I got MOG at observation #9969892. Transmission began approximately 6 minutes later than scheduled.
https://dashboard.satnogs.org/d/fbXCU8USz/kashiwa?orgId=1
In the aforementioned example, is the string of characters “a385c2650fe00001” is exactly what we received in CW ?
Or is the string after “fe” - 00001 is some kind of checksum ?
I tried to send my decoded reception but it was not listed.
Please correct me if I did something wrong:
curl --data ‘noradID=59508&source=SP5LOT×tamp=2024-08-03T08:47:30Z&frame=6A7331796D786B617368697761u485c5670fe00001&locator=longLat&longitude=21.12E&latitude=52.08N’
Hi Tomasz,
Thanks for joining!
Yes, it is.
You tried ““u485c5670fe00001””.
Guess it’s a typo. Try “a485c5670fe00001” instead.
And don’t forget “https://db.satnogs.org/api/telemetry/” at the end.
Thank you.
Most likely, you are absolutely right.
I will still try.
Hi Tomasz.
You can check your data from this link.
BTW CIT-Gardens will shut down KASHIWA on the Aug 5th, so we have little time left.
えええ 本当ですか。
What does “shut down” mean exactly? And why? Will さくら transmit on the same frequency?
At official X, They said 停波 & 終了措置。 These words mean KASHIWA stop beaconing. Because she is very close to re-entry.
さくら is the next satellite, but there is little information about her.
Should APRS broadcast today according to the schedule? Or only over the area of Japan ? Unfortunately, I did not receive anything and the satellite did not respond to my APRS “calls”.
Last SKD is MOG over JAPAN at 8/5 01:11Z. NO more APRS plan.
https://x.com/Tomek_SP5LOT/status/1820104455200612847
I think I’ve succeeded…
So we are getting closer to its re-entry! Let’s track it as far as we can then!!!
I’ve opened a related thread Kashiwa re-entry
