Starting at ~03 UTC today, all observations made by my station failed (no waterfall, nothing). At 18:21:31 UTC the station stopped pulling new observations from the API and started displaying
Your Station is offline. You should make sure it can successfully connect to the Network API.
This is what top looked like when I logged in to check status:
top - 20:35:58 up 11 days, 22:50, 1 user, load average: 0.49, 0.65, 0.68
Tasks: 131 total, 1 running, 130 sleeping, 0 stopped, 0 zombie
%Cpu(s): 6.7 us, 5.1 sy, 0.0 ni, 86.2 id, 0.0 wa, 0.0 hi, 1.9 si, 0.0 st
MiB Mem : 3906.0 total, 1157.5 free, 2101.6 used, 646.9 buff/cache
MiB Swap: 100.0 total, 100.0 free, 0.0 used. 1559.3 avail Mem
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
318 satnogs 20 0 907236 380476 18268 S 24.8 9.5 231:18.03 satnogs-client
319 hamlib-+ 20 0 370660 33308 2884 S 12.9 0.8 79:47.00 rigctld
1195 satnogs 20 0 389244 121504 52560 S 1.0 3.0 2:12.85 satnogs_cw_deco
1380 satnogs 20 0 471472 121272 53540 S 1.0 3.0 2:03.86 satnogs_fsk_ax2
1819 satnogs 20 0 468280 117560 52976 S 1.0 2.9 1:38.80 satnogs_fsk_ax2
2268 satnogs 20 0 465208 114504 53276 S 1.0 2.9 1:11.62 satnogs_fsk_ax2
3236 pi 20 0 10324 2944 2512 R 1.0 0.1 0:00.17 top
29089 satnogs 20 0 503092 160292 53396 S 1.0 4.0 8:16.03 satnogs_fsk_ax2
29777 satnogs 20 0 423036 154368 52752 S 1.0 3.9 7:07.94 satnogs_cw_deco
30482 satnogs 20 0 499120 148936 53472 S 1.0 3.7 6:16.35 satnogs_fsk_ax2
30686 satnogs 20 0 498096 146900 53012 S 1.0 3.7 6:04.51 satnogs_fsk_ax2
32202 satnogs 20 0 485688 134212 52916 S 1.0 3.4 4:05.72 satnogs_fsk_ax2
560 satnogs 20 0 477496 127284 53000 S 0.7 3.2 3:02.15 satnogs_fsk_ax2
774 satnogs 20 0 393340 125796 52956 S 0.7 3.1 2:43.81 satnogs_cw_deco
1507 satnogs 20 0 387196 118680 52700 S 0.7 3.0 1:56.14 satnogs_cw_deco
1659 satnogs 20 0 469304 118692 53252 S 0.7 3.0 1:47.36 satnogs_fsk_ax2
1935 satnogs 20 0 467376 116924 53144 S 0.7 2.9 1:36.30 satnogs_fsk_ax2
28845 satnogs 20 0 524340 161896 53020 S 0.7 4.0 8:38.01 satnogs_fsk_ax2
30859 satnogs 20 0 454660 146044 53632 S 0.7 3.7 5:43.61 satnogs_bpsk_ax
30994 satnogs 20 0 496048 145232 53396 S 0.7 3.6 5:41.74 satnogs_fsk_ax2
31254 satnogs 20 0 451588 142612 53172 S 0.7 3.6 5:15.83 satnogs_bpsk_ax
31928 satnogs 20 0 445236 136692 53492 S 0.7 3.4 4:18.80 satnogs_bpsk_ax
32375 satnogs 20 0 483760 133376 53292 S 0.7 3.3 3:53.51 satnogs_fsk_ax2
21 root 20 0 0 0 0 S 0.3 0.0 0:35.42 ksoftirqd/2
1 root 20 0 33696 7948 6384 S 0.0 0.2 3:38.05 systemd
systemctl status satnogs-client.service showed the following:
β satnogs-client.service - SatNOGS client
Active: active (running) since Sun 2020-04-12 14:00:23 UTC; 1 weeks 6 days ago
Main PID: 318 (satnogs-client)
Tasks: 164 (limit: 4915)
Memory: 2.0G
ββ 318 /var/lib/satnogs/bin/python3 /var/lib/satnogs/bin/satnogs-client
