fredy
July 30, 2023, 9:14am
1
From PSLV-CA C56 - DS-SAR - FLP - 30 July 2023 (01:01 UTC) and
PSLV_C56_Mission_Brochure.pdf (8.2 MB) we have these:
Temporary NORAD ID
Satellite
Frequency
Notes
Deployed
COMMERCIAL UHF
99059
NuLIoN
401.500 MHz
Directly
AMATEUR UHF
99055
GALASSIA-2
436.400 MHz
IARU Coordinated
Directly
99056
VELOX-AM
437.125 MHz
IARU Coordinated
Directly
99057
SCOOB-II
437.500 MHz
IARU Coordinated
Directly
99058
ARCADE
437.760 MHz
IARU Coordinated
Directly
NO FREQUENCIES
ORB-12 STRIDER
Directly
Latest Update: 2023-07-30 09:15 UTC
fredy
July 30, 2023, 10:17am
2
I forgot to add TLE set that NuLIoN team shared with us and it is also used for the rest of the satellites:
NuLIoN
1 99059U 10793A 23211.05523148 .00000000 00000-0 38792-4 0 05
2 99059 4.8856 278.2466 0011634 185.0746 359.0067 15.10000000 03
ARCADE
1 99058U 10793A 23211.05523148 .00000000 00000-0 38792-4 0 04
2 99058 4.8856 278.2466 0011634 185.0746 359.0067 15.10000000 02
SCOOB-II
1 99057U 10793A 23211.05523148 .00000000 00000-0 38792-4 0 03
2 99057 4.8856 278.2466 0011634 185.0746 359.0067 15.10000000 01
VELOX-AM
1 99056U 10793A 23211.05523148 .00000000 00000-0 38792-4 0 02
2 99056 4.8856 278.2466 0011634 185.0746 359.0067 15.10000000 00
GALASSIA-2
1 99055U 10793A 23211.05523148 .00000000 00000-0 38792-4 0 01
2 99055 4.8856 278.2466 0011634 185.0746 359.0067 15.10000000 09
TLE set is adjusted to use the temporary NORAD ID for each satellite.
fredy
3
fredy
July 30, 2023, 10:36am
4
After some analysis by @PE0SAT we have that the modulation is GOMspace AX.100 Mode 5 FKS1k2
and from one of the demodulated frames we have:
47414c41535349412d3200a5a5a5a5a5a5a5a5a5051d0512051e205d002d008f00110021001700000000003e0000004a000000000001000100000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000dff0008b6d10505000000000000000000000000000000000000000100080007000600060004000507030200000071007302000100000001b9fcd01c0239fd2f6b020075007a0007000001000000000000000000000000fc19fc19fc19fc19827f38a7
Where the first hex digits are translated to GALASSIA-2. So, we can confirm that this is the satellite.
fredy
July 30, 2023, 10:39am
5
Unfortunately due to the orbit of these satellites, we have limited passes and many of them are low elevation ones.
However we will continue to track them and try to generate TLE sets and identify them when they are catalogued.
fredy
July 30, 2023, 11:51am
6
From the first Galassia-2 observations we have this TLE set:
GALASSIA-2
1 99055U 23211.40000000 .00000000 00000-0 00000-0 0 04
2 99055 4.8856 280.5354 0011231 189.2325 65.7103 15.20284791 07
galassia_211.dat (210 Bytes)
sites.txt (2.8 KB)
Based on the above I’ve updated also the rest of the satellite TLE sets by adjusting the set above to the temporary NORAD IDs:
NuLIoN
1 99059U 23211.40000000 .00000000 00000-0 00000-0 0 08
2 99059 4.8856 280.5354 0011231 189.2325 65.7103 15.20284791 01
ARCADE
1 99058U 23211.40000000 .00000000 00000-0 00000-0 0 07
2 99058 4.8856 280.5354 0011231 189.2325 65.7103 15.20284791 00
SCOOB-II
1 99057U 23211.40000000 .00000000 00000-0 00000-0 0 06
2 99057 4.8856 280.5354 0011231 189.2325 65.7103 15.20284791 09
VELOX-AM
1 99056U 23211.40000000 .00000000 00000-0 00000-0 0 05
2 99056 4.8856 280.5354 0011231 189.2325 65.7103 15.20284791 08
fredy
July 30, 2023, 4:50pm
7
From more recent observations we have for NuLIoN:
NuLIoN
1 99059U 23211.60000000 .00000000 00000-0 00000-0 0 00
2 99059 4.8856 271.8799 0011442 186.8046 86.3140 15.10512481 03
sites.txt (2.8 KB)
nulion_211.dat (1.9 KB)
From the above analysis it looks like that NuLIoN has ~1.2KHz frequency drift.
