Satnogs-client.service not found
Hi, I have been trying to set up a ground station over the last couple of days to no prevail. Currently journalctl -u satnogs-client.service returns nothing, there is no log file as well as no .satnog file anywhere on the system. I have followed the tutorials twice , the RTLSDR is connected correctly and the hardware itself is working so I believe it is the software. Please let me know if you need any more information!
Edit:
After probing around some more, it seems that satnogs-client is not running, any way i can start/find it? satnogs-setup works fine and other commands
what method of install did you use ?
if it’s the newer stack, it is running in docker and not systemd.
Ah i see, havent used docker before so how do i check that? Also im running an rtl-sdr v4 which i think may be problamitic but made sure the correct drivers are installed
Im now in the docker but i still have no journal logs/files
journal is a systemd thing, not docker.
here’s a few threads where we have touched some of this:
All the documentation and troubleshooting is slowly catching up to the new stack. SatNOGS Setup - SatNOGS Wiki
Thank you for your help so far. Reading those blogs you have thrown my way , I ran the sudo docker logs -f satnogs_satnogs-client command and got this as an output:
rot_init called
initrots4_dummy: _init called
rot_register (1)
rot_register (2)
dummy_rot_init called
rot_open called
dummy_rot_open called
rig_init: rig does not have rx_range!!
network_open: hoststr=rigctld, portstr=4532
File “/usr/bin/satnogs_fm.py”, line 476, in
main()
File “/usr/bin/satnogs_fm.py”, line 459, in main
tb = top_block_cls(antenna=options.antenna, bb_freq=options.bb_freq, bw=options.bw, dc_removal=options.dc_removal, decoded_data_file_path=options.decoded_data_file_path, dev_args=options.dev_args, deviation=options.deviation, doppler_correction_per_sec=options.doppler_correction_per_sec, enable_iq_dump=options.enable_iq_dump, file_path=options.file_path, gain=options.gain, gain_mode=options.gain_mode, iq_file_path=options.iq_file_path, lo_offset=options.lo_offset, max_modulation_freq=options.max_modulation_freq, other_settings=options.other_settings, ppm=options.ppm, rigctl_host=options.rigctl_host, rigctl_port=options.rigctl_port, rx_freq=options.rx_freq, samp_rate_rx=options.samp_rate_rx, soapy_rx_device=options.soapy_rx_device, stream_args=options.stream_args, tune_args=options.tune_args, udp_IP=options.udp_IP, udp_dump_host=options.udp_dump_host, udp_dump_port=options.udp_dump_port, udp_port=options.udp_port, waterfall_file_path=options.waterfall_file_path)
File “/usr/bin/satnogs_fm.py”, line 92, in init
self.soapy_source_0_0 = soapy.source(1, dev, dev_args, stream_args,
File “/usr/lib/python3/dist-packages/soapy/soapy_swig.py”, line 131, in make
return _soapy_swig.source_make(nchan, device, dev_args, stream_args, tune_args, other_settings, sampling_rate, type)
RuntimeError: SoapySDR::Device::make() no match
netrigctl_close: done status=Command completed successfully
ERROR satnogsclient.observer.observer No waterfall data file found
main()
File “/usr/bin/satnogs_noaa_apt_decoder.py”, line 494, in
main()
File “/usr/bin/satnogs_noaa_apt_decoder.py”, line 477, in main
tb = top_block_cls(antenna=options.antenna, bb_freq=options.bb_freq, bw=options.bw, dc_removal=options.dc_removal, decoded_data_file_path=options.decoded_data_file_path, dev_args=options.dev_args, doppler_correction_per_sec=options.doppler_correction_per_sec, enable_iq_dump=options.enable_iq_dump, file_path=options.file_path, flip_images=options.flip_images, gain=options.gain, gain_mode=options.gain_mode, iq_file_path=options.iq_file_path, lo_offset=options.lo_offset, other_settings=options.other_settings, ppm=options.ppm, rigctl_host=options.rigctl_host, rigctl_port=options.rigctl_port, rx_freq=options.rx_freq, samp_rate_rx=options.samp_rate_rx, soapy_rx_device=options.soapy_rx_device, stream_args=options.stream_args, sync=options.sync, tune_args=options.tune_args, udp_IP=options.udp_IP, udp_dump_host=options.udp_dump_host, udp_dump_port=options.udp_dump_port, udp_port=options.udp_port, waterfall_file_path=options.waterfall_file_path)
File “/usr/bin/satnogs_noaa_apt_decoder.py”, line 91, in init
main()
WARNING apscheduler.executors.default Run time of job “get_jobs (trigger: interval[0:01:00], next run at: 2025-02-08 22:18:34 UTC)” was missed by 0:00:38.520647
rot_init called
rot_register (1)
rot_register (2)
main()
main()
Looking at RuntimeError: SoapySDR::Device::make() no match there seems something wrong with the SDR configuration.