ββ 560 /usr/bin/python3 /usr/bin/satnogs_fsk_ax25.py --soapy-rx-device=driver=rtlsdr --samp-rate-rx=2.048e6 --rx-freq=437445000 --file-path=/tmp/.satnogs/data/receiving_satnogs_2096042_2020-04-25T14-53-52.out --waterfall-file-path=/tmp/.satnogs/data/receiving_waterfall_2096042_2020-04-25T14-53-52.dat --baudrate=9600 --rigctl-port=4532 --gain-mode=Overall --gain=48.0 --antenna=RX --enable-iq-dump=1 --iq-file-path=/tmp/.satnogs/iq.raw --decoded-data-file-path=/tmp/.satnogs/data/data_2096042
ββ 774 /usr/bin/python3 /usr/bin/satnogs_cw_decoder.py --soapy-rx-device=driver=rtlsdr --samp-rate-rx=2.048e6 --rx-freq=437274600 --file-path=/tmp/.satnogs/data/receiving_satnogs_2095697_2020-04-25T15-15-58.out --waterfall-file-path=/tmp/.satnogs/data/receiving_waterfall_2095697_2020-04-25T15-15-58.dat --rigctl-port=4532 --gain-mode=Overall --gain=48.0 --antenna=RX --enable-iq-dump=1 --iq-file-path=/tmp/.satnogs/iq.raw --decoded-data-file-path=/tmp/.satnogs/data/data_2095697
ββ 1195 /usr/bin/python3 /usr/bin/satnogs_cw_decoder.py --soapy-rx-device=driver=rtlsdr --samp-rate-rx=2.048e6 --rx-freq=436835820 --file-path=/tmp/.satnogs/data/receiving_satnogs_2096500_2020-04-25T16-15-17.out --waterfall-file-path=/tmp/.satnogs/data/receiving_waterfall_2096500_2020-04-25T16-15-17.dat --rigctl-port=4532 --gain-mode=Overall --gain=48.0 --antenna=RX --enable-iq-dump=1 --iq-file-path=/tmp/.satnogs/iq.raw --decoded-data-file-path=/tmp/.satnogs/data/data_2096500
ββ 1380 /usr/bin/python3 /usr/bin/satnogs_fsk_ax25.py --soapy-rx-device=driver=rtlsdr --samp-rate-rx=2.048e6 --rx-freq=437225000 --file-path=/tmp/.satnogs/data/receiving_satnogs_2096574_2020-04-25T16-39-52.out --waterfall-file-path=/tmp/.satnogs/data/receiving_waterfall_2096574_2020-04-25T16-39-52.dat --baudrate=4800 --rigctl-port=4532 --gain-mode=Overall --gain=48.0 --antenna=RX --enable-iq-dump=1 --iq-file-path=/tmp/.satnogs/iq.raw --decoded-data-file-path=/tmp/.satnogs/data/data_2096574
ββ 1507 /usr/bin/python3 /usr/bin/satnogs_cw_decoder.py --soapy-rx-device=driver=rtlsdr --samp-rate-rx=2.048e6 --rx-freq=435315700 --file-path=/tmp/.satnogs/data/receiving_satnogs_2096586_2020-04-25T16-52-20.out --waterfall-file-path=/tmp/.satnogs/data/receiving_waterfall_2096586_2020-04-25T16-52-20.dat --rigctl-port=4532 --gain-mode=Overall --gain=48.0 --antenna=RX --enable-iq-dump=1 --iq-file-path=/tmp/.satnogs/iq.raw --decoded-data-file-path=/tmp/.satnogs/data/data_2096586
ββ 1659 /usr/bin/python3 /usr/bin/satnogs_fsk_ax25.py --soapy-rx-device=driver=rtlsdr --samp-rate-rx=2.048e6 --rx-freq=438226000 --file-path=/tmp/.satnogs/data/receiving_satnogs_2096600_2020-04-25T17-11-58.out --waterfall-file-path=/tmp/.satnogs/data/receiving_waterfall_2096600_2020-04-25T17-11-58.dat --baudrate=9600 --rigctl-port=4532 --gain-mode=Overall --gain=48.0 --antenna=RX --enable-iq-dump=1 --iq-file-path=/tmp/.satnogs/iq.raw --decoded-data-file-path=/tmp/.satnogs/data/data_2096600
