I’m trying to install gpredict from source code on Linux mint. But I have a problem with ./configure, so below I will text by steps what I have done.
I installed libraries :
Gtk+ 3 install libgtk-3-dev
GLib 2.32 ( here I could make some mess … I make install autoconf + automake + m4 from gnu, i installed all in home directory, but during that installation I had some errors especially with automake, cause I installed last release but it asked me for 1.13 so I installed this one too, and I think I could overwrite files … but I delete all ( I hope I did ) and did it again so eventually it worked.
Then I download gpredict-2.2.1.tar.gz unpacked it and try to ./configure but it didn’t work so I did automake + autoconf - it created configure exe file but I’m getting this error now :
./configure: line 2033: syntax error near unexpected token build-config.h' ./configure: line 2033:AM_CONFIG_HEADER(build-config.h)’
And all of that because I couldn’t navigate satellite - I had gpredict installed apt-get install gpredict, it was working. On radio I could listen to radio amateurs broadcast, but with satellites I had nothing. So I started to wonder if maybe there is some libraries I’m missing for radio + gpredict, and I wasn’t sure if I need to make some additional configuration about Doppler compensation, cause on gpredict it seemed to work on radio control - but I don’t know if there is no need for special conf for transceiver …
I hope it’s not too messy what I’ve written… I will appreciate any help cause I have no more ideas.
Yes it works, thank you Thats what I did before I decided to installed it from source. But the problem is that I don’t know how to configure Doppler with my transceiver (its kenwood ts 2000) on gpredict it seems to work, but I cannot catch satellite signals So I just decide to try that
So do You have any idea if I have to configure Doppler additionally or its built in gpredict ? And do I have to set manually orbit path of the satellite in the transceiver or gpredict does that too ?
Yes, it’s for the FT-847, but maybe there are some useful hints for you.
gpredict does all you need: doppler correction and antenna positioning if you want to.
It needs a bit of experience to understand how all these things are working together. There’s a manual available with gpredict - so please go through the steps in it first.
The binary packages are complete. You will not get any extra functionality by compiling from source, not at this time anyway.
Having said that, building from source should “just work” but I find it hard to have any idea what could be wrong after you tried many things… I can only recommend to
Install the dependencies according to the readme
Run the configure script from the source tarball
If you get an error during configure ask about it. Perhaps we can find out what is wrong.
