Jomjom79
just tried on the last pass over the UK but to low of a pass to get a good signal for me. on 24°
Got 3 noisy, partials from the 0853UTC AOS pass over UK; max elev c26deg so not best reception. In fact the best pass at my QTH during the activation period seems to be 41deg tomorrow morning. Anyway here’s the best of the 3 from this pass.
Monitor-3 26-Jan-25 0858UTC
26.01.25 - 10:28UTC
Max 32° el.
Second picture started out ok then the satellite dipped below the mountains to the SW.
Jomjom79
2025-01-26 12:26UTC (AI)
2025-01-26 12:29UTC (AI)
MN-3 over Brazil
(Unfortunately I started receiving in the middle of the first transmission)
In honor of the two-year stay in the orbit of the spacecraft of the NIIF MSU, a festive broadcast of images in the SSTV format is held.
SSTV transmission schedule from the MONITOR-3 (RS58S) satellite:
- Beginning of transmission: June 27, 2025 at ~ 09:00 UTC.
- Completion: June 29, 2025 at ~ 18:30 UTC.
The Format Is SSTV Robot 36.
The interval between transmissions is 120 seconds (can be adjusted later).
Attention! SSTV transmission can be interrupted if necessary! (increased temperature, discharged batteries, etc.)
Original post on R4UAB page (HERE)
Did they start the transmission early as its not yet 0900 UTC on the 27th?
Yeeep… For some reason the transmissions started much earlier
Got 3 images on the 1001+UTC pass over NW UK. This, the middle one, the best of the lot … and the best MONITOR-3 (RS58S) image I have received to date ![]()
Is there a qsl available for this satellite? Didn’t find anything on the R4UAB page.
No SSTV on pass 2025-06-29 11:2x UTC.
Transmission start: January 30, 2026 at ~09:00 UTC.
Transmission end: February 2, 2026 at ~ 18:30 UTC.
Format: SSTV Robot 36.
Interval between transmissions is 120 seconds (can be adjusted later).
Frequency of MKA “MONITOR-3 (RS58S)”
- 435.290 MHz GMSK 2k4 USP FEC, GMSK 4k8 USP FEC, GMSK 9k6 USP FEC, SSTV;
