Install the satnogs_gr-satellites "addon" and use your station more!
Hi all station operators!
I can recommend the satnogs_gr-satellites “add-on” from @SA2KNG to be able to decode even more satellites with your SatNOGS station.
The installation is very simple, even for a non-Linux person like myself.
//Lars SM0TGU
https://network.satnogs.org/stations/858/
After updating my station to the latest build and installing satnogs_gr-satellites, I now see demodulated data for NAYIF-1! https://network.satnogs.org/observations/4231963/
@graems Great! I hope more station owners will follow.
/Lars
I tried to install the addon. When I try “gr_satellites --version” I get the following messages back:
pi@satnogs:~ $ gr_satellites --version
File “/usr/local/bin/gr_satellites”, line 16, in
import satellites.core
File “/usr/local/lib/python3/dist-packages/satellites/init.py”, line 49, in
from .adsb_kml import adsb_kml
File “/usr/local/lib/python3/dist-packages/satellites/adsb_kml.py”, line 15, in
from .telemetry import gomx_3 as tlm
File “/usr/local/lib/python3/dist-packages/satellites/telemetry/init.py”, line 19, in
import construct
ModuleNotFoundError: No module named ‘construct’
pi@satnogs:~ $
I did this course:
If you get the error: ModuleNotFoundError: No module named ‘satellites’
You can add this to ~/.bashrc : export PYTHONPATH=/usr/local/lib/python3/dist-packages/
This is the output of echo $PATH:
/home/pi/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
I have a log file of the complete installation process for the one who is able to figure out what’s going on here.
Sorry but I do not know what the problem can be. Maybe @SA2KNG can help?
/Lars
Looks like the installation of python module construct is not working, or not installed.
Follow the instruction on Installing from source — gr-satellites 5.6.0-git documentation
pip3 install --user --upgrade construct requests
There’s also a possibility to install it from the distribution package, but will depend heavily on what dist you’re using. In debian it’s called python3-construct and can be installed with:
sudo apt-get install python3-construct
I’m sure I checked whether construct is installed or not. But it was not installed.
gr_satellites --version is working now.
I’m using the Satnogs Raspberry Pi image, which only has Gnuradio 3.7. gr_satellites requires Gnuradio 3.8+. I tried installing the Gnuradio repository (sudo add-apt-repository ppa:gnuradio/gnuradio-releases) but got “Error: could not find a distribution template for Raspbian/buster”. https://wiki.gnuradio.org/index.php/InstallingGR#Raspberry_Pi suggests installing Gnuradio from source. Is that what you did, or is there a better way to get gr_satellites running?
A big thanks to https://community.libre.space/u/sa2kng!
This is the 1st observation with gr_satellites on my satnogs stn: https://network.satnogs.org/observations/4265966/
Very nice! 73, DL8LAQ
My satnogs client version is 1.5.1 and I just followed this installation procedure https://github.com/kng/satnogs_gr-satellites/blob/main/INSTALL.md
That’s all I did to get gr_satellites running!
Thanks. That’s the guide I used as well, but cmake .. resulted in
By not providing "FindGnuradio.cmake" in CMAKE_MODULE_PATH this project has
asked CMake to find a package configuration file provided by "Gnuradio",
but CMake did not find one.
which lead me down the path of trying to get a more recent version of gnuradio.
But just now I tried clearing the build directory and running cmake again. This time it was successful. I don’t know what has changed, but something of all the stuff I tried the last day seems to have fixed it. Currently running make which will take a while. I’ll report back.
Everything seems to be working now.
The script overwrote my existing post observation script but after editing /usr/local/bin/satnogs-post to call my script as well as the gr-satellites script, everything seems to be in order. gr-satellites logs the following:
gr-satellites: Observation: 4269435, Norad: 43743, Name: REAKTOR_HELLO_WORLD, Script: satnogs_reaktor_hello_world_fsk9600_decoder.py
gr-satellites: Starting observation 4269435
gr-satellites: running at 57600 sps
Also for me it works fine. Only had to replace some spaces with tabs in a Makefile. But it shows a suggestion.
Observation:
https://network.satnogs.org/observations/4271692/
Thanks people for the hard work! :smiley:
Best regards Eelke.
I forgot to mention this too!
Me too :smiley: I used sed -i Makefile -e 's/ /\t/g' (8 spaces between the first and second /)
For those with UHF-only ground stations (like me!), satnogs_gr_satellites does not currently include active UHF satellites although this will probably change in the future.
SELECTED="39444 44830 43803 42017 44832 40074"
These two inactive UHF satellites were recycled by the Earth’s upper atmosphere:
ALT-1 44830 on 437.175 Mhz (successful atmospheric re-entry Oct 2020)
SMOG-P 44832 on 437.175 Mhz (successful atmospheric re-entry late Sept 2020)
Time to rebuild my VHF QFH :grinning:
And thanks for the tips on the makefile!
You can edit the SELECTED parameter and add (or remove) the satellites you would like to process with satnogs_gr_satellites.
/Lars
Thanks, Lars. My understanding is limited for this software.
Was satnogs_gr_satellites meant to be an alternative way of decoding frames (IQ stream → UDP)? That is, can this add-on be used to decode all the satellites that satnogs-client already decode but uses a different flowgraph? Or is it meant to fill the gap of satellites that the satnogs-client (v1.4x or v1.5.x) cannot currently decode?
I think better @SA2KNG answer that question. I just happy for this super add-on and all the work that has been done.
/L
Agreed, thanks to the SatNOGS community for this and all that is contributed!