ββ 1819 /usr/bin/python3 /usr/bin/satnogs_fsk_ax25.py --soapy-rx-device=driver=rtlsdr --samp-rate-rx=2.048e6 --rx-freq=435925000 --file-path=/tmp/.satnogs/data/receiving_satnogs_2096608_2020-04-25T17-27-05.out --waterfall-file-path=/tmp/.satnogs/data/receiving_waterfall_2096608_2020-04-25T17-27-05.dat --baudrate=9600 --rigctl-port=4532 --gain-mode=Overall --gain=48.0 --antenna=RX --enable-iq-dump=1 --iq-file-path=/tmp/.satnogs/iq.raw --decoded-data-file-path=/tmp/.satnogs/data/data_2096608
ββ 1935 /usr/bin/python3 /usr/bin/satnogs_fsk_ax25.py --soapy-rx-device=driver=rtlsdr --samp-rate-rx=2.048e6 --rx-freq=435950000 --file-path=/tmp/.satnogs/data/receiving_satnogs_2096632_2020-04-25T17-36-36.out --waterfall-file-path=/tmp/.satnogs/data/receiving_waterfall_2096632_2020-04-25T17-36-36.dat --baudrate=4800 --rigctl-port=4532 --gain-mode=Overall --gain=48.0 --antenna=RX --enable-iq-dump=1 --iq-file-path=/tmp/.satnogs/iq.raw --decoded-data-file-path=/tmp/.satnogs/data/data_2096632
ββ 2268 /usr/bin/python3 /usr/bin/satnogs_fsk_ax25.py --soapy-rx-device=driver=rtlsdr --samp-rate-rx=2.048e6 --rx-freq=437480000 --file-path=/tmp/.satnogs/data/receiving_satnogs_2096648_2020-04-25T18-22-15.out --waterfall-file-path=/tmp/.satnogs/data/receiving_waterfall_2096648_2020-04-25T18-22-15.dat --baudrate=9600 --rigctl-port=4532 --gain-mode=Overall --gain=48.0 --antenna=RX --enable-iq-dump=1 --iq-file-path=/tmp/.satnogs/iq.raw --decoded-data-file-path=/tmp/.satnogs/data/data_2096648
ββ28845 /usr/bin/python3 /usr/bin/satnogs_fsk_ax25.py --soapy-rx-device=driver=rtlsdr --samp-rate-rx=2.048e6 --rx-freq=437950000 --file-path=/tmp/.satnogs/data/receiving_satnogs_2093915_2020-04-25T05-53-52.out --waterfall-file-path=/tmp/.satnogs/data/receiving_waterfall_2093915_2020-04-25T05-53-52.dat --baudrate=9600 --rigctl-port=4532 --gain-mode=Overall --gain=48.0 --antenna=RX --enable-iq-dump=1 --iq-file-path=/tmp/.satnogs/iq.raw --decoded-data-file-path=/tmp/.satnogs/data/data_2093915
ββ29089 /usr/bin/python3 /usr/bin/satnogs_fsk_ax25.py --soapy-rx-device=driver=rtlsdr --samp-rate-rx=2.048e6 --rx-freq=437421500 --file-path=/tmp/.satnogs/data/receiving_satnogs_2093514_2020-04-25T06-20-30.out --waterfall-file-path=/tmp/.satnogs/data/receiving_waterfall_2093514_2020-04-25T06-20-30.dat --baudrate=9600 --rigctl-port=4532 --gain-mode=Overall --gain=48.0 --antenna=RX --enable-iq-dump=1 --iq-file-path=/tmp/.satnogs/iq.raw --decoded-data-file-path=/tmp/.satnogs/data/data_2093514
ββ29777 /usr/bin/python3 /usr/bin/satnogs_cw_decoder.py --soapy-rx-device=driver=rtlsdr --samp-rate-rx=2.048e6 --rx-freq=437505000 --file-path=/tmp/.satnogs/data/receiving_satnogs_2094633_2020-04-25T07-42-26.out --waterfall-file-path=/tmp/.satnogs/data/receiving_waterfall_2094633_2020-04-25T07-42-26.dat --rigctl-port=4532 --gain-mode=Overall --gain=48.0 --antenna=RX --enable-iq-dump=1 --iq-file-path=/tmp/.satnogs/iq.raw --decoded-data-file-path=/tmp/.satnogs/data/data_2094633