fredy
July 30, 2023, 5:14pm
8
VELOX-AM is also received and decoded by @PE0SAT :
((transmitter . 4k8 FSK AX100 ASM+Golay downlink))
pdu length = 71 bytes
pdu vector contents =
0000: 8a ac f2 00 58 44 41 54 00 0a 39 00 30 10 4b 10
0010: 0e 00 45 00 0e 0e 47 00 46 00 00 00 00 42 0d 09
0020: 3f 41 d4 5f d6 41 8d 04 5a ba 6b c6 0c bc 40 16
0030: 01 3b 13 b5 40 42 03 e8 b5 00 00 00 00 b7 4f c8
0040: 5d d5 c6 e4 2e 75 84
From the same observation here is a generated TLE set:
VELOX-AM
1 99056U 23211.60000000 .00000000 00000-0 00000-0 0 07
2 99056 4.8856 286.2759 0011259 191.3336 69.8576 15.10000692 00
veloxam_211.dat (280 Bytes)
sites.txt (2.8 KB)
fredy
July 30, 2023, 5:16pm
9
TLE sets for this launch by space-track.org , still in TBA status and still not for all objects:
0 TBA - TO BE ASSIGNED
1 57481U 23109A 23211.41847873 .00000886 00000-0 00000+0 0 9992
2 57481 4.9995 275.7023 0007847 8.6094 353.0053 15.11174876 57
1 57482U 23109B 23211.41966507 .00000898 00000-0 00000+0 0 9992
2 57482 5.0039 275.6202 0011127 12.6229 356.6021 15.11991539 55
1 57483U 23109C 23211.34332602 .00000905 00000-0 00000+0 0 9997
2 57483 4.9997 276.1987 0013415 7.9740 305.0286 15.12414615 46
1 57484U 23109D 23211.41486877 .00000880 00000-0 00000+0 0 9992
2 57484 5.0043 275.6603 0006560 341.0699 0.3856 15.10753608 53
1 57485U 23109E 23211.55779225 .00000893 00000-0 00000+0 0 9994
2 57485 4.9949 274.5372 0010275 11.7883 30.8210 15.11663994 75
Hello everyone! Thanks for helping to track this launch!
We have a tracking station in Singapore and were working on Galassia-2’s pass using 57484. We could only obtain good connection between 10-30deg elevation, suggesting poor TLE. Will continue to track with different TLE and report back.
fredy
July 31, 2023, 8:09am
12
New TLE sets from space-track.org , some of the in TBA status:
0 OBJECT A
1 57481U 23109A 23211.77263348 .00000886 00000-0 00000+0 0 9990
2 57481 4.9985 272.9435 0008409 12.3518 121.3077 15.11155875 106
0 OBJECT B
1 57482U 23109B 23211.69788124 .00000898 00000-0 00000+0 0 9999
2 57482 5.0053 273.5142 0011278 16.1203 71.6576 15.11988407 92
0 OBJECT C
1 57483U 23109C 23211.69936272 .00000904 00000-0 00000+0 0 9997
2 57483 5.0009 273.4822 0013204 13.7638 83.1198 15.12416173 99
0 OBJECT D
1 57484U 23109D 23211.70069953 .00000881 00000-0 00000+0 0 9997
2 57484 5.0053 273.5008 0006823 356.8981 103.4064 15.10750417 95
1 57485U 23109E 23211.76891589 .00000893 00000-0 00000+0 0 9995
2 57485 4.9976 272.9708 0010139 15.1424 99.5413 15.11666312 106
1 57486U 23109F 23211.70251434 .00000879 00000-0 00000+0 0 9993
2 57486 5.0061 273.4089 0006679 357.2235 112.5913 15.10572641 95
1 57487U 23109G 23211.84005355 .00000874 00000-0 00000+0 0 9993
2 57487 5.0080 272.4641 0004488 3.0664 136.0329 15.10342699 65
We have in total 7 TLE sets, given that the payloads are 7 and the we also have the rocket body, we probably expect more sets.
We just attempted a pass for Galassia-2 with 57486. The pass was of decent quality throughout. Quite certain that 57486 is Galassia-2.
Based on observations here, we are starting to believe that 57487 is NuLIoN. Will continue to track NuLIoN with 57487 and report back.
Thats cool! Which TLE did you use to track it?
fredy
July 31, 2023, 4:42pm
18
Indeed running observation 7944094 through ikhnos looks like that 57487 is closer than the other candidates.
I’ve changed it in DB and Network.
yd9ckh
July 31, 2023, 10:51pm
19
this one
GALASSIA-2
1 57486U 23109F 23211.70251434 .00000879 00000+0 00000+0 0 9992
Based on our attempts today, it does seem that our suspect of NuLIoN being 57487 seems to be quite accurate.
