Howto: Meteor M2 weather satellite image decoding
Managed to decode data, but when I manually tested the process_meteor.py it failed when copying file to /tmp/.satnogs/data/complete/
pi@raspberrypi:~/satnogs-extras/scripts $ sudo python process_meteor.py
Waiting for 10 seconds before processing.
Attempting to process: /tmp/data_4224714_2021-06-07T17-18-54.s
Total:        284.441986
Processing:   46.032661
Correlation:  18.766024
Viterbi:      203.864761
ECC:          15.733690
Remainder:    0.044825
Packets:      5330 / 5549
Elapsed time: 00:12:48.232
convert-im6.q16: length and filesize do not match `/tmp/meteor_image_temp_vis.bmp' @ warning/bmp.c/ReadBMPImage/839.
Total:        62.771225
Processing:   62.749352
Correlation:  0.000000
Viterbi:      0.000000
ECC:          0.000000
Remainder:    0.021868
Packets:      5330 / 5330
convert-im6.q16: length and filesize do not match `/tmp/meteor_image_temp_ir.bmp' @ warning/bmp.c/ReadBMPImage/839.
VIS processing successful!
IR processing successful!
  File "process_meteor.py", line 135, in <module>
    shutil.move(_file, RAW_DESTINATION_DIR + os.path.basename(_file))
  File "/usr/lib/python2.7/shutil.py", line 325, in move
    copy2(src, real_dst)
  File "/usr/lib/python2.7/shutil.py", line 153, in copy2
    copyfile(src, dst)
  File "/usr/lib/python2.7/shutil.py", line 97, in copyfile
    with open(dst, 'wb') as fdst:
IOError: [Errno 2] No such file or directory: '/tmp/.satnogs/data/complete/data_4224714_2021-06-07T17-18-54.s'
Is it simply due to observation being performed over an hour ago? Or is it something that should be fixed?
It’s this observation: https://network.satnogs.org/observations/4224714/
EDIT: Ok, everything works - thanks @EelkeVisser https://network.satnogs.org/observations/4229549
I found that adding:
if not os.path.isdir(RAW_DESTINATION_DIR):
    os.makedirs(RAW_DESTINATION_DIR)
before
Makes the code a little more robust if there was reboot that cleared the /tmp
@EelkeVisser I’ve got one issue - thermal image is still all black despite adding:
if suffix == "_ir":
        subprocess.call([CONVERT_PATH, "-negate", "-linear-stretch", "1x1%", raw_image_path, result_image])
Any ideas where to start looking to determine the reason?
Hi Michal,
Yes, your code improvement makes sense if you want keep the files. But the tmp folder is in memory as far as I know. Could get full, so I decided to remove them. See step 5 of the instruction.
To solve the ir image problem you don’t need to look at the computer monitor, but need to look outside during the observation. :slight_smile: If it is light outside, the ir channel is off and the image gets black. I assume it starts working again when the winter arrives in :poland:
Makes perfect sense, I’m still in awe how beautiful those pictures are. One thing is when I add the process_meteor.py script as post observation script something seems off and after decodes I get a long series of failed observations afterwards where no products were uploaded - is this connected to what you mentioned that it’s getting full?
I just done this and it worked right out the box. Thanks for nice guide. Will add the tweaking later.
Thanks for now.
73 Geoge
After the upgrade we need to edit the flowgraphs.py again.
73 George
Updating from client version 1.4 to 1.6.
re editing flowgraps.py but no luck on my station.
No more .s file generated
  • No change in postob.sh
  • No change in advance post observation menu
Is other updated files could be my problem…?
VE2DSK
Hi, in the update from 1.4 to 1.5 there was new functionality introdced in Satnogs that caused trouble. I had updated step 1 of the howto to include some arguments to satnogs_lrpt_demod.py. So please check this file against the instructions of step 1. Start at: sudo nano satnogs_lrpt_demod.py…
And it is good that you have already updated flowgraps.py. I think there are no changes needed in postob.sh or the menu.
Good luck, best regards, Eelke.
Need help since the upgrade to 1.6
I have a syntax error and i can’t tell why so please see pictures of flowgraphs.py and the dump/log file and help a guy out who’s stuck please.
Thanks Karl.
Missing one bracket
VE2SDSK
Thank you.
I just got through looking at my second stations file and noticed my mistake. I’ve now added the } to the file and shes started back up.
Best 73
Karl.
Hi All.
So yet another issue. while observing the Meteor-M2 pass i see no waterfall data and the log file shows as in the picture below. This time I’ve looked at both stations i have running and they both look the same so please see the attached picture and if you can shed some light on my issue with that would be great.
I have noticed that the def argument_parser() : is not all the way to the left of the screen on the file could this be it ? and how important is the spacing.
Well it took a while but it’s finally fixed and I’ve got the first successful observation, Time to schedule some more.
Thanks for all the help.
https://network.satnogs.org/observations/4712852/
It is very important! Python uses the spacing to determine which lines belong to each other. Other programming languages are more dependent on brackets or key words, and not to spaces.
Good job, fixing it! :smiley:
This line start with no space…
Did those two mods work for yours two stations…?
Mine still no .s capture… VE2DSK
Yes the start looks just like yours and end looks like the second picture above.
It’s back to working.
One other thing i had to do was edit the complete_output_path in the satnogs-setup options as this is the only way i could get the complete folder to stop deleting it’s self on reboot or restart.
Regards
Karl.
Hi Elke and all…
what is needed to be done to get the LRPT-demod in to ā€œSATNOGS-clientā€?
So we do not have to do allthis when the next upgrade comes along.
Best 73
George
I think the issue is that we use post processing after the observation. I read somewhere (where?) that this is undesirable, as it might interfere with the next observation.
There is some work tracked in this item LRPT Decoder (#122) Ā· Issues Ā· librespacefoundation / SatNOGS / gr-satnogs Ā· GitLab to include it. It seems ā€˜paused’, and I don’t know the status.
Running fine here !
A lot of thank’s for your howto.
https://network.satnogs.org/observations/5354518/
Hi runahue
also running on my station (client v1.6) for many months…
Not working since v1.7 update…
ve2dsk
Is METEOR M2 still alive…?
No more waterfall print… ve2dsk
https://network.satnogs.org/observations/5910591/