ββ30482 /usr/bin/python3 /usr/bin/satnogs_fsk_ax25.py --soapy-rx-device=driver=rtlsdr --samp-rate-rx=2.048e6 --rx-freq=435950000 --file-path=/tmp/.satnogs/data/receiving_satnogs_2094973_2020-04-25T09-24-23.out --waterfall-file-path=/tmp/.satnogs/data/receiving_waterfall_2094973_2020-04-25T09-24-23.dat --baudrate=4800 --rigctl-port=4532 --gain-mode=Overall --gain=48.0 --antenna=RX --enable-iq-dump=1 --iq-file-path=/tmp/.satnogs/iq.raw --decoded-data-file-path=/tmp/.satnogs/data/data_2094973
ββ30686 /usr/bin/python3 /usr/bin/satnogs_fsk_ax25.py --soapy-rx-device=driver=rtlsdr --samp-rate-rx=2.048e6 --rx-freq=435700000 --file-path=/tmp/.satnogs/data/receiving_satnogs_2094233_2020-04-25T09-46-00.out --waterfall-file-path=/tmp/.satnogs/data/receiving_waterfall_2094233_2020-04-25T09-46-00.dat --baudrate=4800 --rigctl-port=4532 --gain-mode=Overall --gain=48.0 --antenna=RX --enable-iq-dump=1 --iq-file-path=/tmp/.satnogs/iq.raw --decoded-data-file-path=/tmp/.satnogs/data/data_2094233
ββ30859 /usr/bin/python3 /usr/bin/satnogs_bpsk_ax25.py --soapy-rx-device=driver=rtlsdr --samp-rate-rx=2.048e6 --rx-freq=437625000 --file-path=/tmp/.satnogs/data/receiving_satnogs_2095300_2020-04-25T10-08-51.out --waterfall-file-path=/tmp/.satnogs/data/receiving_waterfall_2095300_2020-04-25T10-08-51.dat --baudrate=9600 --rigctl-port=4532 --gain-mode=Overall --gain=48.0 --antenna=RX --enable-iq-dump=1 --iq-file-path=/tmp/.satnogs/iq.raw --decoded-data-file-path=/tmp/.satnogs/data/data_2095300
ββ30994 /usr/bin/python3 /usr/bin/satnogs_fsk_ax25.py --soapy-rx-device=driver=rtlsdr --samp-rate-rx=2.048e6 --rx-freq=437558325 --file-path=/tmp/.satnogs/data/receiving_satnogs_2095371_2020-04-25T10-21-44.out --waterfall-file-path=/tmp/.satnogs/data/receiving_waterfall_2095371_2020-04-25T10-21-44.dat --baudrate=1200 --rigctl-port=4532 --gain-mode=Overall --gain=48.0 --antenna=RX --enable-iq-dump=1 --iq-file-path=/tmp/.satnogs/iq.raw --decoded-data-file-path=/tmp/.satnogs/data/data_2095371
ββ31254 /usr/bin/python3 /usr/bin/satnogs_bpsk_ax25.py --soapy-rx-device=driver=rtlsdr --samp-rate-rx=2.048e6 --rx-freq=435840000 --file-path=/tmp/.satnogs/data/receiving_satnogs_2095409_2020-04-25T10-55-13.out --waterfall-file-path=/tmp/.satnogs/data/receiving_waterfall_2095409_2020-04-25T10-55-13.dat --baudrate=9600 --rigctl-port=4532 --gain-mode=Overall --gain=48.0 --antenna=RX --enable-iq-dump=1 --iq-file-path=/tmp/.satnogs/iq.raw --decoded-data-file-path=/tmp/.satnogs/data/data_2095409
