I dont receive any waterfall or data
i have antenas cross yaggi with a rotator and an rtl sdr i dont receive any watrfall what can be the problem with the configuration of satnogs in raspberry pi
Share more information.
https://wiki.satnogs.org/Troubleshooting
i set the configuration on my raspberry pi as following SATNOGS_SOAPY_RX_DEIVE
:black_small_square: driver=rtl-sdr Enter if SDR is RTL-SDR.
o SATNOGS_ANTENNE
:black_small_square: RX Enter.
o SATNOGS_RX_SAMP_RATE
:black_small_square: 2.048e6Enter (2Msps) for RTL-SDR.
o SATNOGS_STATION_ELEV
:black_small_square: Enter the value set for “Altitude” in the ground station.
o SATNOGS_STATION_ID
:black_small_square: Enter the ID of the ground station.
o SATNOGS_STATION_LAT
:black_small_square: Enter the value you set as latitude in the “Coordinates” of
the ground station.
o STANOGS_STATION_LON
:black_small_square: Enter the value that you set as the…
  • thank u somuch for responding
I have made my ground station with a cross yagi antena an amplifier and polariser on the roof and an rtl sdr with a raspberry pi 3 .I have created a satnogs account but no waterfall is there
We need more details on your satnogs-client install, for now the RF information isn’t important.
Something is wrong with the software install. The more details the better.
Please share the output from the following command:
sudo satnogs-setup select advanced, select Support. Then share the output of the output.
Also share the journalctl information as mentioned on the troubleshooting wiki
As a last step SoapySDRUtil --probe="driver=rtlsdr"
PLEASE HELP ME
error no waterfall data file found
Could you try for Antenna to add ‘RX’ instead ‘Rx’?
ok i will try thank youu
it doen t work
Please run this and share the result.
$ SoapySDRUtil --probe=“driver=rtlsdr”
Probe device driver=rtlsdr
[INFO] Opening Generic RTL2832U OEM :: 00000001…
– Device identification
driver=RTLSDR
hardware=R820T
index=0
origin=GitHub - pothosware/SoapyRTLSDR: SoapySDR RTL-SDR Support Module
– Peripheral summary
Channels: 1 Rx, 0 Tx
Timestamps: YES
Time sources: sw_ticks
Other Settings:
* Bias Tee - RTL-SDR Blog V.3 Bias-Tee Mode
[key=biastee, default=false, type=bool]
– RX Channel 0
Full-duplex: NO
Supports AGC: YES
Stream args:
Antennas: RX
Full gain range: [0, 49.6] dB
RF freq range: [24, 1764] MHz
Filter bandwidths: [0, 8] MHz
Just in case, when you changed the satnogs_soapy_rx_device from “Rx” to “RX”, did you hit the apply button?
If yes, please run once more the support report by going to Advanced -> Support.
THIS is the result of advanced support
The SATNOGS_SOAPY_RX_DEVICE should be driver=rtlsdr and not rtlsdr
Please change this, apply the change and check once more with new observations.