Maybe you can share the environment variables that are used as an input for the docker satnogs client. Please hide the api keys from the output that you share.
I found that error and just in the process of doing a flat reinstall to see whether it persist.s. I did lots of tinkering to my last build to try and fix some other issues
Ive done a fresh install and have lost the old error, now I am at this error (RTL-SDR V4): satnogs-client@a16c74dcf74d:/$ SoapySDRUtil --probe
Probe device
[ERROR] avahi_client_new() failed: Daemon not running
ERROR: Unable to create Avahi DNS-SD client :Daemon not running
[WARNING] Unable to scan ip: -26
Found Rafael Micro R828D tuner
RTL-SDR Blog V4 Detected
– Device identification
driver=Audio
hardware=Audio
device_id=0
origin=GitHub - pothosware/SoapyAudio: Soapy SDR plugin for Audio devices
– Peripheral summary
Channels: 1 Rx, 0 Tx
Timestamps: NO
Other Settings:
* Stereo Sample Offset - Offset stereo samples for off-by-one audio inputs.
[key=sample_offset, default=0, type=string, options=(-2, -1, 0, 1, 2)]
* Rig Control - Select hamlib rig control type.
[key=rig, type=string, options=(29001, 25016, 25017, 25013, 25018, 5008, 5006, 5005, 5004, 5014, 5003, 5015, 5002, 5001, 5013, 5016, 17001, 17002, 25006, 32001, 25003, 23003, 23004, 31002, 31001, 9002, 9003, 33001, 2021, 2029, 2043, 2047, 2044, 2045, 2038, 25001, 25007, 4, 25012, 23001, 2036, 2048, 25015, 1, 6, 2, 2046, 25019, 3054, 3002, 3003, 3072, 3004, 3006, 3007, 3060, 3055, 3085, 3009, 3010, 3011, 3012, 3070, 3013, 3061, 3014, 3015, 3016, 3017, 3073, 3019, 3020, 3021, 3022, 3067, 3023, 3046, 3024, 3026, 3027, 3047, 3057, 3063, 3028, 3078, 3029, 3062, 3030, 3045, 3056, 3031, 3075, 3032, 3034, 3044, 3068, 3065, 3035, 3081, 30001, 30003, 30002, 30004, 4002, 4001, 4003, 4004, 3036, 3058, 3080, 3077, 3040, 3037, 3041, 3038, 3039, 3079, 3043, 3066, 3069, 3042, 3083, 3082, 3084, 3071, 6005, 6006, 6007, 25011, 18001, 2015, 2033, 2042, 2017, 2019, 2020, 2023, 2026, 2034, 2027, 2030, 2025, 2014, 2002, 2003, 2028, 2001, 2004, 2016, 2031, 2037, 2024, 2005, 2006, 2007, 2008, 2009, 2010, 2041, 2022, 2011, 2012, 2013, 2039, 10004, 3074, 25014, 2040, 3053, 3052, 28001, 24001, 11005, 11003, 8004, 27002, 27001, 27003, 25002, 2032, 14004, 14002, 25009, 22001, 5, 3064, 3051, 16003, 16012, 16004, 16005, 16007, 16002, 16001, 16008, 16009, 16011, 16013, 8002, 8006, 8001, 8003, 8012, 8010, 8011, 1033, 26001, 26002, 12004, 15001, 15002, 15003, 15004, 15005, 15006, 15007, 15009, 3076, 1017, 1019, 1018, 1021, 1003, 1024, 1029, 1027, 1039, 1010, 1005, 1006, 1007, 1009, 1020, 1041, 1011, 1001, 1038, 1022, 1015, 1036, 1023, 1013, 1014, 1028, 1031, 1016, 1035, 1034, 1037, 1032, 1030, 1040, 1004, 1025, 1026, 25008)]
* Rig Serial Rate - Select hamlib rig serial control rate.
[key=rig_rate, default=57600, type=string, options=(1200, 2400, 4800, 9600, 19200, 38400, 57600, 115200, 128000, 256000)]
* Rig Serial Port - hamlib rig Serial Port dev / COMx / IP-Address
[key=rig_port, default=/dev/ttyUSB0, type=string]
– RX Channel 0
Full-duplex: YES
Supports AGC: YES
Native format: CS16 [full-scale=65536]
Stream args:
* Channel Setup - Input channel configuration.
[key=chan, default=mono_l, type=string, options=(mono_l, mono_r, stereo_iq, stereo_qi)]
Antennas: RX
Full gain range: [0, 0] dB
Full freq range: [0, 6000] MHz
RF freq range: [0, 6000] MHz
Sample rates: 0.008, 0.016, 0.02205, 0.032, 0.0441, 0.048, 0.096 MSps
the --probe usually just the first device it finds, which mostly is the soundcard.
use SoapySDRUtil --find and then look in the list for devices, example:
Found device 0
  default_input = True
  default_output = True
  device_id = 0
  driver = audio
  label = PulseAudio
Found device 1
  driver = rtlsdr
  label = Generic RTL2832U OEM :: 1864
  manufacturer = Realtek
  product = RTL2838UHIDIR
  serial = 1864
  tuner = Rafael Micro R820T
If you want to see the capabilities, run SoapySDRUtil --probe="driver=rtlsdr" if that is what it found.