ββ31928 /usr/bin/python3 /usr/bin/satnogs_bpsk_ax25.py --soapy-rx-device=driver=rtlsdr --samp-rate-rx=2.048e6 --rx-freq=437126350 --file-path=/tmp/.satnogs/data/receiving_satnogs_2095138_2020-04-25T12-33-07.out --waterfall-file-path=/tmp/.satnogs/data/receiving_waterfall_2095138_2020-04-25T12-33-07.dat --baudrate=1200 --rigctl-port=4532 --gain-mode=Overall --gain=48.0 --antenna=RX --enable-iq-dump=1 --iq-file-path=/tmp/.satnogs/iq.raw --decoded-data-file-path=/tmp/.satnogs/data/data_2095138
ββ32202 /usr/bin/python3 /usr/bin/satnogs_fsk_ax25.py --soapy-rx-device=driver=rtlsdr --samp-rate-rx=2.048e6 --rx-freq=437445000 --file-path=/tmp/.satnogs/data/receiving_satnogs_2095142_2020-04-25T13-01-26.out --waterfall-file-path=/tmp/.satnogs/data/receiving_waterfall_2095142_2020-04-25T13-01-26.dat --baudrate=9600 --rigctl-port=4532 --gain-mode=Overall --gain=48.0 --antenna=RX --enable-iq-dump=1 --iq-file-path=/tmp/.satnogs/iq.raw --decoded-data-file-path=/tmp/.satnogs/data/data_2095142
ββ32375 /usr/bin/python3 /usr/bin/satnogs_fsk_ax25.py --soapy-rx-device=driver=rtlsdr --samp-rate-rx=2.048e6 --rx-freq=436250000 --file-path=/tmp/.satnogs/data/receiving_satnogs_2095962_2020-04-25T13-23-36.out --waterfall-file-path=/tmp/.satnogs/data/receiving_waterfall_2095962_2020-04-25T13-23-36.dat --baudrate=4800 --rigctl-port=4532 --gain-mode=Overall --gain=48.0 --antenna=RX --enable-iq-dump=1 --iq-file-path=/tmp/.satnogs/iq.raw --decoded-data-file-path=/tmp/.satnogs/data/data_2095962
Apr 25 20:30:30 satnogs-fhab-1 satnogs-client[318]: apscheduler.scheduler - WARNING - Execution of job "post_data (trigger: interval[0:02:00], next run at: 2020-04-25 20:30:30 UTC)" skipped: maximum number of running instances reached (1)
Apr 25 20:31:30 satnogs-fhab-1 satnogs-client[318]: apscheduler.scheduler - WARNING - Execution of job "get_jobs (trigger: interval[0:01:00], next run at: 2020-04-25 20:31:30 UTC)" skipped: maximum number of running instances reached (1)
Apr 25 20:32:30 satnogs-fhab-1 satnogs-client[318]: apscheduler.scheduler - WARNING - Execution of job "get_jobs (trigger: interval[0:01:00], next run at: 2020-04-25 20:32:30 UTC)" skipped: maximum number of running instances reached (1)
Apr 25 20:32:30 satnogs-fhab-1 satnogs-client[318]: apscheduler.scheduler - WARNING - Execution of job "post_data (trigger: interval[0:02:00], next run at: 2020-04-25 20:32:30 UTC)" skipped: maximum number of running instances reached (1)
Apr 25 20:33:30 satnogs-fhab-1 satnogs-client[318]: apscheduler.scheduler - WARNING - Execution of job "get_jobs (trigger: interval[0:01:00], next run at: 2020-04-25 20:33:30 UTC)" skipped: maximum number of running instances reached (1)
Apr 25 20:34:30 satnogs-fhab-1 satnogs-client[318]: apscheduler.scheduler - WARNING - Execution of job "get_jobs (trigger: interval[0:01:00], next run at: 2020-04-25 20:34:30 UTC)" skipped: maximum number of running instances reached (1)
