Hello,
Regarding Observation 4965181 … it appears to show a strong signal, any idea as to why there is not any decoded data?
Thanks, Abraham-XE3ADC
Native SatNOGS has no decoder for CubeSX-HSE.
Have a look at satnogs_gr-satellites, there is also a post on this community for more details and experiences.
And yes the signal is strong enough to be decoded, here some output:
# Decoding Satellite 47952.
-> Packet from 2k4 FSK downlink
Container:
header = Container:
addresses = ListContainer:
Container:
callsign = u'R2ANF' (total 5)
ssid = Container:
ch = False
ssid = 0
extension = False
Container:
callsign = u'RS13S' (total 5)
ssid = Container:
ch = False
ssid = 4
extension = True
control = 0x00
pid = 0xF0
info = b'\x16B\x02\x00\x01\x00B\x00\x07\x00\x05\x00\x05\x00\x01\x00\x01\x00\x01\x00\xf5\xff\x00\x00\x1e\x00\x00\x00\x00\x00\x03\x00\x03\x00\x02\x00\x03\x00\x00 \x00\x00\xec\x1e\x8e%\x18\x00\x85\x0c\x86a\xe1\x04\x03\x02\xff~"\x13I\x0e\x86\x0c\x86a\x14\x1f\x18\x00\x1e\x00\xfc\x1e' (total 74)
Thanks for the info!!, I’ll follow up on satnogs_gr-satellites…I gather you use gr-satellites with the observation’s ogg file to obtain the decode, right?
best regards de XE3ADC, Abraham
You can use the ogg file direct with GNURadio 3.9 and gr_satellites but if you use GNURadio 3.8 and gr_satellites you first need to convert the ogg file to a wav.
This can be done with ffmpeg -i <input file.ogg> <output_file.wav> then you can execute:
gr_satellites <norad id> --wavfile <audio file.ogg> --samp_rate 48e3 or
gr_satellites <norad id> --wavfile <audio file.wav> --samp_rate 48e3
gr_satellites --list_satellites will show you al list with all supported satellites.
Community article on the satnogs gr-satellites integration
