I have been running a station for a while and logging in to add observations usually 2 days at a time, the maximum advanced timing allowed. Is there a way to schedule all ISS passes over my station and some of the ham radio sats routinely and ongoing ? Any chance we can have this built into the software; sorry I don’t code
I understand there is an option to load and auto scheduler, was just wondering if anyone else would find this feature useful in the GUI side of software?
There’s the auto-scheduler, with the priorities file you can set it to either schedule only those specified or to have it fill up the rest of the time with random satellites.
I have installed the auto-scheduler for the satellite PEGASUS on my Station in Austria.
I documented the process, since I ran into some errors during installation. Maybe the file attached will help you for setting up the auto-scheduler. You only need to adapt it to the NORAD-ID and transmitter you want to observer of the ISS.
Note: The paths in the document are for my local Setup on a RPi, they may differ for you. Moreover, I have generated the content of the priorities_XXXX.txt file using a gen-priorities.py script. The standard procedure, which is discribed in the auto-scheduler documentation didn’t work out for me. Also note, that the auto-scheduler is not part of any GUI, its a routine which runs at defined times using a cronjob. This routine schedules the specified passes for your Station in the SatNOGS Network.
Hi SA2KNG, I had seen this and looked at it but decided it looked a bit involved, i only manage to get the satnogs up and running after a few tries. Will try and work through it
Cheers
I might be able to follow this as you sugest, many thanks.
I was asking about building it in to the gui to be able to avoid the under the bonnet work this needs, a nice tick box to say add all passes ongoing to my list would be great, or better specify until x date, or the next 50
I will give it a go and let you know
cheers
Max
I think that feature has been discussed, perhaps in the future.
I’m running everything satnogs in docker and also the auto-scheduler, in that one I just use a sleep loop instead of crontab. while true; do ./schedule_single_station.py -s xxxx; sleep 3600; done
I wasn’t proposing docker as a solution, rather the method of execution I used in it (:
The venv install is the easiest path for auto-scheduler as it has pretty simple dependencies.
The method described in the repo works just fine, but this is what I used earlier (python3-venv required):
cd
git clone https://gitlab.com/librespacefoundation/satnogs/satnogs-auto-scheduler.git
cd satnogs-auto-scheduler
python3 -m venv venv
./venv/bin/pip3 install .
Run from crontab: ~/satnogs-auto-scheduler/venv/bin/schedule_single_station.py -s XXX
When done this way, the parser is already set for the script, so activating the venv before is not needed.
FYI I’m running docker on all my satnogs stations, a mix of pc, rpi and odroid, all on linux.
Indeed we plan to kind of integrate auto-scheduling in Network code. The plan is to have Network satellite list of priorities and station owners they can have their own that will overwrite all or part of the Network list.
In the first version of it, it will be very simple and the Network satellite list will be handled manually but in the next we plan to be populated in an automatic way with some criteria.
Unfortunately still we have to finish some maintenance work in both Network and DB, so I expect this new feature as well as others to come after the Summer.