Also, post your configuration (no api key).
great thank you, thanks for your help. please see above comment :). Here is my configuration:
"configuration": {
    "satnogs_antenna": "RX",
    "satnogs_log_level": "DEBUG",
    "satnogs_rf_gain": "32.8",
    "satnogs_scheduler_log_level": "DEBUG",
    "satnogs_station_elev": "93",
    "satnogs_station_id": "3933",
    "satnogs_station_lat": "50.224722",
    "satnogs_station_lon": "-5.083355"
I had a look at the meta data from one of your observations:
In this example you are using driver=RTLSDR this isn’t correct, it should be lower case.
radio: {
version: "v2.3-compat-xxx-v2.3.5.0",
parameters: {
soapy-rx-device: "driver=RTLSDR",
samp-rate-rx: "2.048e6",
rx-freq: "468100000",
file-path: "/tmp/.satnogs/data/receiving_satnogs_11065550_2025-02-09T14-27-40.out",
waterfall-file-path: "/tmp/.satnogs/data/receiving_waterfall_11065550_2025-02-09T14-27-40.dat",
decoded-data-file-path: "/tmp/.satnogs/data/data_11065550",
doppler-correction-per-sec: null,
lo-offset: null,
ppm: null,
rigctl-host: "rigctld",
rigctl-port: "4532",
gain-mode: "Overall",
gain: "32.8",
antenna: "RX",
dev-args: null,
stream-args: null,
tune-args: null,
other-settings: null,
dc-removal: null,
bb-freq: null,
bw: null,
enable-iq-dump: "0",
iq-file-path: null,
udp-dump-host: null,
udp-dump-port: 57356,
wpm: null,
baudrate: null,
framing: null
latitude: 50.224722,
longitude: -5.083355,
elevation: 93,
frequency: 468100000
This has been fixed already, it was something I tried yesterday
Im trying to setup satnogs on a rasberry pi 4B+ 2gb ram
i know my linux basics but i have know idea wha the following
docker & ansible these are not normal unix tools.
I am quite frustrated with this install. I can run satnogs setup but cant seem, to coax satnogs-client into operation with systemctl satnogs-client the command returns service not found. Running soapy SoupySDRUtill --Probe does show both my ack rf & rtlsdr devices as both sdr run properly on gqrx… now I’m not a massive fan Linux these days, I just tolerate it to accomplish sdr-tasks however im not impressed with satnogs installation process. i could use some help. my intent in using the software is to expand my interest antenna engineering while having somthing quite cool to apply the antenna design enginneering to in a practical way.
@satenna-junkie it looks like you run the latest version of the client, this version installs the client into a container (docker container), this means that you don’t have access with the usual commands.
@Acinonyx has just updated the Troubleshooting wiki page with the necessary commands for performing a basic troubleshooting and solve some common issues.
Please go through it and if you can not find a solution to your issue please open a new thread and paste here any error logs and the support report, as described at the top of the Troubleshooting wiki page.
PS
A general note to all current and future station owners: This period the developers of SatNOGS client are in the process of improving and making easier the ground station software installation. Due to the complexity of the task, it is done in steps, for example in the new version not all of the previous features have been supported yet and the interaction with the satnogs-client setup and configuration are still done through command line, instead of a simple web page and through the SatNOGS Network. Please bear with us and if possible contribute either by reporting issues, testing or even development.
To all that have replied Thank you!!! the Librie plans to simplify the install process couldent have come at a better time :slight_smile: Been tinkering with the install process for sandnogs for 2 weeks and i say it dreadfully painful to install …
I think the Raspberry pi 4B adds another layer pie centric technicalities to the install
that being said I even got chatGPT to try and help with the satnogs install process, just felt like i was going around in circle.
Earlier this year I used chatGPT to guide my installing GNU-Radio Companion, and learn to update the various Demodulation Modules that were deprecated in older gnu radio versions and extract them into my current linux install of gnu radio alongside the OOT demodulation modules. took several days but i got it to work. I wish i could have a similar installation experience with satnogs
I have 2 raspbery pie 4b 2gb ram that i would like mount to a 24"" monitor for my satnogs node making it portable.
if anyone has any suggestions lets have them…
Peace
Phil
i have an issue for setup a new SATNOGS-CLIENT.
i’m already finish to make BASIC CONFIGURATION.
after apply, got this error.
when i get general support information :slight_smile:
need help
