Hello,
The new cubesat Entrysat (ON2FR) will be launch from ISS next week. Is it possible to add the satelitte in the Database ? I will complete the transmitter part and the NoradID asap.
Just wondering. Does it have the FM rely mentioned in the IARU?
Also normally the administrators set up the transmitters in the DB and assign a temp noradID (Basically just so it can be scheduled on the network until its identified.)
Hello,
Unfortunately not … I arrived at the end of the project. When the Flight Model RF card (ISIS) have been purchased, the repeater option has been forgotten…
73,
Nicolas
Thank you for your fast answer. I will warn you about the right deployement datetime. As we are using nanorack, I assume that several cubesat will be deployed the same day.
I would like to start with a satnogs-decoder for your satellite!
Could you please provide some more informations on how to decode it?
Sampleframes would be great and, if possible, a little more description on the framing you are using. Sure you’re using AX.25 - but what exactly are you using inside the AX.25 packet? I’ve read about PUS but from a single sample frame it is hard to see what your implementation covers.
Hello Patrick,
Sorry I just come back from holidays. Happy that our cubesat is interesting for you. What do you plan to do exactly ?? The only PUS service for beacon mode is this one. Other HK are triggered by TC.
You are right, I made a mistake with call, it is F6KTA-0 !! I will correct the website.
Packet lenght is normaly the size of the packet field including TM data field header and the source data but I should double-checked, a byte is missing !!!
I didn’t understand your comment about time : a joke ???
Mode 01 is Orbital mode, beacon is still working in this mode
The AX.25 Time is a number of second since 2000/1/1 @ 00:00:100 in little endian. It is to timestamp the frame itself, the time upper is used to timestamp the informations of the informations.
there no mistake on the packet length. It is the count of bytes of the packet data field including the packet CRC minus one. In this case : 19 bytes from “10 : Spare/TM source packet number/ Space (fixed)” to “1f c6 : Packet CRC” minus 1 : 18 bytes or 0x0012 bytes
Frame Status is composed :
4 bits : b0 (MSB) to b3 : that give information of following Time : b0 (0: no time field; 1 : time field), b1 to b3 : size to time field in bytes + one. in this case : 1011 = 0xb
Yeah, well, that looks good! Proud to see this progress! My approach looks very similar, so maybe we could synchronize them to have a decoder for the data warehouse!
Be careful on using the bit types in kaitai - there is an issue with MSBit and LSBit. So please double check the results. If you run into trouble, I can give you some hints how to ship around this.
Hello fredy,
The deployement of EntrySat is scheduled tomorrow July 3th at 15h00 UTC. Is it possible to activate it in the system using the same TLE than ISS ???
