Unfortunately the next orbits, that are crucial to fit and fix the TLE, are above areas without many stations, and on those that they are scheduled the passes are very low. Let’s see if we will manage to get any other successful pass. ![]()
And here is a TLE update after the pass over Europe:
RSP-03
1 65732U 98067XL 26047.10675481 .00000000 00000-0 83701-3 0 09
2 65732 51.6084 155.5768 0007960 327.1992 93.7217 16.34509093 00
sites.txt (12.7 KB)
rsp03_046_v13.dat (1.7 KB)
Re-calculated with another method the data and here is a better TLE set:
RSP-03
1 65732U 98067XL 26047.10673979 .00000000 00000-0 11704-2 0 02
2 65732 51.6084 155.6935 0007960 327.1992 93.6127 16.36147342 03
One more update after the latest pass over Europe:
RSP-03
1 65732U 98067XL 26047.10688430 .00000000 00000-0 11689-2 0 02
2 65732 51.6084 155.6281 0007960 327.1992 94.4397 16.35634604 06
rsp03_047_v2.dat (2.2 KB)
sites.txt (12.7 KB)
One more update from the pass over East Asia:
RSP-03
1 65732U 98067XL 26047.18379986 .00000000 00000-0 11645-2 0 05
2 65732 51.6084 155.2121 0007960 327.1992 187.8569 16.37215120 03
sites.txt (12.7 KB)
rsp03_047_v3.dat (2.6 KB)
A small fix from the pass over Australia:
RSP-03
1 65732U 98067XL 26047.19473898 .00000000 00000-0 10281-2 0 08
2 65732 51.6084 156.0049 0007960 327.1992 251.8078 16.36594183 06
rsp03_047_v5.dat (2.1 KB)
sites.txt (12.7 KB)
One more TLE from the pass over Europe:
RSP-03
1 65732U 98067XL 26047.23394127 .00000000 00000-0 10736-2 0 05
2 65732 51.6084 155.8774 0007960 327.1992 123.0313 16.37953545 02
sites.txt (12.7 KB)
rsp03_047_v6.dat (2.3 KB)
TLE update using the observations from the pass over Australia:
RSP-03
1 65732U 98067XL 26047.25808867 .00000000 00000-0 10520-2 0 09
2 65732 51.6084 154.8865 0007960 327.1992 266.2127 16.39211244 00
rsp03_047_v7.dat (2.7 KB)
sites.txt (12.7 KB)
07:03 - 07:08 UTC 40° elevation, 174 km
no sig
TLE from observations over Europe:
RSP-03
1 65732U 98067XL 26047.25808867 .00000000 00000-0 10192-2 0 04
2 65732 51.6084 154.9028 0007960 327.1992 266.2140 16.39217085 06
sites.txt (12.7 KB)
rsp03_047_v8.dat (3.2 KB)
There is also a TLE from space-track.org:
0 OBJECT XL
1 65732U 98067XL 26047.15751462 .08209638 12383-4 92064-3 0 9994
2 65732 51.6063 155.3995 0006813 323.5269 36.5291 16.36188855 23531
However it seems to be already deprecated.
Using the last data, a small fix:
RSP-03
1 65732U 98067XL 26047.25808867 .00000000 00000-0 10379-2 0 01
2 65732 51.6084 154.8920 0007960 327.1992 266.1430 16.38963739 00
By @tammojan and the latest decodes from the Dwingeloo observation, it seems that the voltage is at 7V, which is near the limit. Let’s see if it manages to decode until the end. ![]()
No surprise, but nothing seen over the Eastern U.S. 0823utc; max EL would have been 49°.
Thanks for coordinating the final orbits - very interesting & a lot of fun.
Very clear signals heard on the 8:34 pass over the Dwingeloo telescope. Unfortunately the satnogs recording failed, so no decodes ![]()
TLE from passes over North America:
RSP-03
1 65732U 98067XL 26047.31479485 .00000000 00000-0 10263-2 0 00
2 65732 51.6084 154.5219 0007960 327.1992 241.2339 16.41071241 02
rsp03_047_v10.dat (3.6 KB)
sites.txt (12.7 KB)
The final “G”-telemetry from Europe - 25KHz low, seems to speed up now …
Thanks Fredy for the great TLE-support!
73, Stefan/OE6ISP - now QRT
One more update:
RSP-03
1 65732U 98067XL 26047.36072123 .00000000 00000-0 10263-2 0 03
2 65732 51.6084 154.2580 0007960 327.1992 152.8940 16.43074434 04
sites.txt (12.7 KB)
rsp03_047_v12.dat (2.9 KB)
