Help, I desperately need help, I get wrong angles when setting microstepping
Hi, I really need help here, so I made a rotator using an Arduino Nano Every and 2 TB6600 drivers but they were way too noisy, I tried microstepping but the angles were off, thinking it might be a problem with the drivers I bought two TMC2160 they are much more silent but the minimum stepping is 8 times.
The problem is I set the SPR to 1600 on the code, but when I set the angle, for example to 90º it only turn 22.5º and reports it as 90. I tried setting the SPR, changing the ratios, but it doesn’t make a difference, it refuses to go to the set angle. I have got the driver properly set to 1600 steps per rotation, but whatever I do to the code it doesn’t change it. Please help!
The code:
#include <string.h>
#include <stdlib.h>
#include <math.h>
#include <AccelStepper.h>
#define DIR_AZ 18 //PIN for Azimuth Direction
#define STEP_AZ 10 //PIN for Azimuth Steps
#define DIR_EL 6 //PIN for Elevation Direction
#define STEP_EL 7 //PIN for Elevation Steps
#define MS1 9 //PIN for step size
#define EN 8 //PIN for Enable or Disable Stepper Motors
#define SPR 200 //Step Per Revolution
#define RATIO 60 //Gear ratio
#define T_DELAY 60000 //Time to disable the motors in millisecond
#define HOME_AZ 4 //Homing switch for Azimuth
#define HOME_EL 5 //Homing switch for Elevation
/*The MAX_ANGLE depends of ANGLE_SCANNING_MULT and maybe misbehave for large values*/
#define ANGLE_SCANNING_MULT 180 //Angle scanning multiplier
#define MAX_AZ_ANGLE 360 //Maximum Angle of Azimuth for homing scanning
#define MAX_EL_ANGLE 360 //Maximum Angle of Elevation for homing scanning
#define HOME_DELAY 6000 //Time for homing Decceleration in millisecond
/*Global Variables*/
unsigned long t_DIS = 0; //time to disable the Motors
/*Define a stepper and the pins it will use*/
AccelStepper AZstepper(1, STEP_AZ, DIR_AZ);
AccelStepper ELstepper(1, STEP_EL, DIR_EL);
void setup()
  /*Change these to suit your stepper if you want*/
  AZstepper.setMaxSpeed(150);
  AZstepper.setAcceleration(50);
  ELstepper.setMaxSpeed(150);
  ELstepper.setAcceleration(50);
  /*Enable Motors*/
  pinMode(EN, OUTPUT);
  digitalWrite(EN, LOW);
  /*Step size*/
  pinMode(MS1, OUTPUT);
  digitalWrite(MS1, LOW); //Full step
  /*Homing switch*/
  pinMode(HOME_AZ, INPUT);
  pinMode(HOME_EL, INPUT);
  /*Serial Communication*/
  Serial.begin(19200);
  /*Initial Homing*/
  Homing(deg2step(-ANGLE_SCANNING_MULT), deg2step(-ANGLE_SCANNING_MULT));
void loop()
  /*Define the steps*/
  static int AZstep = 0;
  static int ELstep = 0;
  /*Time Check*/
  if (t_DIS == 0)
    t_DIS = millis();
  /*Disable Motors*/
  if (AZstep == AZstepper.currentPosition() && ELstep == ELstepper.currentPosition() && millis()-t_DIS > T_DELAY)
    digitalWrite(EN, HIGH);
  /*Enable Motors*/
  else
  /*Read the steps from serial*/
  cmd_proc(AZstep, ELstep);
  /*Move the Azimuth & Elevation Motor*/
  stepper_move(AZstep, ELstep);
/*Homing Function*/
void Homing(int AZsteps, int ELsteps)
  int value_Home_AZ = HIGH;
  int value_Home_EL = HIGH;
  int n_AZ = 1; //Times that AZ angle has changed
  int n_EL = 1; //Times that EL angle has changed
  boolean isHome_AZ = false;
  boolean isHome_EL = false;
  AZstepper.moveTo(AZsteps);
  ELstepper.moveTo(ELsteps);
  while(isHome_AZ == false || isHome_EL == false)
    value_Home_AZ = digitalRead(HOME_AZ);
    value_Home_EL = digitalRead(HOME_EL);
    /* Change to LOW according to Home sensor */
    if (value_Home_AZ == HIGH)
      AZstepper.moveTo(AZstepper.currentPosition());
      isHome_AZ = true;
    if (value_Home_EL == HIGH)
      ELstepper.moveTo(ELstepper.currentPosition());
      isHome_EL = true;
    if (AZstepper.distanceToGo() == 0 && !isHome_AZ)
      n_AZ++;
      AZsteps = deg2step(pow(-1,n_AZ)*n_AZ*ANGLE_SCANNING_MULT);
      if (abs(n_AZ*ANGLE_SCANNING_MULT) > MAX_AZ_ANGLE)
        error(0);
        break;
    if (ELstepper.distanceToGo() == 0 && !isHome_EL)
      n_EL++;
      ELsteps = deg2step(pow(-1,n_EL)*n_EL*ANGLE_SCANNING_MULT);
      if (abs(n_EL*ANGLE_SCANNING_MULT) > MAX_EL_ANGLE)
        error(1);
        break;
    AZstepper.run();
    ELstepper.run();
  /*Delay to Deccelerate*/
  long time = millis();
  while(millis() - time < HOME_DELAY)
    AZstepper.run();
    ELstepper.run();
  /*Reset the steps*/
  AZstepper.setCurrentPosition(0);
  ELstepper.setCurrentPosition(0);
/*EasyComm 2 Protocol & Calculate the steps*/
void cmd_proc(int &stepAz, int &stepEl)
  /*Serial*/
  char buffer[256];
  char incomingByte;
  char *p=buffer;
  char *str;
  static int counter=0;
  char data[100];
  double angleAz,angleEl;
  /*Read from serial*/
  while (Serial.available() > 0)
    incomingByte = Serial.read();
    /* XXX: Get position using custom and test code */
    if (incomingByte == '!')
