To verify an observation system, I am trying to use Gpredict for making satellite data just like the result for “Show next pass” as below.
But, I found that I have to save the data one by one.
Is there a way to save these results for multiple satellites? like hundreds?
I don’t have the knowledge to modify C programming language, so I need some help.
jebba
June 9, 2022, 7:47pm
2
I’m still a noob, but I don’t see any straightforward way to do that with gpredict. There are a variety of other command line tools, which may work better, such as Python scripts using Skyfield:
Perhaps you could explain your use case further and how you are doing your verification. Thanks!
Thank you for your help!
I will consider using this
Is there no way to do this with gpredict, not other tools?
I have never used gpredict but google tells me Saving the List View could be relevant.
jebba
June 10, 2022, 9:50pm
6
I think you can get a custom list of satellites that way, but they’d still have to click on each one to view “next pass” for export. afaict…
I see this link now too:
@csete :
For the time being, pass predictions are only generated for one satellite at a time, though it might change in the future.
Thank you so much for finding what I needed!
Helped me a lot
I would have to try modifying the source code then…
I read this before asking, but thank you
