Nothing heard here either on the 0852UTC pass over UK.
Also at 08:52 until 09:00 UTC no signals on max. 24° elevation pass.
Most of the observations I had scheduled for BGSARPIT shows a strong presence of signal in the waterfall but nothing heard in the audio. Can anyone help me understand what this could be.
https://network.satnogs.org/observations/10925194/
https://network.satnogs.org/observations/10925270/
https://network.satnogs.org/observations/10925255/
https://network.satnogs.org/observations/10925192/
https://network.satnogs.org/observations/10925191/
https://network.satnogs.org/observations/10925190/
and many more…
The signals are QRM or QRN or from other satellites and sometimes out of the filter.
"BGS ARPIT (POEM-4) is turned ON and will be available until 07:00 UTC on Jan 19th 2025.Please submit your reception reports to info@amsatindia.org or vu3tyg@yahoo.co.in
Time ‘Switch OFF’ : 07:00 UTC, January 19th
Object : POEM-4
Payload : BGS ARPIT
NORAD No : 62461
Frequency : 145.870 MHz (IARU Coordinated)
Mode : NFM
Data :
- 1. Pre recorded audio message
- 2. Greeting Message & limited TM in APRS Packet format
- 3. Pre loaded SSTV Images "
The post was made on Twitter/X and can be seen HERE
62° pass of the POEM-4 module 1753utc (18-Jan); unfortunately nothing heard 145.825 or 145.870 over the Eastern U.S.
Same same here in Brazil
However, it was a low pass for my QTH (about 12 degrees elevation)
"BGS ARPIT is turned ON from 10:52 UTC FEB 4th . The payload will be kept ON continiously for global coverage.Please submit your reception reports to info@amsatindia.org or vu3tyg@yahoo.co.in
Object : POEM-4
Payload : BGS ARPIT
NORAD No : 62461
Mode : NFM Data
- Pre recorded audio message:
- Greeting Message & limited TM in APRS Packet format:
- Pre loaded SSTV Images"
The post was made on Twitter/X and can be seen HERE (Nitter HERE)
Pity all passes over my qth overnight - 11pm to 5am ![]()
BGS ARPIT / POEM-4:
82° pass over the Eastern U.S. around 0348utc - no signals of any kind seen on 145.870
