I have been experimenting with a UHF Parasitic Lindenblad build based on this AMSAT article. The hope is to create an easily built (with 3D printer) antenna with good reception for a non-rotator setup.
This antenna will soon go live in @fredy 's ground station for testing.
Antenna works good, especially on low degrees passes. The lowest elevation at which I received signal was on 3 degrees and I’m surrounded by buildings and some mountains on the background.
You can have a look at results on dev-network (don’t be confused by the photo, I haven’t updated it with the new setup).
I’ll make a post with more details on my station and its performance after finished some more experiments. Hopefully will be ready soon to be moved on production network.
Unfortunately I had some issues and it went off and I haven’t managed to get it online. However I’m planning in the next days to get it up again. From what I remember, the performance (with an LNA) it was fair enough for my noisy environment.
I haven’t construct it, maybe @BOCTOK-1 can point us to the 3d designs.
Nice job! That is the exact same article that I used to build my Lindenblad, currently on station 663 (KB4NKO - Jonesboro, VA). It performs well, especially for a stationary antenna. I can confirm that it even does well at low passes. I like seeing the 3-D printing as well. I would recommend that you publish your STLs on Thingiverse.
My UHF station uses this antenna. No LNA, indoors (attic). It’s ok, but really not what I’d hoped. But I suspect that my expectations were WAY too high. I would like to move it outdoors at some point to see how much that improves the reception.
