Should I be seeing automatic decoding with my stations? I was under the impression that it was working with at least APT. I’ve recorded several great passes and been able to decode from audio outside of SatNOGS. My stations haven’t decoded anything nor registered any errors during such passes.
The config on both is similar and pasted below, but I do have ENABLE_DECODED_DATA=“True”
Perhaps, I do not know. Can anyone of the satnogs-client guys help us?
As far the NOAA decoder concerns, you can use the --sync=0 option to disable the synchronization. This eventually will generate a non-aligned or even an only noise image, regardless the presence or absence of signal. Please post the resulting image and audio to be able to help you.
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name Version Architecture Description
ii gr-satnogs 20171016.13f armhf SatNOGS GNU Radio Out-Of-Tree Mod
ii gr-satnogs 20171015.13f armhf SatNOGS GNU Radio Out-Of-Tree Mod
@cshields I guess I’m mistaken, but I had thought that executing the playbook through satnogs-setup was grabbing the latest. However, it looks like I’ve got one at .4 and one at .5. If it’s the playbook acting up, just let me know if I can grab anything to help debug.
yeah, that’s the intent… if it is not working that way then hmmm… Try re-running it on both of your systems now, there were some fixes put in that should fix the FSK scripts.
gitlab went belly up today, hence your errors… At least I hope those are the only reasons for the errors. Let’s hope gitlab holds up now and the latest run works for you.
@cshields Ah, okay… that makes sense… made for an interesting user experience!
In the middle of the playbook I started getting messages such as unable to locate file. When I got it to load later, git decided there were some uncommitted local changes. So, after a hard reset it worked fine. I had just assumed you were still messing with the repo and I didn’t realize it went down.
I misspoke on the FSK fix: run the ‘sudo satnogs-setup’ command and hit the “Update” command before “Apply”. This will ensure you update to the latest first…
