There is already a VHF Vertical and UHF Vertical antenna in the list, which reflect your antenna closely enough.
I really don’t see the point of the huge list of antennas currently present, which mostly represent similar things (vertical, yagi, turnstile, etc…) just with slightly different frequency ranges. It should really be a frequency range (or a set of ranges), and a custom description field where the operator can provide details.
I’m just getting into satellite reception, and as a newbie I would find it interesting to see statistics on which antennas are able to get the most decoded messages, sliced by the types of satellites and frequencies I am most interested in.
Hi Mark
I hadn’t realised I could just add in from the list , I thought you had to tell Satnogs specifics for some data collection about antenna types etc. Have changed this morning as you suggested.
Perhaps a better way is for a frequency range and a comment on the station page of vertical , dipole , Helical etc ? Also have the list by hf , vhf , uhf etc then the build type instead of one long jumbled list ?
As always great support from the satnogs community, looking forward to the iss sstv pass later today over Nz
