KD9KCK
October 19, 2022, 5:30pm
1
After discussing about the current issue with NOAA-15 on the main SatNOGS Matrix channel I decided it was best to dump all the information I have come up with so far.
Based on looking thru twitter it appears the that issue began around 00:00 UTC on October the 19th 2022
This is the first instance I could find when I search up NOAA-15 on twitter. So I am considering it the start time of the issue. https://twitter.com/octacons/status/1582524383431491584
Before this the sat appeared to be working properly, https://twitter.com/rsun0525/status/1582516521447874562 From someone else’s twitter.
This time line can be backed up with observations from the network that display the issue. SatNOGS Network - Observation 6631098
SatNOGS Network - Observation 6630204
While these observations do not.
https://network.satnogs.org/observations/6627439/
https://network.satnogs.org/observations/6630551/
KD9KCK
October 19, 2022, 5:32pm
2
Information on how the sensors on board NOAA-15 can be found in NOAA’s Product Guide for the series of satellites. ncei.noaa.gov/pub/data/satellite/publications/podguides/N-15%20thru%20N-19/pdf/2.0%20Section%203.0%20Description%20of%20the%20NOAA%20KLM%20Sensor%20Package.pdf
Along with an image created by @dereksgc that they shared in the Martix room showing the data path for all the sensors.
KD9KCK
October 19, 2022, 6:25pm
3
Linking in Scott Tilley’s twitter post with a GAC pass he captured just about 3 hours after when I think the fault first occurred. https://twitter.com/coastal8049/status/1582791478157643777
Recorded both HRPT and APT data, here are all the channels aligned for reference
Managed to capture the moment of failure.
00:57 19-Oct-2022 - 01:08 19-Oct-2022
KD9KCK
October 23, 2022, 5:53pm
6
Looks like it’s back to normal again.
00:28 28-Oct-2022 - 00:41 28-Oct-2022
KD9KCK
October 28, 2022, 6:09pm
8
Latest looks a bit messed up still
https://network.satnogs.org/observations/6669399/
I think its on the very edge of working properly.
Appears to have recovered sometime between 2022-10-27 17:30 UTC and 2022-10-27 19:30
Still messed up SatNOGS Network - Observation 6661423
Working properly SatNOGS Network - Observation 6666144