      /* Get position */
      Serial.print("TM");
      Serial.print(1);
      Serial.print(" ");
      Serial.print("AZ");
      Serial.print(10*step2deg(AZstepper.currentPosition()), 1);
      Serial.print(" ");
      Serial.print("EL");
      Serial.println(10*step2deg(ELstepper.currentPosition()), 1);
    /*new data*/
    else if (incomingByte == '\n')
      p = buffer;
      buffer[counter] = 0;
      if (buffer[0] == 'A' && buffer[1] == 'Z')
        if (buffer[2] == ' ' && buffer[3] == 'E' && buffer[4] == 'L')
          /* Get position */
          Serial.print("AZ");
          Serial.print(step2deg(AZstepper.currentPosition()), 1);
          Serial.print(" ");
          Serial.print("EL");
          Serial.print(step2deg(ELstepper.currentPosition()), 1);
          Serial.println(" ");
        else
          /*Get the absolute value of angle*/
          str = strtok_r(p, " " , &p);
          strncpy(data, str+2, 10);
          angleAz = atof(data);
          /*Calculate the steps*/
          stepAz = deg2step(angleAz);
          if (str[0] == 'E' && str[1] == 'L')
            angleEl = atof(data);
            stepEl = deg2step(angleEl);
      /* Stop Moving */
      else if (buffer[0] == 'S' && buffer[1] == 'A' && buffer[2] == ' ' && buffer[3] == 'S' && buffer[4] == 'E')
        /* Get position */
        Serial.print("AZ");
        Serial.print(" ");
        Serial.print("EL");
        Serial.println(step2deg(ELstepper.currentPosition()), 1);
        stepAz = AZstepper.currentPosition();
        stepEl = ELstepper.currentPosition();
      /* Reset the rotator */
      else if (buffer[0] == 'R' && buffer[1] == 'E' && buffer[2] == 'S' && buffer[3] == 'E' && buffer[4] == 'T')
        /* Get position */
        Serial.print("AZ");
        Serial.print(" ");
        Serial.print("EL");
        /*Move the steppers to initial position*/
        Homing(0,0);
        /*Zero the steps*/
        stepAz = 0;
        stepEl = 0;
      counter = 0;
      /*Reset the disable motor time*/
      t_DIS = 0;
    /*Fill the buffer with incoming data*/
    else {
      buffer[counter] = incomingByte;
      counter++;
/*Error Handling*/
void error(int num_error)
  switch (num_error)
    /*Azimuth error*/
    case (0):
      while(1)
        Serial.println("AL001");
        delay(100);
    /*Elevation error*/
    case (1):
      while(1)
        Serial.println("AL002");
        delay(100);
    default:
      while(1)
        Serial.println("AL000");
        delay(100);
/*Send pulses to stepper motor drivers*/
void stepper_move(int stepAz, int stepEl)
  AZstepper.moveTo(stepAz);
  ELstepper.moveTo(stepEl);
  AZstepper.run();
  ELstepper.run();
/*Convert degrees to steps*/
int deg2step(double deg)
  return(RATIO*SPR*deg/360);
/*Convert steps to degrees*/
double step2deg(int Step)
  return(360.00*Step/(SPR*RATIO));
microstepping means that every pulse will only make a fraction of a step, if you’re running full steps and 200 steps per revolution, this needs to me multiplicated by the same number as you are microstepping. so the SPR set to 1600 is correct.
another issue that arrives quite fast is the fastest the arduino can send these pulses, depending on how it’s implemented and what pins, this can become an issue.
if it doesn’t change when you set it in the code, I’d guess there’s a break in the code → build → flash process that somehow either uploads the wrong code or to something else or not at all.
Turns out the script wasn’t working right due to integer overflows. I got some help on another forum and chatGPT.
I’m pasting the final script in case someone needs it.
This script allows you to build your own rotator and it features a meridian flip fix so there are no interruptions when a satellite is crossing North. I have not written the script myself, I got the original script from here: Solved the meridian flip problem
This is a modified script with bug fixes that allows you to use microstepping without buffer overflows which prevented the correct fuctions if you used higher than 400 steps per revolution. It is preset to use 1/8 microsteps as is.
