So I am curious as to how M-2 works, and if the decoder works automatically, etc… so I scheduled a few observations on my 2m station. Dimitris has marked it good, and honestly I cannot see anything there. Am I missing something? Can somebody point me to a really good waterfall image of M-2?
It should be worth noting that generally my station has no hope to pick up a 0° pass, and this one was only scheduled because it was lumped in with all passes over my station (with no minimum elevation).
Ok, that’s what I thought (regarding the decoder). However, I am still curious about the waterfall: Is the observation you linked above really what the downlink looks like (a 50kHz wide fuzzy cloud)?
Something to note is if you are not running the custom meteor-m2 flowgraph, the default waterfall bandwidth used is only 48 khz wide. The Meteor-m2 signal is about 50 kHz wide, so you only see it as an apparent rise in the noise floor, just like what you see in observation #424190.
More my problem than anyones… The flowgraph i’m talking about is not in gr-satnogs - it’s an extra one in https://github.com/darksidelemm/satnogs-extras which does the meteor-m2 QPSK decoding.
The actual processing of the QPSK soft-bits into imagery doesn’t run in real-time, so that part is done as a post-processing script. Hence, it hasn’t ever been included in gr-satnogs as it doesn’t fit the real-time processing aims. I believe someone was working on a ‘live’ meteor m-2 decoder, but I don’t know the status of it.
Apart from PJM’s instructions at the top of this thread ( Meteor MN2 decoder for rpi 3B+ ) there isn’t really much else I can point to. Those instructions link to an old version of the flowgraph script too, and may have other errors.
I did have intentions on producing a patch-set which could be applied to a working SatNOGS install, but haven’t had time to work on it.