Apr 25 20:34:30 satnogs-fhab-1 satnogs-client[318]: apscheduler.scheduler - WARNING - Execution of job "post_data (trigger: interval[0:02:00], next run at: 2020-04-25 20:34:30 UTC)" skipped: maximum number of running instances reached (1)
Apr 25 20:35:30 satnogs-fhab-1 satnogs-client[318]: apscheduler.scheduler - WARNING - Execution of job "get_jobs (trigger: interval[0:01:00], next run at: 2020-04-25 20:35:30 UTC)" skipped: maximum number of running instances reached (1)
Apr 25 20:36:30 satnogs-fhab-1 satnogs-client[318]: apscheduler.scheduler - WARNING - Execution of job "get_jobs (trigger: interval[0:01:00], next run at: 2020-04-25 20:36:30 UTC)" skipped: maximum number of running instances reached (1)
Apr 25 20:36:30 satnogs-fhab-1 satnogs-client[318]: apscheduler.scheduler - WARNING - Execution of job "post_data (trigger: interval[0:02:00], next run at: 2020-04-25 20:36:30 UTC)" skipped: maximum number of running instances reached (1)
Support information:
"versions": {
"satnogs-client": "1.3.1",
"satnogs-client-ansible": "202004031132",
"satnogs-flowgraphs": "1.1.1-1",
"gr-satnogs": "2.1.2-1",
"gr-soapy": "2.1.2-1",
"gnuradio": "3.8.1.0~rc1-2",
"satnogs-config": "0.10.1"
"state": {
"is-applied": true,
"pending-tags": null
"system": {
"distribution": {
"DESCRIPTION": "Raspbian GNU/Linux 10 (buster)",
"RELEASE": "10",
"CODENAME": "buster",
"ID": "Raspbian"
"pending-updates": true,
"platform": {
"system": "Linux",
"node": "satnogs-fhab-1",
"release": "4.19.97-v7l+",
"version": "#1294 SMP Thu Jan 30 13:21:14 GMT 2020",
"machine": "armv7l",
"processor": ""
"memory": {
"total": 4095750144,
"available": 3621396480,
"percent": 11.6,
"used": 202539008,
"free": 3086618624,
"active": 479145984,
"inactive": 335114240,
"buffers": 126664704,
"cached": 679927808,
"shared": 127479808,
"slab": 88653824
"disk": {
"total": 30142779392,
"used": 5157044224,
"free": 23714934784,
"percent": 17.9
"configuration": {
"enable_iq_dump": true,
"hamlib_utils_rot_enabled": false,
"iq_dump_filename": "/tmp/.satnogs/iq.raw",
"satnogs_antenna": "RX",
"satnogs_post_observation_script": "/usr/local/bin/satnogs-post {{ID}} {{FREQ}} {{TLE}}",
"satnogs_rf_gain": 48.0,
"satnogs_rx_device": "rtlsdr",
"satnogs_station_elev": 67,
"satnogs_station_id": 1272,
"satnogs_station_lat": 56.82,
"satnogs_station_lon": 12.89
Shutting down the service took almost 2 minutes (I ran the stop command at 20:37:35):
pi@satnogs-fhab-1:~ $ sudo systemctl stop satnogs-client.service
pi@satnogs-fhab-1:~ $ systemctl status satnogs-client.service
Active: failed (Result: timeout) since Sat 2020-04-25 20:39:06 UTC; 32s ago
Process: 318 ExecStart=/var/lib/satnogs/bin/satnogs-client (code=killed, signal=TERM)
Main PID: 318 (code=killed, signal=TERM)
Apr 25 20:39:06 satnogs-fhab-1 systemd[1]: satnogs-client.service: Killing process 774 (satnogs_cw_deco) with signal SIGKILL.
