DL2ZZ
March 1, 2021, 11:55am
#1
There is a satellite, which is just as of last week having public TLEs:
CubeL (Norad 47448)
3D Mission Animation of PIXL-1 (with CubeLCT) - YouTube
Integrating the Cubesat Space Protocol into GSOC’s Multi-Mission Environment
According to ITU filings, it has an UHF transponder with 437.16 MHz (±10 kHz) assign.
Would it be possible to add this satellite to the database, so one can do further analysis on the waveform?
73 de DL2ZZ
can you please point us to the source of this info?
From here i can only see TX at 401Mhz.
Nevertheless I added the satellite with no transmitters for now:
DL2ZZ
March 1, 2021, 3:43pm
#3
thanks for adding it. my info comes from:
Space Services Department (SSD) - SNL Part B - Query result (itu.int)
ntc_id
emi_rcp
beam_name
grp_id
seq_no
freq_sym
freq_assgn
freq_mhz
freq_min
freq_max
120545040
R
U1UHFU
120616298
1
M
437.16
437.16
437.15
437.17
120545040
E
U1BEACON
120616297
1
M
437.16
437.16
437.15
437.17
120545040
E
U1UHFD
120616296
1
M
437.16
437.16
437.15
437.17
I really really hope those are wrong Feel free to suggest the transmitter on DB so I can approve it and it will be available to the Network for scheduling.
Could those be the old API/A which then got modified? (the M note)
DL2ZZ
March 1, 2021, 4:10pm
#5
I think at the moment GomeSpace is doing LEOP, so this explains the non-ham frequencies. I guess they activate 437.16 MHz later. S-band is also to come later.
In that case we could also scan this on the 400 range. Please submit all those as transmitters on DB so we can track them.
DL2ZZ
March 1, 2021, 4:18pm
#7
I submitted the 400.575 MHz (probably LEOP) and 437.160 MHz in the database.
How do you do the scanning? Does that work with the SatNOGS scheduler?
I just approved them btw. They should be ready for scheduling in the Network now. (note: next time try to also assign a Modulation even if it is not a known one)
This is done with SatNOGS Network and locally too using the strf toolkit.
DL2ZZ
March 1, 2021, 4:28pm
#9
yes it appears in the scheduler, but claims not to have any TLEs.
Can you manually push a TLE update?
I will have a look at the strf toolkit, did not now about it, but sounds very handy according to the GitHub page.
OK I know now what was the confusion:
The beam_name and grp_id you posted are from UNICORN-1R API/A not from CUBEL.
Those IFICs include API, CR/NOTIF and other information for multiple missions.
I am removing the said transmitters from the DB. (but will be monitoring in 401 )
DL2ZZ
March 1, 2021, 5:41pm
#11
Well there is a signal in the first observation
DL2ZZ
March 1, 2021, 6:34pm
#12
I updated the transmitter to MSK AX.100 Mode 6 9600
Just a guess.
I saw you suggested a change from MSK to FSK. Please when you submit changed write a bit on the “citation needed” so we can review accordingly.
DL2ZZ
March 2, 2021, 8:18am
#15
yes, I will in the future. Figures 2 in:
2020 Roediger - High data-rate optical communication payload for CubeSats (dlr.de)
looks like a NanoCom SDR from GomSpace.
Looking at the spectrum and waveform:
it could be GMSK or GFSK with 9600 baud.
DL2ZZ
March 3, 2021, 2:21pm
#16
@pierros Gnuradio analysis confirm that it is GMSK 9600 with very likely RS. Can you please approve my transponder change? Thanks!
All done in DB! Thanks for checking.
DL2ZZ
March 3, 2021, 7:10pm
#19
hey @pierros would you active scratchpad access for me to create a dashboard? Thanks!
fredy
March 3, 2021, 7:45pm
#20
@DL2ZZ you should have the permissions to edit the scratchpad dashboards now.
