Help in configuring SDRPlay with SatNOGS
After installing and configuring SatNOGS, this error occurred after scheduling the first observation, how do I fix this issue? The error log is provided below:
2026-02-24T12:29:31.004759000Z rot_init called
2026-02-24T12:29:31.005128000Z initrots4_dummy: _init called
2026-02-24T12:29:31.005182000Z rot_register (1)
2026-02-24T12:29:31.005234000Z rot_register (2)
2026-02-24T12:29:31.005385000Z dummy_rot_init called
2026-02-24T12:29:31.005460000Z rot_open called
2026-02-24T12:29:31.005504000Z dummy_rot_open called
2026-02-24T12:29:31.005540000Z dummy_rot_open: dummy rotator so simulating speed
2026-02-24T12:29:32.754366000Z rig_check_rig_caps: p1=0x7fac777cbc40, p2=0x7fac777d21c0, rig_model=0x7fac777cbc40, macro_name=0x7fac777d21c0
2026-02-24T12:29:32.754651000Z initrigs4_dummy: _init called
2026-02-24T12:29:32.754728000Z rig_init: rig_model=Hamlib NET rigctl
2026-02-24T12:29:32.754767000Z rig_init: rx_range_list1 is empty, using rx_range_list2
2026-02-24T12:29:32.754809000Z rig_init: rig does not have tx_range!!
2026-02-24T12:29:32.754852000Z netrigctl_init version 20230106.0
2026-02-24T12:29:32.920340000Z Traceback (most recent call last):
2026-02-24T12:29:32.920608000Z   File "/usr/bin/satnogs_cw_decoder.py", line 515, in <module>
2026-02-24T12:29:32.921953000Z     main()
2026-02-24T12:29:32.922325000Z   File "/usr/bin/satnogs_cw_decoder.py", line 498, in main
2026-02-24T12:29:32.922819000Z     tb = top_block_cls(antenna=options.antenna, bb_freq=options.bb_freq, bfo_freq=options.bfo_freq, bw=options.bw, dc_removal=options.dc_removal, decoded_data_file_path=options.decoded_data_file_path, dev_args=options.dev_args, doppler_correction_per_sec=options.doppler_correction_per_sec, enable_iq_dump=options.enable_iq_dump, file_path=options.file_path, gain=options.gain, gain_mode=options.gain_mode, iq_file_path=options.iq_file_path, lo_offset=options.lo_offset, other_settings=options.other_settings, ppm=options.ppm, rigctl_host=options.rigctl_host, rigctl_port=options.rigctl_port, rx_freq=options.rx_freq, samp_rate_rx=options.samp_rate_rx, soapy_rx_device=options.soapy_rx_device, stream_args=options.stream_args, tune_args=options.tune_args, udp_dump_host=options.udp_dump_host, udp_dump_port=options.udp_dump_port, waterfall_file_path=options.waterfall_file_path, wpm=options.wpm, zmq_pub_uri=options.zmq_pub_uri)
2026-02-24T12:29:32.926190000Z          ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
2026-02-24T12:29:32.926706000Z   File "/usr/bin/satnogs_cw_decoder.py", line 108, in __init__
2026-02-24T12:29:32.926794000Z     self.soapy_source_0_0 = soapy.source(dev, "fc32", 1, dev_args,
2026-02-24T12:29:32.926845000Z                             ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
2026-02-24T12:29:32.926904000Z RuntimeError: SoapySDR::Device::make() no match
2026-02-24T12:29:34.232088000Z netrigctl_close: done
2026-02-24T12:29:37.131030000Z ERROR    satnogsclient.observer.observer No waterfall data file found
I seemed to have narrowed the problem down, it seems that the SoapySDRUtil inside the satnogs-client docker does not have sdrplay support. Running “SoapySDRUtil –info” outside the docker gives:
##     Soapy SDR -- the SDR abstraction library     ##
Lib Version: v0.8.1-5+b2
API Version: v0.8.0
ABI Version: v0.8
Install root: /usr
Search path:  /usr/lib/x86_64-linux-gnu/SoapySDR/modules0.8
Search path:  /usr/local/lib/x86_64-linux-gnu/SoapySDR/modules0.8                (missing)