Apr 25 20:39:06 satnogs-fhab-1 systemd[1]: satnogs-client.service: Killing process 1195 (satnogs_cw_deco) with signal SIGKILL.
Apr 25 20:39:06 satnogs-fhab-1 systemd[1]: satnogs-client.service: Killing process 1380 (satnogs_fsk_ax2) with signal SIGKILL.
Apr 25 20:39:06 satnogs-fhab-1 systemd[1]: satnogs-client.service: Killing process 1507 (satnogs_cw_deco) with signal SIGKILL.
Apr 25 20:39:06 satnogs-fhab-1 systemd[1]: satnogs-client.service: Killing process 1659 (satnogs_fsk_ax2) with signal SIGKILL.
Apr 25 20:39:06 satnogs-fhab-1 systemd[1]: satnogs-client.service: Killing process 1819 (satnogs_fsk_ax2) with signal SIGKILL.
Apr 25 20:39:06 satnogs-fhab-1 systemd[1]: satnogs-client.service: Killing process 1935 (satnogs_fsk_ax2) with signal SIGKILL.
Apr 25 20:39:06 satnogs-fhab-1 systemd[1]: satnogs-client.service: Killing process 2268 (satnogs_fsk_ax2) with signal SIGKILL.
Apr 25 20:39:06 satnogs-fhab-1 systemd[1]: satnogs-client.service: Failed with result 'timeout'.
Apr 25 20:39:06 satnogs-fhab-1 systemd[1]: Stopped SatNOGS client.
The only things that look odd in /var/log/syslog are these:
Apr 25 05:39:26 satnogs-fhab-1 satnogs-client[318]: apscheduler.executors.default - WARNING - Run time of job "get_jobs (trigger: interval[0:01:00], next run at: 2020-04-25 05:39:30 UTC)" was missed by 0:00:55.708387
Apr 25 05:39:26 satnogs-fhab-1 satnogs-client[318]: apscheduler.executors.default - WARNING - Run time of job "post_data (trigger: interval[0:02:00], next run at: 2020-04-25 05:40:30 UTC)" was missed by 0:00:55.709994
Apr 25 06:20:32 satnogs-fhab-1 satnogs-client[318]: usb_claim_interface error -6
Apr 25 06:20:32 satnogs-fhab-1 satnogs-client[318]: [INFO] Using format CF32.
Apr 25 07:42:28 satnogs-fhab-1 satnogs-client[318]: usb_claim_interface error -6
Apr 25 07:42:28 satnogs-fhab-1 satnogs-client[318]: [INFO] Using format CF32.
Apr 25 09:24:25 satnogs-fhab-1 satnogs-client[318]: usb_claim_interface error -6
Apr 25 09:24:25 satnogs-fhab-1 satnogs-client[318]: [INFO] Using format CF32.
