How can one build/buy such an antenna? And how does it compare on VHF to for example - turnstile built only for VHF?
Besides somewhat large surface area, does it have any significant drawbacks? Not gonna lie the ability to cover both UHF and VHF with one antenna is awesome.
So as I understand I would need to generate shape for one arm of such antenna, then have someone mill it on CNC machine (out of what metal composition?)
Are those arms welded to that support structure in the image? If so I have no idea how this antenna is working as that would just be shorting the arms together.
If you are able to measure the impedance and stuff right at the feed point then I am sure someone can help come up with a balun. (Would suggest using a NanoVNA or something as they are pretty cheap_
