TASK [satnogs-client : Install satnogs-client] *********************************************************************************************************************************************************
FAILED - RETRYING: Install satnogs-client (5 retries left).
FAILED - RETRYING: Install satnogs-client (4 retries left).
FAILED - RETRYING: Install satnogs-client (3 retries left).
FAILED - RETRYING: Install satnogs-client (2 retries left).
FAILED - RETRYING: Install satnogs-client (1 retries left).
fatal: [localhost]: FAILED! => {"attempts": 5, "changed": false, "cmd": ["/var/lib/satnogs/bin/pip2", "install", "git+https://gitlab.com/librespacefoundation/satnogs/satnogs-client.git@master"], "name": ["git+https://gitlab.com/librespacefoundation/satnogs/satnogs-client.git@master"], "requirements": null, "state": "present", "stderr": "DEPRECATION: Python 2.7 will reach the end of its life on January 1st, 2020. Please upgrade your Python as Python 2.7 won't be maintained after that date. A future version of pip will drop support for Python 2.7. More details about Python 2 support in pip, can be found at https://pip.pypa.io/en/latest/development/release-process/#python-2-support\n Running command git clone -q https://gitlab.com/librespacefoundation/satnogs/satnogs-client.git /tmp/pip-req-build-_2YMCR\nWARNING: You are using pip version 19.2.3, however version 19.3.1 is available.\nYou should consider upgrading via the 'pip install --upgrade pip' command.\n", "stderr_lines": ["DEPRECATION: Python 2.7 will reach the end of its life on January 1st, 2020. Please upgrade your Python as Python 2.7 won't be maintained after that date. A future version of pip will drop support for Python 2.7. More details about Python 2 support in pip, can be found at https://pip.pypa.io/en/latest/development/release-process/#python-2-support", " Running command git clone -q https://gitlab.com/librespacefoundation/satnogs/satnogs-client.git /tmp/pip-req-build-_2YMCR", "WARNING: You are using pip version 19.2.3, however version 19.3.1 is available.", "You should consider upgrading via the 'pip install --upgrade pip' command."], "stdout": "Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple\nCollecting git+https://gitlab.com/librespacefoundation/satnogs/satnogs-client.git@master\n Cloning https://gitlab.com/librespacefoundation/satnogs/satnogs-client.git (to revision master) to ./pip-req-build-_2YMCR\nRequirement already satisfied (use --upgrade to upgrade): satnogs-client==1.0 from git+https://gitlab.com/librespacefoundation/satnogs/satnogs-client.git@master in /var/lib/satnogs/lib/python2.7/site-packages\nRequirement already satisfied: APScheduler in /usr/lib/python2.7/dist-packages (from satnogs-client==1.0) (0.0.0)\nRequirement already satisfied: python-dotenv in /var/lib/satnogs/lib/python2.7/site-packages (from satnogs-client==1.0) (0.10.3)\nRequirement already satisfied: requests in /usr/lib/python2.7/dist-packages (from satnogs-client==1.0) (2.21.0)\nRequirement already satisfied: validators in /var/lib/satnogs/lib/python2.7/site-packages (from satnogs-client==1.0) (0.14.0)\nRequirement already satisfied: python-dateutil in /usr/lib/python2.7/dist-packages (from satnogs-client==1.0) (2.7.3)\nRequirement already satisfied: ephem in /usr/lib/python2.7/dist-packages (from satnogs-client==1.0) (3.7.6.0)\nRequirement already satisfied: pytz in /usr/lib/python2.7/dist-packages (from satnogs-client==1.0) (2019.1)\nRequirement already satisfied: numpy in /usr/lib/python2.7/dist-packages (from satnogs-client==1.0) (1.16.2)\nRequirement already satisfied: matplotlib in /usr/lib/python2.7/dist-packages (from satnogs-client==1.0) (2.2.3)\nRequirement already satisfied: gps in /usr/lib/python2.7/dist-packages (from satnogs-client==1.0) (3.17)\nRequirement already satisfied: funcsigs in /var/lib/satnogs/lib/python2.7/site-packages (from APScheduler->satnogs-client==1.0) (1.0.2)\nRequirement already satisfied: futures in /var/lib/satnogs/lib/python2.7/site-packages (from APScheduler->satnogs-client==1.0) (3.3.0)\nRequirement already satisfied: typing; python_version < \"3.5\" in /var/lib/satnogs/lib/python2.7/site-packages (from python-dotenv->satnogs-client==1.0) (3.7.4.1)\nRequirement already satisfied: six>=1.4.0 in /usr/lib/python2.7/dist-packages (from validators->satnogs-client==1.0) (1.12.0)\nRequirement already satisfied: decorator>=3.4.0 in /usr/lib/python2.7/dist-packages (from validators->satnogs-client==1.0) (4.3.0)\nBuilding wheels for collected packages: satnogs-client\n Building wheel for satnogs-client (setup.py): started\n Building wheel for satnogs-client (setup.py): finished with status 'done'\n Created wheel for satnogs-client: filename=satnogs_client-1.0-cp27-none-any.whl size=31119 sha256=340b6766875bce74b31b20ed07dd1583815d47c3ae4e9e65030990b1276d6724\n Stored in directory: /tmp/pip-ephem-wheel-cache-4Zl7Rx/wheels/13/4e/d6/e0dee11ac8cff16eac76942153def2bd8b9c3e5a5207306e10\nSuccessfully built satnogs-client\n", "stdout_lines": ["Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple", "Collecting git+https://gitlab.com/librespacefoundation/satnogs/satnogs-client.git@master", " Cloning https://gitlab.com/librespacefoundation/satnogs/satnogs-client.git (to revision master) to ./pip-req-build-_2YMCR", "Requirement already satisfied (use --upgrade to upgrade): satnogs-client==1.0 from git+https://gitlab.com/librespacefoundation/satnogs/satnogs-client.git@master in /var/lib/satnogs/lib/python2.7/site-packages", "Requirement already satisfied: APScheduler in /usr/lib/python2.7/dist-packages (from satnogs-client==1.0) (0.0.0)", "Requirement already satisfied: python-dotenv in /var/lib/satnogs/lib/python2.7/site-packages (from satnogs-client==1.0) (0.10.3)", "Requirement already satisfied: requests in /usr/lib/python2.7/dist-packages (from satnogs-client==1.0) (2.21.0)", "Requirement already satisfied: validators in /var/lib/satnogs/lib/python2.7/site-packages (from satnogs-client==1.0) (0.14.0)", "Requirement already satisfied: python-dateutil in /usr/lib/python2.7/dist-packages (from satnogs-client==1.0) (2.7.3)", "Requirement already satisfied: ephem in /usr/lib/python2.7/dist-packages (from satnogs-client==1.0) (3.7.6.0)", "Requirement already satisfied: pytz in /usr/lib/python2.7/dist-packages (from satnogs-client==1.0) (2019.1)", "Requirement already satisfied: numpy in /usr/lib/python2.7/dist-packages (from satnogs-client==1.0) (1.16.2)", "Requirement already satisfied: matplotlib in /usr/lib/python2.7/dist-packages (from satnogs-client==1.0) (2.2.3)", "Requirement already satisfied: gps in /usr/lib/python2.7/dist-packages (from satnogs-client==1.0) (3.17)", "Requirement already satisfied: funcsigs in /var/lib/satnogs/lib/python2.7/site-packages (from APScheduler->satnogs-client==1.0) (1.0.2)", "Requirement already satisfied: futures in /var/lib/satnogs/lib/python2.7/site-packages (from APScheduler->satnogs-client==1.0) (3.3.0)", "Requirement already satisfied: typing; python_version < \"3.5\" in /var/lib/satnogs/lib/python2.7/site-packages (from python-dotenv->satnogs-client==1.0) (3.7.4.1)", "Requirement already satisfied: six>=1.4.0 in /usr/lib/python2.7/dist-packages (from validators->satnogs-client==1.0) (1.12.0)", "Requirement already satisfied: decorator>=3.4.0 in /usr/lib/python2.7/dist-packages (from validators->satnogs-client==1.0) (4.3.0)", "Building wheels for collected packages: satnogs-client", " Building wheel for satnogs-client (setup.py): started", " Building wheel for satnogs-client (setup.py): finished with status 'done'", " Created wheel for satnogs-client: filename=satnogs_client-1.0-cp27-none-any.whl size=31119 sha256=340b6766875bce74b31b20ed07dd1583815d47c3ae4e9e65030990b1276d6724", " Stored in directory: /tmp/pip-ephem-wheel-cache-4Zl7Rx/wheels/13/4e/d6/e0dee11ac8cff16eac76942153def2bd8b9c3e5a5207306e10", "Successfully built satnogs-client"], "version": null, "virtualenv": "/var/lib/satnogs"}
PLAY RECAP *********************************************************************************************************************************************************************************************
localhost : ok=37 changed=1 unreachable=0 failed=1 skipped=1 rescued=0 ignored=0
