K3ng controller?
Is it true that the k3ng controller does not work with satnogs?
look here:
 Rot #  Mfg                    Model                   Version         Status        Macro
     1  Hamlib                 Dummy                   20220531.0      Stable        ROT_MODEL_DUMMY
     2  Hamlib                 NET rotctl              20221110.0      Stable        ROT_MODEL_NETROTCTL
   201  Hamlib                 EasycommI               20220109.0      Stable        ROT_MODEL_EASYCOMM1
   202  Hamlib                 EasycommII              20191206.0      Stable        ROT_MODEL_EASYCOMM2
   204  Hamlib                 EasycommIII             20201203.0      Stable        ROT_MODEL_EASYCOMM3
   301  XQ2FOD                 Fodtrack                20200107.0      Stable        ROT_MODEL_FODTRACK
   401  Idiom Press            Rotor-EZ                20220109.0      Stable        ROT_MODEL_ROTOREZ
   402  Idiom Press            RotorCard               20100214.0      Beta          ROT_MODEL_ROTORCARD
   403  Hy-Gain                DCU-1/DCU-1X            20100823.0      Stable        ROT_MODEL_DCU
   404  DF9GR                  ERC                     20100823.2      Stable        ROT_MODEL_ERC
   405  Green Heron            RT-21                   20220104.0      Stable        ROT_MODEL_RT21
   406  Hy-Gain                DCU2/DCU3/YRC-1         20100823.2      Stable        ROT_MODEL_YRC1
   501  SARtek                 SARtek-1                20061007.0      Beta          ROT_MODEL_SARTEK1
   601  Yaesu                  GS-232A                 20220109.0      Stable        ROT_MODEL_GS232A
   602  Various                GS-232 Generic          20220109.0      Stable        ROT_MODEL_GS232_GENERIC
   603  Yaesu                  GS-232B                 20220109.0      Stable        ROT_MODEL_GS232B
   604  F1TE                   GS232/F1TE Tracker      20220109.0      Stable        ROT_MODEL_F1TETRACKER
   605  Yaesu/Kenpro           GS-23                   20220109.0      Stable        ROT_MODEL_GS23
   606  Yaesu/Kenpro           GS-232                  20220109.0      Stable        ROT_MODEL_GS232
   607  AMSAT                  LVB Tracker             20220109.0      Stable        ROT_MODEL_LVB
   608  FoxDelta               GS232/ST2               20220109.0      Stable        ROT_MODEL_ST2
   609  Yaesu                  GS-232A azimuth         20220109.0      Stable        ROT_MODEL_GS232A_AZ
   610  Yaesu                  GS-232A elevation       20220109.0      Stable        ROT_MODEL_GS232A_EL
   611  Yaesu                  GS-232B azimuth         20220109.0      Stable        ROT_MODEL_GS232B_AZ
   612  Yaesu                  GS-232B elevation       20220109.0      Stable        ROT_MODEL_GS232B_EL
   701  WA6UFQ                 PcRotor                 20081013.0      Beta          ROT_MODEL_PCROTOR
   801  Heathkit               HD 1780 Intellirotor    20220109.0      Stable        ROT_MODEL_HD1780
   901  SPID                   Rot2Prog                20220109.0      Stable        ROT_MODEL_SPID_ROT2PROG
   902  SPID                   Rot1Prog                20220109.0      Stable        ROT_MODEL_SPID_ROT1PROG
   903  SPID                   MD-01/02 (ROT2 mode)    20220109.0      Stable        ROT_MODEL_SPID_MD01_ROT2PROG
  1001  M2                     RC2800                  20210129        Stable        ROT_MODEL_RC2800
  1002  M2                     RC2800_EARLY_AZ         20201130        Stable        ROT_MODEL_RC2800_EARLY_AZ
  1003  M2                     RC2800_EARLY_AZEL       20201130        Stable        ROT_MODEL_RC2800_EARLY_AZEL
  1101  EA4TX                  ARS RCI AZ&EL           20200112.0      Stable        ROT_MODEL_RCI_AZEL
  1102  EA4TX                  ARS RCI AZ              20200112.0      Stable        ROT_MODEL_RCI_AZ
  1201  AMSAT                  IF-100                  20110531.0      Beta          ROT_MODEL_IF100
  1301  LA7LKA                 ts7400                  20200113.0      Stable        ROT_MODEL_TS7400
  1401  Celestron              NexStar                 20220109.0      Beta          ROT_MODEL_NEXSTAR
  1501  DG9OAA                 Ether6 (via ethernet)   20220109.0      Stable        ROT_MODEL_ETHER6
  1601  CNCTRK                 CNCTRK                  20220109.0      Beta          ROT_MODEL_CNCTRK
  1701  Prosistel              D azimuth               20201215.0      Stable        ROT_MODEL_PROSISTEL_D_AZ
  1702  Prosistel              D elevation             20201215.0      Stable        ROT_MODEL_PROSISTEL_D_EL
  1703  Prosistel              Combi-Track az+el       20201215.0      Stable        ROT_MODEL_PROSISTEL_COMBI_TRACK_AZEL
  1704  Prosistel              D elevation CBOX az     20221215.0      Stable        ROT_MODEL_PROSISTEL_D_EL_CBOXAZ
  1801  Meade                  LX200/Autostar          20220109.0      Stable        ROT_MODEL_MEADE
  1901  iOptron                iOptron                 20220109.0      Stable        ROT_MODEL_IOPTRON
  2101  SatEL                  SatEL                   20210123.0      Stable        ROT_MODEL_SATEL
  2201  Radant                 AZ-1/AZV-1              20210508.0      Stable        ROT_MODEL_RADANT
  2401  BG5DIW                 GRBLTRK via Serial      20220515.0      Beta          ROT_MODEL_GRBLTRK_SER
  2402  BG5DIW                 GRBLTRK via Net         20220515.0      Beta          ROT_MODEL_GRBLTRK_NET
it should work :smile:
