I encountered the same issue. As a temporary workaround, I enabled the “Experimental” setting (“Install latest versions of all software”) in the Software Package Settings using satnogs-setup. That seems to have resulted in a functioning system again.
Once the “stable” releases are again truly stable, I intend to switch this back.
I create a new image on a micro SD card. First time same issue. After running sudo apt-get purge libgnuradio-satnogs gr-satnogs a second time I could update and apply. I can´t find the issue, but it´s running now
Thanks for the command to get the station back on track. My station has had 150 failed observations after it broke. Hopefully it will be back to normal operational state now. I’ll let it run overnight and report back.
Thank you @Acinonyx - with your advice, update went through.
But now my station is experiencing another error. It seems to occur after some 4 hours after the last reboot of the Pi, but not sure if this is just coincidence.
This is from the syslog:
Dec 7 13:08:00 satnogs satnogs-client[336]: — Logging error —
Dec 7 13:08:00 satnogs satnogs-client[336]: Traceback (most recent call last):
Dec 7 13:08:00 satnogs satnogs-client[336]: File “/var/lib/satnogs/lib/python3.7/site-packages/satnogsclient/scheduler/tasks.py”, line 124, in post_data
Dec 7 13:08:00 satnogs satnogs-client[336]: response.raise_for_status()
Dec 7 13:08:00 satnogs satnogs-client[336]: File “/var/lib/satnogs/lib/python3.7/site-packages/requests/models.py”, line 941, in raise_for_status
Dec 7 13:08:00 satnogs satnogs-client[336]: raise HTTPError(http_error_msg, response=self)
Dec 7 13:08:00 satnogs satnogs-client[336]: requests.exceptions.HTTPError: 400 Client Error: Bad Request for url: https://network.satnogs.org/api/observations/3255525/
Dec 7 13:08:00 satnogs satnogs-client[336]: During handling of the above exception, another exception occurred:
Dec 7 13:08:00 satnogs satnogs-client[336]: File “/usr/lib/python3.7/logging/init.py”, line 1034, in emit
Dec 7 13:08:00 satnogs satnogs-client[336]: msg = self.format(record)
Dec 7 13:08:00 satnogs satnogs-client[336]: File “/usr/lib/python3.7/logging/init.py”, line 880, in format
Dec 7 13:08:00 satnogs satnogs-client[336]: return fmt.format(record)
Dec 7 13:08:00 satnogs satnogs-client[336]: File “/usr/lib/python3.7/logging/init.py”, line 619, in format
Dec 7 13:08:00 satnogs satnogs-client[336]: record.message = record.getMessage()
Dec 7 13:08:00 satnogs satnogs-client[336]: File “/usr/lib/python3.7/logging/init.py”, line 380, in getMessage
Dec 7 13:08:00 satnogs satnogs-client[336]: msg = msg % self.args
Dec 7 13:08:00 satnogs satnogs-client[336]: TypeError: %i format: a number is required, not str
Dec 7 13:08:00 satnogs satnogs-client[336]: Call stack:
Dec 7 13:08:00 satnogs satnogs-client[336]: File “/usr/lib/python3.7/threading.py”, line 885, in _bootstrap
Dec 7 13:08:00 satnogs satnogs-client[336]: self._bootstrap_inner()
Dec 7 13:08:00 satnogs satnogs-client[336]: File “/usr/lib/python3.7/threading.py”, line 917, in _bootstrap_inner
Dec 7 13:08:00 satnogs satnogs-client[336]: self.run()
Dec 7 13:08:00 satnogs satnogs-client[336]: File “/usr/lib/python3.7/threading.py”, line 865, in run
Dec 7 13:08:00 satnogs satnogs-client[336]: self._target(*self._args, **self._kwargs)
Dec 7 13:08:00 satnogs satnogs-client[336]: File “/usr/lib/python3.7/concurrent/futures/thread.py”, line 80, in _worker
Dec 7 13:08:00 satnogs satnogs-client[336]: work_item.run()
Dec 7 13:08:00 satnogs satnogs-client[336]: File “/usr/lib/python3.7/concurrent/futures/thread.py”, line 57, in run
Dec 7 13:08:00 satnogs satnogs-client[336]: result = self.fn(*self.args, **self.kwargs)
Dec 7 13:08:00 satnogs satnogs-client[336]: File “/var/lib/satnogs/lib/python3.7/site-packages/apscheduler/executors/base.py”, line 125, in run_job
Dec 7 13:08:00 satnogs satnogs-client[336]: retval = job.func(*job.args, **job.kwargs)
Dec 7 13:08:00 satnogs satnogs-client[336]: File “/var/lib/satnogs/lib/python3.7/site-packages/satnogsclient/scheduler/tasks.py”, line 147, in post_data
Dec 7 13:08:00 satnogs satnogs-client[336]: ‘response status code: %s’, fil, observation_id, response.status_code)
Dec 7 13:08:00 satnogs satnogs-client[336]: Message: ‘Upload of %s for observation %i failed, response status code: %s’
Dec 7 13:08:00 satnogs satnogs-client[336]: Arguments: (‘waterfall_3255525_2020-12-07T11-23-52.png’, ‘3255525’, 400)
Dec 7 13:08:00 satnogs satnogs-client[336]: satnogsclient.scheduler.tasks - ERROR - 502 Server Error: Bad Gateway for url: https://network.satnogs.org/api/jobs/?ground_station=376&lat=48.833&lon=8.839&alt=460
