Observation 13875540: RADIO ROSTO (23439)
Regarding Observation 13875540 …
Is there any way to tune in to the SSB conversations on these downloads of the linear satellites? Looks like one was about 7khz down from center on this one.
the best solution is to enable iq raw
enable-iq-dump: “0” set to “1” or true
but i should question what method did you install your ground station. if you install it with manual docker, that is correct path and i will tell you the next step..
