CroCube: QSL cards!
Hi Nitin,
Thanks for trying the digipeater of CroCube.
I’m usually putting 50 watts into a 9.5 dBd UHF antenna.
Satgate is a different thing.
I’m guessing you are referring to the digipeater dashboard.
EA5WA, me and others just upload received data (telemetry and also digipeated packets) to SatNOGS.
In my case, I’m using gnuradio and blocks from gr-satellites as described for the GR-satellites uploader.
You may also simply use GetKISS+ instead.
By the way, if you have no luck with CroCube, feel free to try LASARSat.
73
Daniel