Apr 25 09:46:02 satnogs-fhab-1 satnogs-client[318]: usb_claim_interface error -6
Apr 25 09:46:02 satnogs-fhab-1 satnogs-client[318]: [INFO] Using format CF32.
<more of the usb_claim errors>
Apr 25 18:22:17 satnogs-fhab-1 satnogs-client[318]: usb_claim_interface error -6
Apr 25 18:22:17 satnogs-fhab-1 satnogs-client[318]: [INFO] Using format CF32.
Apr 25 18:23:30 satnogs-fhab-1 satnogs-client[318]: apscheduler.scheduler - WARNING - Execution of job "get_jobs (trigger: interval[0:01:00], next run at: 2020-04-25 18:23:30 UTC)" skipped: maximum number of running instances reached (1)
Apr 25 18:24:02 satnogs-fhab-1 CRON[2313]: (pi) CMD (~/upnp.sh)
Apr 25 18:24:02 satnogs-fhab-1 CRON[2309]: (CRON) info (No MTA installed, discarding output)
Apr 25 18:24:30 satnogs-fhab-1 satnogs-client[318]: apscheduler.scheduler - WARNING - Execution of job "get_jobs (trigger: interval[0:01:00], next run at: 2020-04-25 18:24:30 UTC)" skipped: maximum number of running instances reached (1)
Apr 25 18:24:30 satnogs-fhab-1 satnogs-client[318]: apscheduler.scheduler - WARNING - Execution of job "post_data (trigger: interval[0:02:00], next run at: 2020-04-25 18:24:30 UTC)" skipped: maximum number of running instances reached (1)
Apr 25 18:25:01 satnogs-fhab-1 CRON[2328]: (pi) CMD (~/duckdns/duck.sh >/dev/null 2>&1)
Apr 25 18:25:30 satnogs-fhab-1 satnogs-client[318]: apscheduler.scheduler - WARNING - Execution of job "get_jobs (trigger: interval[0:01:00], next run at: 2020-04-25 18:25:30 UTC)" skipped: maximum number of running instances reached (1)
Apr 25 18:26:30 satnogs-fhab-1 satnogs-client[318]: apscheduler.scheduler - WARNING - Execution of job "get_jobs (trigger: interval[0:01:00], next run at: 2020-04-25 18:26:30 UTC)" skipped: maximum number of running instances reached (1)
Apr 25 18:26:30 satnogs-fhab-1 satnogs-client[318]: apscheduler.scheduler - WARNING - Execution of job "post_data (trigger: interval[0:02:00], next run at: 2020-04-25 18:26:30 UTC)" skipped: maximum number of running instances reached (1)
Apr 25 18:27:30 satnogs-fhab-1 satnogs-client[318]: apscheduler.scheduler - WARNING - Execution of job "get_jobs (trigger: interval[0:01:00], next run at: 2020-04-25 18:27:30 UTC)" skipped: maximum number of running instances reached (1)
Apr 25 18:28:30 satnogs-fhab-1 satnogs-client[318]: apscheduler.scheduler - WARNING - Execution of job "get_jobs (trigger: interval[0:01:00], next run at: 2020-04-25 18:28:30 UTC)" skipped: maximum number of running instances reached (1)
Apr 25 18:28:30 satnogs-fhab-1 satnogs-client[318]: apscheduler.scheduler - WARNING - Execution of job "post_data (trigger: interval[0:02:00], next run at: 2020-04-25 18:28:30 UTC)" skipped: maximum number of running instances reached (1)
Apr 25 18:29:30 satnogs-fhab-1 satnogs-client[318]: apscheduler.scheduler - WARNING - Execution of job "get_jobs (trigger: interval[0:01:00], next run at: 2020-04-25 18:29:30 UTC)" skipped: maximum number of running instances reached (1)
After starting the service again, the station came up online according to the dashboard.
Any idea what went wrong? Anything I can do to prevent this from happening again, or at least recover quicker?
