GR-satellites UPloader checking for string in hex
Last time I presented my gr-satellites UPloader. It uses the updated gr-satellites block Check AX.25 address.
This is good for satellites transmitting according to AX.25 protocol.
Additionally to that, I’ve recently built another block: Check Hex String
Check Hex String
It checks for a given string in hexadecimal beginning from a starting position on.
Use it for satellites transmitting in non AX.25 protocol where at least one byte is always the same and at the same position.
I also built a little UPloader in the style of the aforementioned one but with less functionality making use of this new block.
It’s practically like the Online Telemetry Forwarder.
SatNOGS_UPloader_using_block_Check_Hex_String.zip (2.9 KB)
Supporting currently up to 4 satellites.
Preconfigured: NanoFF A, NanoFF B, GO-32, ALSat-1N
Daniel
