OBJECT AK(48041) Identified as OBJECT AK(48041), here are the results of ikhnos on observation 3958289.
FEES OBJECT AL(48082) No reception, changed to follow OBJECT AL(48082) from our discussion in this thread and also this tweet by Jonathan McDowell
DIY-1 OBJECT AH(47963) Identified as OBJECT AH(47963), here are the results of ikhnos on observation 3958366.
SMOG-1 OBJECT AJ(47964) Identified as OBJECT AJ(47964), here are the results of ikhnos on observation 3954293. Both OBJECT F and OBJECT AH look close fits but have been rejected in the past.
STECCO OBJECT AG(47962) Identified as OBJECT AG(47962), here are the results of ikhnos on observation 3915387.
NANOSATC-BR2 OBJECT U(47950) OBJECT AC(47958), OBJECT AP(47985) No update
KMSL OBJECT AC(47958) OBJECT U(47950), OBJECT AB(47958), OBJECT AM(48083), OBJECT AN(48084) Rejected OBJECT AP(47985), changed to follow OBJECT AC(47958) it seems to fit better and also this tweet by Jonathan McDowell
CANYVAL-C 1U OBJECT G(47938) No reception continue to follow OBJECT G(47938)
CANYVAL-C 2U OBJECT G(47938) No reception continue to follow OBJECT G(47938)
BEESAT-5 OBJECT AM(48083) OBJECT AB(47957), OBJECT AC(47958), OBJECT AN(48084) No Update
BEESAT-6 OBJECT AM(48083) OBJECT AB(47957), OBJECT AC(47958), OBJECT AN(48084) No Update
BEESAT-7 OBJECT AN(48084) OBJECT AB(47957), OBJECT AC(47958), OBJECT AM(48083) No Update
BEESAT-8 OBJECT AN(48084) OBJECT AB(47957), OBJECT AC(47958), OBJECT AM(48083) No Update
CUBESX-SIRIUS-HSE OBJECT V(47951) Identified as OBJECT V(47951), here are the results of ikhnos on observation 3957952.
CUBESX-HSE OBJECT W(47952) Identified as OBJECT W(47952), here are the results of ikhnos on observation 3957827.
ORBICRAFT-ZORKIY OBJECT AE(47960) Identified as OBJECT AE(47960), here are the results of ikhnos on observation 3958176.
SIMBA OBJECT K(47941) Rejected OBJECT AD(47959) as it is GRBALPHA, it should be the remaining OBJECT K(47941), not a very good observation the last hours to confirm with ikhnos
GRBALPHA OBJECT AD(47959) Rejected OBJECT K(47941), OBJECT W(47952) , Identified as OBJECT AD(47959), here are the results of ikhnos on observation 3989591.
CHALLENGEONE OBJECT AA(47956) Identified as OBJECT AA(47956), here are the results of ikhnos on observation 3957745.
KSU-CUBESAT OBJECT Y(47954) Rejected OBJECT AF(47961), Identified as OBJECT Y(47954), here are the results of ikhnos on observation 3989650. It seems that this object was mis-identified initially in space-track.org as being satellite 3B5GSAT, however this recently changed a now is not identified in their catalog.
Regarding Observation 4010013
KMSL does not fit properly to 47958
This is because it is not KMSL but 43793 CSIM, bellow is the result of ikhnos by using CSIM TLE set and CSIM transmitter frequency:
Update on the fits for the 38 TLE sets by using ikhnos:
NANOSATC-BR2 OBJECT U(47950) OBJECT AP(47985) Rejected OBJECT AC(47958)
KMSL OBJECT AC(47958) OBJECT U(47950), OBJECT AB(47958), OBJECT AM(48083), OBJECT AN(48084) No signal since 2021-04-22 23:17:23
SIMBA OBJECT K(47941) Identified as OBJECT AD(47959), here are the results of ikhnos on observation 4022058.
GRBALPHA OBJECT AD(47959) Identified as OBJECT AD(47959), here are the results of ikhnos on observation 3989591.
KSU-CUBESAT OBJECT Y(47954) Identified as OBJECT Y(47954), here are the results of ikhnos on observation 3989650.
Hello, Fredy.
Always, thank you for your efforts in Satnogs
This is just information for you and users.
There was a single event effect in ISIS UHF Tx Modem. Through ‘reset command’ from ground station without OBC reset. The modem works well again now.
So, everything is good now.
NANOSATC-BR2 has been identified as OBJECT U(47950) and KMSL is OBJECT AC(47958) I’ll post later more info.
BEESATs will beacon continuously the next 48h, so I have scheduled observations to help identify the objects.
13 posts were split to a new topic: OrbiCraft-Zorkiy - SSTV event
What’s the satnogs policy re: uncoordinated satellites please? I seem to remember it was to help identify rogue sats but I think I need a reminder of where the previous discussions got to on this.
73s Chris
@drchrisbridges you can find the policy for now in Changes in Network and DB for satellites that violate frequency regulations.
