Next schedule.
Hi, what’s the best way to receive a CW signal?
I have an RTL-SDR and an SDRSharp.
Regards
Hi I use a program called SDR Console https://www.sdr-radio.com/console
Connect your antenna to the RTL-SDR connect this to your computer then set the frequency of the satellite you wish to receive. You can record this In sdr console.
I also use my Satnogs ground station this is probably the easiest way.
Thanks dl7ndr.
I’m new and don’t know much about amateur radio.
To get a QSL card APRS Degipeat, I understand you have to transmit and receive a signal? or is enough to just receive someone’s signal via satellite?
I know my questions may be stupid, but I don’t know much about all this yet.
Regards
yes. its enough
It’s the operators’s decision. Just ask them.
Could be different from satellite to satellite.
Received a beacon today. No other stations heard, and couldn’t confirm my own digipeat.
Fm JS1YPT To APTT4 Via WIDE1-1,WIDE2-1 <UI pid=F0 Len=30 PF=0 >[10:41:22]
>Hello World!! This is BOT�N.
Next schedule!
2026-02-20 07:1x no digi
The signal shutdown is planned for March 2nd. from jamsat-bb
2026-02-23 14:3x heard JH4DHX-3. BOTAN was parroting back what I sent.
14:37:01 JH4DHX-3> CQ JS1YPT*: Hello! DE JH4DHX/3 Takatsuki-city, Osaka PM74TU. v(^^)
14:37:08 JS1YPT> APTT4 WIDE1-1 WIDE2-1:
14:37:43 JS1YPT> APTT4 WIDE1-1 WIDE2-1: s
14:37:45 JS1YPT> APTT4 WIDE1-1 WIDE2-1: >JH4XSY-1>APZ001,JS1YPT:!3604.a8N/14012.43E>
Noted on Amsat board - end of botan transmissions…
