Jan, PE0SAT, has published a new type of transmitter for the DIY-1, FSK 500 BD, but I think it is wrongly set for downloading and decoding the recording. I leave you a recording in which the RTTY FM mode is used.
I hope the FSK 500BD mode setting can be corrected for the benefit of all.
After several tests with the configuration of the transmitter 2 mode U-FSK 500 B, I recommend deleting it since it was impossible to rescue data of the audio.
Seems to work fine. I’m looking at the possibility of making a dashboard now that the uz7ho software has given us that possibility. Do I need a special permit?
@LW2DTZ for getting a dashboard, first we need to create the decoder that will decode the data in DB and make them available in the grafana dashboards.
For permissions to Dashboard, you first need to login in dashboard.satnogs.org (with the same credential you login here) and let us know so we can create a team for DIY satellite team, give the necessary permissions and add you as member of the team.
It would be nice for the initial dashboard if you could provide an image of the satellite.
Nvm if you don’t have one at the moment, I just added the default DB image for it!
If you have data already that you could provide to satnogs-db: please start feeding it! The decoder is on its way to be deployed!
