I can see the device on native raspbian, but obviousely its not accessible from inside docker.
greetings
Stefan/OE6ISP
greetings
Stefan/OE6ISP
Hi Stefan,
The docker rotor support is still on the missing features table.
Thinking out of the box, maybe configure a remote connection inside the docker container to a rotctld daemon running on the physical host.
Maybe this community post can help you further
Thx Jan for the quick response!
73, Stefan
This one also works, but uses a separate stack. You need to specify the host IP to connect on port 4533, 127.0.0.1 or localhost will not work from the containers iirc.
thx for your answer - this is indeed the best solution for me, because I usually have the rotor plugged to the win-pc - works out of the box.
73
Stefan