#include <stdlib.h>
#include <math.h>
#define DIR_AZ 9 //PIN for Azimuth Direction
#define MS1 18 //PIN for step size
#define SPR 1600L //Step Per Revolution
#define RATIO 50L //Gear ratio
void setup()
  AZstepper.setMaxSpeed(1600);
  AZstepper.setAcceleration(1000);
  ELstepper.setMaxSpeed(1600);
  ELstepper.setAcceleration(1000);
  /*Enable Motors*/
  /*Step size*/
  digitalWrite(MS1, HIGH); //Full step
  /*Homing switch*/
  /*Serial1 Communication*/
  Serial1.begin(19200); // Use Serial1 for RX/TX on Arduino Nano, othewise change Serial1 to Serial
  /*Initial Homing*/
void loop()
  static long AZstep = 0;
  static long ELstep = 0;
  /*Time Check*/
  if (t_DIS == 0)
    t_DIS = millis();
  /*Disable Motors*/
  /*Enable Motors*/
  else
  /*Read the steps from Serial1*/
/*Homing Function*/
void Homing(long AZsteps, long ELsteps)
  long value_Home_AZ = HIGH;
  long value_Home_EL = HIGH;
  long n_AZ = 1; //Times that AZ angle has changed
  long n_EL = 1; //Times that EL angle has changed
      isHome_AZ = true;
      isHome_EL = true;
      n_AZ++;
        error(0);
        break;
      n_EL++;
        error(1);
        break;
    AZstepper.run();
    ELstepper.run();
    AZstepper.run();
    ELstepper.run();
  /*Reset the steps*/
void cmd_proc(long &stepAz, long &stepEl)
  /*Serial1*/
  char buffer[256];
  char incomingByte;
  char *p=buffer;
  char *str;
  static long counter=0;
  char data[100];
  /*Read from Serial1*/
  while (Serial1.available() > 0)
    incomingByte = Serial1.read();
      /* Get position */
      Serial1.print("TM");
      Serial1.print(1);
      Serial1.print(" ");
      Serial1.print("AZ");
      Serial1.print(10*step2deg(AZstepper.currentPosition()), 1);
      Serial1.print(" ");
      Serial1.print("EL");
      Serial1.println(10*step2deg(ELstepper.currentPosition()), 1);
    /*new data*/
      p = buffer;
          /* Get position */
          Serial1.print(step2deg(AZstepper.currentPosition()), 1);
          Serial1.print(" ");
          Serial1.print(step2deg(ELstepper.currentPosition()), 1);
          Serial1.println(" ");
        else
      // detect any 360-0 or 0-360 crossing to avoid Meridian Flip
          double eps;     // difference in degrees between positions, desired and current
      double az_val = angleAz;    // desired position in degrees
      double az_att = step2deg(AZstepper.currentPosition());  // current position in degrees
      // from here it is assumed that the positions are always between 0 and 360, so to be safe it returns them to the range 0-360
      long n_giri=( long ) (az_att / 360.0);   // example: with az_att=357 -> ngiri = 0
        az_att = az_att - ((double) n_giri)*360.;  // current azimuth, reported between 0 and 360 degrees
      n_giri=( long ) (az_val / 360.0);
      az_val = az_val - ((double) n_giri)*360.;  // desired azimuth, reported between 0 and 360 degrees
          eps = az_val - az_att;     // calculate position error
          if (fabs(eps) > 180.)      // must make more than a half turn (so it must cross north)
             if (az_att < 180)       // go through it turning counterclockwise
               // example: it must go from +10 to +350, eps becomes (350-360)-10=-20 and turns backwards
               eps = (az_val - 360) - az_att;
             else    // az_att > 180
               // passed north by turning clockwise (example az_att=350 and az_val=10)
               eps = az_val -(az_att - 360);   // 10 - (350 - 360) = +20 e and continues clockwise
             }      // end if az_att > 180
          }   // end if fabs(eps) > 180
          // redefines the desired position in steps
          stepAz = AZstepper.currentPosition() + deg2step(eps);
      // end of meridian flip detection code
      /* Stop Moving */
        /* Get position */
        Serial1.print(" ");
        Serial1.println(step2deg(ELstepper.currentPosition()), 1);
        /* Get position */
        Serial1.print(" ");
        Homing(0,0);
        /*Zero the steps*/
        stepAz = 0;
        stepEl = 0;
      counter = 0;
      t_DIS = 0;
    else {
      counter++;
/*Error Handling*/
void error(long num_error)
  switch (num_error)
    /*Azimuth error*/
    case (0):
      while(1)
        Serial1.println("AL001");
        delay(100);
    /*Elevation error*/
    case (1):
      while(1)
        Serial1.println("AL002");
        delay(100);
    default:
      while(1)
        Serial1.println("AL000");
        delay(100);
void stepper_move(long stepAz, long stepEl)
  AZstepper.run();
  ELstepper.run();
// Convert degrees to steps
/* original code out-commented
long deg2step(double deg)
//Convert degrees to steps
double step2deg(long Step)