Search path:  /usr/local/lib/SoapySDR/modules0.8
Module found: /usr/lib/x86_64-linux-gnu/SoapySDR/modules0.8/libHackRFSupport.so  (0.3.4)
Module found: /usr/lib/x86_64-linux-gnu/SoapySDR/modules0.8/libLMS7Support.so    (23.11.0)
Module found: /usr/lib/x86_64-linux-gnu/SoapySDR/modules0.8/libRedPitaya.so      (0.1.1)
Module found: /usr/lib/x86_64-linux-gnu/SoapySDR/modules0.8/libairspySupport.so  (0.2.0)
Module found: /usr/lib/x86_64-linux-gnu/SoapySDR/modules0.8/libaudioSupport.so   (0.1.1)
Module found: /usr/lib/x86_64-linux-gnu/SoapySDR/modules0.8/libbladeRFSupport.so (0.4.2)
Module found: /usr/lib/x86_64-linux-gnu/SoapySDR/modules0.8/libmiriSupport.so    (0.2.5)
Module found: /usr/lib/x86_64-linux-gnu/SoapySDR/modules0.8/libosmosdrSupport.so (0.2.5)
Module found: /usr/lib/x86_64-linux-gnu/SoapySDR/modules0.8/libremoteSupport.so  (0.5.2)
Module found: /usr/lib/x86_64-linux-gnu/SoapySDR/modules0.8/librfspaceSupport.so (0.2.5)
Module found: /usr/lib/x86_64-linux-gnu/SoapySDR/modules0.8/librtlsdrSupport.so  (0.3.3)
Module found: /usr/lib/x86_64-linux-gnu/SoapySDR/modules0.8/libuhdSupport.so     (0.4.1)
Module found: /usr/local/lib/SoapySDR/modules0.8/libsdrPlaySupport.so            (0.5.2)
Available factories... airspy, audio, bladerf, hackrf, lime, miri, osmosdr, redpitaya, remote, rfspace, rtlsdr, sdrplay, uhd
Available converters...
 -  CF32 -> [CF32, CS16, CS8, CU16, CU8]
 -  CS16 -> [CF32, CS16, CS8, CU16, CU8]
 -  CS32 -> [CS32]
 -   CS8 -> [CF32, CS16, CS8, CU16, CU8]
 -  CU16 -> [CF32, CS16, CS8]
 -   CU8 -> [CF32, CS16, CS8]
 -   F32 -> [F32, S16, S8, U16, U8]
 -   S16 -> [F32, S16, S8, U16, U8]
 -   S32 -> [S32]
 -    S8 -> [F32, S16, S8, U16, U8]
 -   U16 -> [F32, S16, S8]
 -    U8 -> [F32, S16, S8]
while running inside satnogs_satnogs-client docker gives:
Lib Version: v0.8.1-3
API Version: v0.8.0
ABI Version: v0.8
Install root: /usr
Search path:  /usr/local/lib/SoapySDR/modules0.8                                  (missing)
Module found: /usr/lib/x86_64-linux-gnu/SoapySDR/modules0.8/libHackRFSupport.so   (0.3.3)
Module found: /usr/lib/x86_64-linux-gnu/SoapySDR/modules0.8/libLMS7Support.so     (22.09.1)
Module found: /usr/lib/x86_64-linux-gnu/SoapySDR/modules0.8/libPlutoSDRSupport.so (0.2.1)
Module found: /usr/lib/x86_64-linux-gnu/SoapySDR/modules0.8/libSoapyHydraSDR.so   (1.0.0)
Module found: /usr/lib/x86_64-linux-gnu/SoapySDR/modules0.8/libairspyhfSupport.so (0.2.0)
Module found: /usr/lib/x86_64-linux-gnu/SoapySDR/modules0.8/libbladeRFSupport.so  (0.4.1)
Available factories... airspy, airspyhf, audio, bladerf, hackrf, hydrasdr, lime, miri, osmosdr, plutosdr, redpitaya, remote, rfspace, rtlsdr, uhd
 -  CS32 -> [CS32]
 -   S32 -> [S32]
However I am still unable to figure out how to add sdrplay support for the SatNOGS client, any help is appreciated.
share your station and obs link here.
You have to build the Soapy module for sdplay yourself. Use https://github.com/TobiasWooldridge/SoapySDRPlay3 for this.
Then adjust your config. For example, mine looks like this:
SATNOGS_SOAPY_RX_DEVICE=“driver=sdrplay”
SATNOGS_ANTENNA=“Tuner 1 50 ohm”
SATNOGS_RX_SAMP_RATE=“2e6”
SATNOGS_RX_BANDWIDTH=“600e3”
SATNOGS_GAIN_MODE=“Settings Field”
SATNOGS_OTHER_SETTINGS=“IFGR=40,RFGR=0”
SATNOGS_DEV_ARGS=“biasT_ctrl=false,rfnotch_ctrl=true,dabnotch_ctrl=true,iqcorr_ctrl=true,agc_setpoint=-30”
SDRPlay with the current SatNOGS client, visit this community post SDRplay and Client Version 2.1.1
