Need help (again).
I am running the docker version, installed few months ago, working OK.
I tried to find another USB on the computer, port with less noise. After some tests, the system stopped work.
So, if I have inserted RTL V4 blog and HackRF in computer, but it seems I can see only the HackRF:
yo4dft@marte:~/station-3600$ SoapySDRUtil --find
## Soapy SDR -- the SDR abstraction library ##
[INFO] [UHD] linux; GNU C++ version 12.2.0; Boost_107400; UHD_4.3.0.0+ds1-5
Found device 0
default_input = False
default_output = True
device_id = 0
driver = audio
label = Built-in Audio
Found device 1
device = HackRF One
driver = hackrf
label = HackRF One #0 66a062dc232c3e9f
part_id = a000cb3c00614f5a
serial = 000000000000000066a062dc232c3e9f
version = 2024.02.1
If I use usb reset, the computer say both SDR are inserted:
yo4dft@marte:~/station-3600$ usbreset
Usage:
usbreset PPPP:VVVV - reset by product and vendor id
usbreset BBB/DDD - reset by bus and device number
usbreset “Product” - reset by product name
Devices:
Number 001/005 ID 1a2c:0c23 USB Keyboard
Number 001/008 ID 0bda:2838 Blog V4
Number 001/002 ID 174c:2074 AS2107
Number 001/003 ID 10c4:8108 USB OPTICAL MOUSE
Number 001/006 ID 1d50:6089 HackRF One
Number 002/002 ID 174c:3074 AS2107
If I am running rtl_test, the computer see the RTL V4:
yo4dft@marte:~/station-3600$ rtl_test
Found 1 device(s):
0: RTLSDRBlog, Blog V4, SN: 00000001
Found Rafael Micro R828D tuner
RTL-SDR Blog V4 Detected
Sampling at 2048000 S/s.
Info: This tool will continuously read from the device, and report if
samples get lost. If you observe no further output, everything is fine.
Reading samples in async mode…
^CSignal caught, exiting!
User cancel, exiting…
Samples per million lost (minimum): 0
For SoapySDRUtil, something wrong:
yo4dft@marte:~/station-3600$ SoapySDRUtil --probe=“driver=rtlsdr”
Probe device driver=rtlsdr
Error probing device: SoapySDR::Device::make() no match
When I am loading the HackRF settings, no reception (waterfall, data, etc):
yo4dft@marte:~/station-3600$ docker-compose exec satnogs_client bash
File “/usr/lib/python3/dist-packages/urllib3/connectionpool.py”, line 705, in urlopen
httplib_response = self._make_request(
File “/usr/lib/python3/dist-packages/urllib3/connectionpool.py”, line 400, in _make_request
conn.request(method, url, **httplib_request_kw)
File “/usr/lib/python3.11/http/client.py”, line 1282, in request
self._send_request(method, url, body, headers, encode_chunked)
File “/usr/lib/python3.11/http/client.py”, line 1328, in _send_request
self.endheaders(body, encode_chunked=encode_chunked)
File “/usr/lib/python3.11/http/client.py”, line 1277, in endheaders
self._send_output(message_body, encode_chunked=encode_chunked)
File “/usr/lib/python3.11/http/client.py”, line 1037, in _send_output
self.send(msg)
File “/usr/lib/python3.11/http/client.py”, line 975, in send
self.connect()
File “/usr/lib/python3/dist-packages/docker/transport/unixconn.py”, line 30, in connect
sock.connect(self.unix_socket)
FileNotFoundError: [Errno 2] No such file or directory
During handling of the above exception, another exception occurred:
File “/usr/lib/python3/dist-packages/requests/adapters.py”, line 489, in send
resp = conn.urlopen(
File “/usr/lib/python3/dist-packages/urllib3/connectionpool.py”, line 789, in urlopen
retries = retries.increment(
File “/usr/lib/python3/dist-packages/urllib3/util/retry.py”, line 552, in increment
raise six.reraise(type(error), error, _stacktrace)
File “/usr/lib/python3/dist-packages/six.py”, line 718, in reraise
raise value.with_traceback(tb)
self.send(msg)
self.connect()
urllib3.exceptions.ProtocolError: (‘Connection aborted.’, FileNotFoundError(2, ‘No such file or directory’))
File “/usr/lib/python3/dist-packages/docker/api/client.py”, line 214, in _retrieve_server_version
return self.version(api_version=False)[“ApiVersion”]
File “/usr/lib/python3/dist-packages/docker/api/daemon.py”, line 181, in version
return self._result(self._get(url), json=True)
File “/usr/lib/python3/dist-packages/docker/utils/decorators.py”, line 46, in inner
return f(self, *args, **kwargs)
File “/usr/lib/python3/dist-packages/docker/api/client.py”, line 237, in _get
return self.get(url, **self._set_request_timeout(kwargs))
File “/usr/lib/python3/dist-packages/requests/sessions.py”, line 600, in get
return self.request(“GET”, url, **kwargs)
File “/usr/lib/python3/dist-packages/requests/sessions.py”, line 587, in request
resp = self.send(prep, **send_kwargs)
File “/usr/lib/python3/dist-packages/requests/sessions.py”, line 701, in send
r = adapter.send(request, **kwargs)
File “/usr/lib/python3/dist-packages/requests/adapters.py”, line 547, in send
raise ConnectionError(err, request=request)
requests.exceptions.ConnectionError: (‘Connection aborted.’, FileNotFoundError(2, ‘No such file or directory’))
File “/usr/bin/docker-compose”, line 33, in
sys.exit(load_entry_point(‘docker-compose==1.29.2’, ‘console_scripts’, ‘docker-compose’)())
File “/usr/lib/python3/dist-packages/compose/cli/main.py”, line 81, in main
command_func()
File “/usr/lib/python3/dist-packages/compose/cli/main.py”, line 200, in perform_command
project = project_from_options(‘.’, options)
File “/usr/lib/python3/dist-packages/compose/cli/command.py”, line 60, in project_from_options
return get_project(
File “/usr/lib/python3/dist-packages/compose/cli/command.py”, line 152, in get_project
client = get_client(
File “/usr/lib/python3/dist-packages/compose/cli/docker_client.py”, line 41, in get_client
client = docker_client(
File “/usr/lib/python3/dist-packages/compose/cli/docker_client.py”, line 170, in docker_client
client = APIClient(use_ssh_client=not use_paramiko_ssh, **kwargs)
File “/usr/lib/python3/dist-packages/docker/api/client.py”, line 197, in init
self._version = self._retrieve_server_version()
File “/usr/lib/python3/dist-packages/docker/api/client.py”, line 221, in _retrieve_server_version
raise DockerException(
docker.errors.DockerException: Error while fetching server API version: (‘Connection aborted.’, FileNotFoundError(2, ‘No such file or directory’))
I tried to reinstall from step : wget https://github.com/kng/satnogs-client-docker/raw/main/lsf/docker-compose.yml from guide
(satnogs-client-docker/lsf/LSF-GUIDE.md at main · kng/satnogs-client-docker · GitHub), same problems.
Cristian, YO4DFT
