Hi
I notice a few are using a 433mhz QFH antennas. I have built a 144mhz QFH and it works great.
Does anyone have designs for the 433Mhz QFH? I have a heap of 6mm copper tube to use!!
Thanks in advance
Brennan ZL4VBJ
Hi
Thanks in advance
Brennan ZL4VBJ
Hi Brennan,
for designing my 144 Mhz QFH, I used the following QFH calculator:
http://jcoppens.com/ant/qfh/calc.en.php
For me that worked fine.
Hope that helps for making your 433 MHz version!
best regards,
Hauke DH4CK
Thanks, ill give it a try
@ZL4VBJ take a look at a thread by @surligas -3d printed 433Mhz QFH antenna a while back An easy 3D printed quadrifilar helix antenna
I used jcoppens.com as well for all my QFH antennas. For UHF I made it from 3mm copper wire and stacked it on top of the 2m QFH. This is for receiving only with LNA4ALL.
I build another stacked pair for Transmitting and used the 6mm copper tubing for both.
