Regarding Observation 300186 … will someone vett this properly?
To update your vetting of this observation, please visit
http://network.satnogs.org/observation_vet/300186/good/
- Good
You should mark observations as “Good” when it is clear from the waterfall and/or audio recording that a satellite is present.- Bad
You should mark observations as “Bad” when by examining the waterfall and/or audio it is obvious that there was no satellite detected in this observation.:- Failed
You should mark observations as “Failed” when the station failed entirely: the waterfall and/or audio is empty or not present, or there’s too much noise.
There are different noise sources in the waterfall, nevertheless the signal is visible.
I think they are testing their ML algorithm again.
It would be less stressful for others if they do this on network-dev.
I am very sorry to cause troubles. This was me trying to support, please see by comment at
Greetings
Ansgar
