Documentation - Wiki - Operate - Decode Telemetry and Packets?
After running several observations, I noticed that DUV (Data Under Voice) telemetry was being decoded, but not presented in human form. I was curious and posted questions under my [observation] (Observation 150869: FOX-1A (40967) - FoxTelem?) of Fox1-A. The existing DUV decode showed me a lot of hexadecimal data, but no way to see it in human readable form. What does it all mean???
@n5fxh Francois-Xavier showed me how to download the ogg audio, convert it to a .wav file using sox and import it into FoxTelem to see everything. I repeated his instructions and figured it out.
I searched the Forum. It sounds like a pretty common thing: We’ve captured the audio file and sometimes there’s a decoder for the data, but not a lot of tools to see esp. telemetry in human readable form.
I did not want to lose how to do the decode and see it buried the discussion about the observation I made. If there’s an initial consensus, I will start adding a section called “Decode Telemetry and Packets” under Operate as my contribution back into a very nice system.
Your comments please.
–Konrad, WA4OSH
Personally, I’m always in favour of improving the wiki. :smile: IMHO, go for it.
@saintaardvark OK … it’s a beginning:
https://wiki.satnogs.org/Main_Page
–Konrad, WA4OSH
\o/ Awesome work! Thanks kindly for adding it to the wiki.
It’s great!
Thank you.
@saintaardvark @n5fxh
I’m further drilling-down into the subject of demodulators and decoders…
I’ve been working on the Decode Telemetry and Packets Wiki pages some more.
Is there a list of decoders provided by SatNOGS? E.g. I can’t get CW to demodulate anything. It gives the illusion as if its working on something.
After I try all of the included demodulators, I’m going to do a search and document those external packages that can be used in conjunction with the SatNOGS client, capturing how it’s done.
–Konrad
@WA4OSH – the closest thing I know of to a list of decoders is this directory in the gr-satnogs repo, which has the GNU Radio flowgraphs for the out-of-tree module. You can see that there are files for FOX telemetry, Morse, AX25 and so on. However, maybe someone else from the project can give a better answer? (/cc @fredy / @pierros)
CW decoding in particular is a work in progress; you can probably get the latest status by asking in Matrix/IRC, but I have the impression it’s changing quickly.
Thanks again for adding all this to the wiki!
I will add to the Wiki as I learn new things … a way to pay back for using other people’s Ground Stations.
I will use the list and look for examples in Observations that have been made already.
Since CW (technically demodulator) is a work in progress, then the user should be notified if there is no demodulator/decoder available.
I make a distinction between demodulating the signal and decoding things … it has to do with how much work or how many layers have been processed :smiley:
–Konrad
I edited the Ground Stations page. Take a look.
–Konrad
Here’s my discoveries for today while still excited to write it up :slight_smile:
Looking at the ax.25 stuff - just discovered direwolf and have this procedure for AFSK1K2 like 42707 - X-CUBESAT - process the audio and decode to a text file in a single line:
$ sox -t ogg satnogs_171323_2018-07-01T01-19-28.ogg -esigned-integer -b 16 -r 48000 -t raw - | direwolf -B 1200 -b 16 -n 1 -r 48000 -q hd -t 0 -a 0 - > xcubesat_42707_171323.txt
Then download and run the ON01FR telemetry software from http://site.amsat-f.org/2017/05/17/on01fr-on05fr-logiciel-de-decodage-des-telemesures/ - - it only worked with java 8 - 10 got a stack dump
Click “File” and find the xcubesat_42707_171323.txt created above.
Click “Load” and enjoy some nice graphs of voltage, current and temperature
You should capture that into the Wiki pages. Help others discover the fun of decoding telemetry and packets.
–Konrad
Thanks for adding this to the wiki!! If someone wanted to convert my post into the wiki its still relevant on decoding in windows: Windows manual decoding howto
Our future plans are to roll all of this data into db.satnogs.org (where we already collect millions of frames through SiDS clients). Each satellite that we have telemetry decoding information for would then have a dashboard that visualizes all of the decoded data. We had a rough framework for this before adopting SiDS and haven’t fixed the dashboards since (I think we need to take a fresh approach to this).
At any rate, I wanted to point out that someday we won’t need to manually decode all of these. But for now I’ve got no ETA on the automation there. :slight_smile:
